grandpa pete Samba Member
Posted: Wed Jul 13, 2016 12:34 pm Post subject: Re: What did you do to your Beetle this week? |
far rider wrote: |
Body back on pan today with much help from my friend Matt. Separated in 1986 this slow, frequently interrupted process, is finally coming to a close.] |
30 YEARS !!!!!
Thanks I needed that ; I've been frustrated lately that my project has been headed towards 3 years
Now I don't feel so bad _________________ 63 two fold rag
66 sedan delivery Type 6
http://www.thesamba.com/vw/forum/viewtopic.php?t=569619&highlight=sedan+delivery |
sludge20 Samba Member
Joined: May 30, 2016 Posts: 22 Location: Bellvue, Nebraska
Posted: Tue Jul 19, 2016 10:11 am Post subject: Re: What did you do to your Beetle this week? |
Squared away the 12 volt conversion. Had some fun installing the starter bushing in the 6 volt hole...got a stereo hooked up. Battling carburetor settings and an as of yet found exhaust leak. Rebuilt entire brake system. Drank beer. |
FL-Frank Samba Member
Joined: August 08, 2015 Posts: 823 Location: Jupiter, Florida
Posted: Wed Jul 20, 2016 9:41 am Post subject: Re: What did you do to your Beetle this week? |
A few weeks ago, my car's fuel gauge started remaining at the full level regardless of the amount of fuel in the tank.
Yesterday, I replaced the fuel tank sending unit (Brasilian stamped 1989) with a new one from WW and recalibrated the fuel gauge. |
JonInAtl Samba Member
Posted: Wed Jul 20, 2016 9:50 am Post subject: Re: What did you do to your Beetle this week? |
Discovered that the reason my shifter had no relationship to the gear it was in was actually becuse the set-screw at the coupler was barely screwed in. Tightened it back up, put in a safety wire, and now I have an "H" pattern rather than a "wide-oval".
The bushings look brand new (I just bought the car on Saturday).
On to the next project: Why the clutch pedal actually leans slightly forward with miles of play (suspect the cable is out of adjustment). |
Fred_e81 Samba Member
Joined: August 31, 2008 Posts: 60 Location: El Paso, Tx
Posted: Wed Jul 20, 2016 3:53 pm Post subject: Re: What did you do to your Beetle this week? |
I finally got around to making a rear speaker tray and installed a 10 inch kicker bass station. This was my first speaker tray, what do you guys think?
[/img]
Posted: Thu Jul 21, 2016 7:47 am Post subject: Re: What did you do to your Beetle this week? |
Fred_e81 wrote: |
what do you guys think? |
I think I don't want to be sitting next to you at a traffic light listening to YOUR music .
It's an " old guy " thing
Nice car ! Good job . _________________ 63 two fold rag
Posted: Thu Jul 21, 2016 7:51 pm Post subject: Re: What did you do to your Beetle this week? |
Grandpa Pete,
Thanks for the comment!! I was going for a nice sound not too boomy but not to plain Jane. |
Posted: Fri Jul 22, 2016 11:23 am Post subject: Re: What did you do to your Beetle this week? |
Fred_e81: Looks great!
Today I replaced the front shifter rod bushing in my '65.. it was missing.
Wow what a difference! |
flyboy161 Samba Member
Joined: December 26, 2009 Posts: 2091 Location: Perry, GA
uglydog56 Samba Member
Posted: Sat Jul 23, 2016 6:51 pm Post subject: Re: What did you do to your Beetle this week? |
Finished adjustable front beam install. Replaced MY missing shifter bushing, too! Put a short shift kit on my shifter while I was in there. Replaced the emergency brake handle. Pulled the engine and installed the baffle plate under the alt stand that I didn't know needed to be there. Installed a deep sump. Ran the valves. Changed plugs and wires. Just need to replace the wiper motor and redo the power wire to my amp tomorrow, and I'll be back on the road! |
buckyten Samba Member
Joined: June 30, 2016 Posts: 32 Location: placerville,ca
Posted: Tue Jul 26, 2016 8:21 pm Post subject: Re: What did you do to your Beetle this week? |
Just
My third week of ownership, today finished taking seats out and stripping down to spring frames, found a couple of broken springs, I guess I need to weld them. Also spent time working on the seat slides so they are smooth.
