63ziggy Samba Member
Joined: June 19, 2005 Posts: 1100 Location: The Woodlands, Texas
Posted: Sun Sep 13, 2015 6:05 pm Post subject: |
Just got in from a quick spin around the neighborhood. It has been a while with heat and rains and priorities. Humidity left this weekend with temps in the 80's. felt great. nice cruise. |
Ratt Samba Member
Joined: April 15, 2003 Posts: 753 Location: Puyallup, Wa
Posted: Sat Oct 10, 2015 9:36 pm Post subject: |
Trimmed up new pans and 3" body lift today. Tomorrow we install beam adjusters and weld the pan. |
Rowens54 Samba Member
Joined: September 13, 2015 Posts: 17 Location: Hillsboro, ND
Posted: Sat Oct 17, 2015 11:19 am Post subject: New plates today |
doublecanister Samba Member
Joined: September 23, 2008 Posts: 1184 Location: Richmond, Va
Posted: Sat Oct 24, 2015 11:53 am Post subject: quick run |
Fired up the Thing for the first time in months since returning from Kubeltreffen, the weather and my weekends have been jacked up since then.
I did something to my back and shoulder too so I've not felt like doing much either, but that's finally cleared up thank goodness!
To start it Took a few cranks, so it's been sitting a while, usually it starts with 1 pedal pump, not this time.
ran fine though, took er' down the road a ways and back, hope to drive it some more if the weather holds.
Didn't get to test fire the heater tho, the wife showed up with lunch and I got side tracked...
T _________________ ****************************************
2020 - Mustang Eco Boost [High Performance]
1973 - Thing
1966 - Mustang GT- Fastback
1951 - Ford F1 pickup Flathead V8 |
Ratt Samba Member
Posted: Sun Oct 25, 2015 6:42 am Post subject: |
Got the new Motor and transmission mounted to the Pan. Looks like it belongs. |
germanbilly Samba Member
Joined: October 18, 2013 Posts: 377 Location: Victorville
Posted: Sun Oct 25, 2015 10:51 am Post subject: |
The route 66 museum had their 20th birthday and had a very nice show. When we drove in with both our Things the DJ came out and said he wanted them parked next to the stage and in front of the pictures on the wall of the building. So we spent the day right up front. Had a great time and met another Thing. Will help the Joesph out getting his gas heater working and turned him on to the Thing Shop for his gas smell. We live 2 blocks off of Rt 66
GB
citroen Samba Member
Joined: February 28, 2010 Posts: 1578 Location: louisville ky
Posted: Sun Oct 25, 2015 8:49 pm Post subject: |
last day for a cruise because it is getting cold in Louisville so I took the Thing and the scooter out for a fall drive in the park and then off to a car cruise
oldthingguy Samba Member
Joined: December 02, 2007 Posts: 146 Location: California
Posted: Fri Nov 13, 2015 7:12 pm Post subject: Re: "What did you do with your Thing today"? |
Believe it or not I picked up my original owners manual from a member here today. Very cool as it shows the vin, original owner, dealer ( matches the license plate frames ) and maintenance record too. Surprised that the car did not sell until May 1975. Heading to Cars and Coffee tomorrow in the car. _________________ 73 914 2.0 - sold
63 single cab
73, 73 and 74 Thing - gone
64 notch - gone
60 23 window - gone
57 oval - gone
plus a few others I should have kept |
uniball Samba Member
Posted: Sun Mar 06, 2016 9:31 pm Post subject: Re: "What did you do with your Thing today"? |
I successfully resolved my reverse lights issue. When I bought her last June I noticed that the reverse lights did not work. Not a big deal IMO, just one of many things to fix. My '74 Thing is the first classic car and VW so every project is a learning experience. One thing that I notice, with the help of a friend, was that the reverse wire that should connect to the coil was not connected. I was able to trace the reverse switch wire off the transmutation and found the end near the coil and connected to the positive side. With naive hope I checked if I had lights but no luck. Next step was to review the wiring diagram book and compare it to what I saw. I saw a lot of discrepancies at the two four wire connectors on each side and at the lens. The color order did not match anything that was in the wiring diagram so just pulled all the wires and started from the beginning. I wired the lenses based on the book then worked on the harness. I started with the running lights and then got the turn signals working. After thatI went to the reverse lights and found the driver's side was working but the right side lite up the brake light. Went back to the right lens wires and swapped the brake wire with the reverse wire and success. I have two reverse lights and confirmed brake lights also work. |
Posted: Sun Apr 03, 2016 6:34 pm Post subject: Re: "What did you do with your Thing today"? |
Took in the first show of the season with my older brother in his aviation influenced build (1970 Beetle underneath)
Blooming Good Show was held Saturday in Nacogdoches, TX (The oldest town in TX)
Beautiful sunny day. Temps started in lower 30's. 60 by noon and 70 on high. Just perfect
We took the opportunity for a photo shoot afterward.My brother lives 4 hrs away.We try to hit at least one show a year together.