Last week stripped all the old carpet and applied Pors 15 |
JimSP16 Samba Member
Posted: Fri Jul 29, 2016 7:50 am Post subject: Re: What did you do to your Beetle this week? |
Congrats Pete! I moved my Beetle to A friends Shop rented some space very cheap, anyway There's no help I can give you so Morning as I'm taking a research day out of the wrenching....can't get my 1500 started...tried everything so few questions for EVRYONE AND ANYONE . it's compression is at 120 psi all the way around. Is that to high? it's a fresh rebuild.timi.ng seems to be perfect set then set again AM I ABOUT to need to drop the engine again? should I do a complete maintance check of all tolerances? I've got plenty ....well more a lot more time and perfect conditions (lacking only in $$$ still I can squeeze 14cents out of a dime! it's Jim again asking for More HELP....But at least I'm better informed and have some experience after the rebuild. Thanks in advance for any input
JIM |
AlteWagen Troll
Posted: Mon Aug 01, 2016 1:40 pm Post subject: Re: What did you do to your Beetle this week? |
GOT my fresh new rebuild fired up TODAY ...FINALLY ! IDLES great get some back fire when I raised the RPM's still some adjustments to make . but after all the stop then go work the final bit seemed to be the most difficult. MY BAD now that that 's free & over I'm just going to enjoy the ride awhile before I start on the minor paint repairs ...gotta save some nickels then get started on the 1st "look" |
DHMaher Samba Member
Joined: November 16, 2009 Posts: 787 Location: Portland, Oregon
Posted: Mon Aug 01, 2016 10:18 pm Post subject: Re: What did you do to your Beetle this week? |
Installed a matching horn button from Steve AKA VW Horn Button Guy.
http://www.thesamba.com/vw/forum/profile.php?mode=viewprofile&u=301475
Also installed a engine light with a mercury switch, wired to the taillight. And made a bracket to mount my AAA Connecticut badge. Bug is originally from CT.
[/url] _________________ Daniel
"POs, you gotta love them, because killing them is illegal." -Unknown Samba Member
1967 Beetle - Java Green
See my ads |
Posted: Mon Aug 01, 2016 11:29 pm Post subject: Re: What did you do to your Beetle this week? |
ordered carpet set from Sewfine, 15pc hope its as good as it seems also ordered shift coupler oem from WW |
aog9354 Samba Member
Joined: August 03, 2016 Posts: 1 Location: Tacoma, Washington
Posted: Wed Aug 03, 2016 8:28 pm Post subject: Re: What did you do to your Beetle this week? |
Replacing rear wheel cylinders, brake shoes, springs & axle seals on the 67. Its work in progress. The Grandsons are helping & learning. Fun times |
Faustling Samba Member
Posted: Sun Aug 07, 2016 5:13 am Post subject: Re: What did you do to your Beetle this week? |
What did I do this week? Well I purchased my first bug!!!
1965 w/ sunroof. Now to make it mine.
That's my 14 Si in the back ground. Not surprisingly they handle differently. But this 65 will eventually leave it in the dust. hehe
dgas Samba Member
Joined: November 09, 2015 Posts: 7 Location: Triad area, NC USA
Posted: Sun Aug 07, 2016 10:56 am Post subject: Re: What did you do to your Beetle this week? |
Replaced generator on my '64 type 1. A bit bigger job than I anticipated; toughest part was replacing the front engine tin after installing the engine. Replaced leaking swing axle boots & transmission oil. It's so much easier to get at the oil fill plug with the engine out. It's done & all is well. |
Posted: Wed Aug 17, 2016 6:16 am Post subject: Re: What did you do to your Beetle this week? |
Still trouble shooting...discovered generator needs rebuild, pulled it . sent core out (BOSCH) |