We did well. I took Best Baja trophy and my brother took Special Interest Trophy.
Fun times
Shoyrtt Samba Member
Joined: August 21, 2010 Posts: 1007 Location: Redlands, CA
Posted: Mon Apr 18, 2016 5:50 pm Post subject: Re: "What did you do with your Thing today"? |
We went to the 2016 Bugorama show and drag meet and took home the "Coolest Thing" award. Fun day!
GI Joe Samba Member
Joined: April 28, 2005 Posts: 2012 Location: Athens, TN
Posted: Mon Apr 18, 2016 7:33 pm Post subject: Re: "What did you do with your Thing today"? |
Congrats Shoyrtt!!
We spent our weekend at Bugapaluza 18 in Chattanooga!
Came home with 1st place "Thing Custom"!!
I took this shot of my Hot Rod girls reflection the passenger rear 1/4 panel of a bug! A club member debuted it at this show, after 4 yrs of having it built and WAY too much $ spent on it.. The paint was glass smooth!
And we always have the traditional post show, ride home nap! She's a trooper and loves the shows.. But can Never make it home without a snooze!
_________________ '74 Thing, "Our Thing"....
http://www.thesamba.com/vw/forum/viewtopic.php?t=4...p;start=60
'71 Beetle RPU
http://www.thesamba.com/vw/forum/viewtopic.php?p=8080337#8080337
www.NLEOMF.com
Respect, Honor, Remember |
Posted: Tue Apr 19, 2016 7:21 am Post subject: Re: "What did you do with your Thing today"? |
GI Joe
Congrats on the award!
I bailed on our first major show of the year. It was 4.5 hrs away and rain was scheduled at 70%-100% both days. I know rain or shine but not for me and the ride would not like it.
Love the trooper crashed in the back seat. I have seen that image a few times with my youngest son.
Keep up the great work |
emersonbiggins Samba Member
Joined: February 18, 2003 Posts: 1681 Location: Nebraska
Posted: Mon May 09, 2016 8:00 pm Post subject: Re: "What did you do with your Thing today"? |
Drove around town for a while then headed home when the clouds started to look bad.
lostarter Samba Member
Posted: Tue May 31, 2016 8:01 pm Post subject: Re: "What did you do with your Thing today"? |
I've been working on my thing every night for a few weeks now, trying to make it to the vw show In Woodburn, or on Saturday . I got the engine out for the first time, replaced the generator, coil , v. Reg. , wires, plugs, clutch kit, drained and filled the rgb's and trans. Wire wheeled the tow hitch and adjusted the brakes. Also grinded rubber undercoating to get to the fender bolts to replace painted over fender beading.
Today I got the front wheels off and found shot tie rods too. Hopefully all the parts come tomorrow and I can make it!
Posted: Sat Jun 04, 2016 8:35 pm Post subject: Re: "What did you do with your Thing today"? |
Got 2nd place in "thing" at the Northwest bug run. The one on the right took first
kenj06 Samba Member
Posted: Sun Jun 05, 2016 3:52 pm Post subject: Re: "What did you do with your Thing today"? |
Took a 50 mile round trip to save a '68 Bug that hadn't run for a few years. Had a scare when I was a few miles away from the destination and started hearing a strange noise. Thought maybe something in the engine or tranny was going south. Arrived at my destination, shut off the Thing and heard the droning of cicadas. That was the noise I heard while driving. Much relived I spent a few hours on the guys Bug and got it going good enough for a trip around the block. |
vw moses Samba Member
Joined: April 17, 2012 Posts: 213 Location: independance,louisiana
Posted: Thu Jun 09, 2016 7:36 pm Post subject: Re: "What did you do with your Thing today"? |
changed the oil today
went for a ride
_________________ Youtube@vw moses
73 thing-gone
66 beetle-gone
62 beetle-gone
57 beetle-gone
convertable-beetle-w/bugspray & screamer dist.(019) gone
"Where There's a Will There's a Way"
63 one of a kind beetle. 57 dash,double rear window--sweet! |
BlissBignall Samba Member
Joined: June 20, 2016 Posts: 72 Location: San Angelo, TX
Posted: Mon Jun 20, 2016 7:07 am Post subject: Re: "What did you do with your Thing today"? |
Drove it to work, with the top down...just like almost every morning for the last couple weeks! Lots of folks smile and wave as I go by! |
Posted: Mon Jun 20, 2016 6:32 pm Post subject: Re: "What did you do with your Thing today"? |
added a vent above shroud intake--fresh cool air! _________________ Youtube@vw moses
73 thing-gone
66 beetle-gone
62 beetle-gone
57 beetle-gone
