Spitty1974 Samba Member
Joined: September 30, 2011 Posts: 647 Location: California
Posted: Wed Feb 20, 2013 8:19 pm Post subject: Re: Here is a picture of the rims? |
Spitty1974 wrote: |
Here is a picture of the rims. They are all four suppose to be like the one in the picture. The guy said 14 inches, slotted......They will work on my bus right?
I guess those are slotted, it is hard to tell.....Maybe you are right, I should wait and educate myself more. I just know I want an extra set, and a guy on Craig's list is selling four and is in my area for a great price.
I'm sure I can find more later. |
cdennisg Samba Member
Joined: November 02, 2004 Posts: 20231 Location: Sandpoint, ID
Posted: Wed Feb 20, 2013 10:22 pm Post subject: |
64-67 split window buses came with 14" rims from the factory.
Lowering your bus 1-2 inches can be done with full sized stock tires. A heavy load of stuff for the dump will lower a stock height bus that far.
In the rear, you only need to re-index the torsion bars to drop a couple of inches. In the front, if you only want to drop that far, an adjustable beam is the way to go.
If you have any more questions it would be best to add them to the lowering thread. You will likely find more interested parties with more concise answers to lowering questions. Plus it keeps this thread clear of discussions outside the main topic.
http://www.thesamba.com/vw/forum/viewtopic.php?t=66927 _________________ nothing |
jpeters Samba Member
Joined: May 06, 2005 Posts: 1025 Location: Woodsfield, Ohio
Posted: Sat Apr 06, 2013 5:24 pm Post subject: |
jpeters wrote: |
What is the ET offset off the 14" wheels? |
I could measure one for you, but I don't recall exactly where ET measurements are made. _________________ nothing |
mandraks Samba Member
Joined: November 28, 2004 Posts: 7045 Location: Lawrenceville, Ga
Posted: Sat Apr 06, 2013 6:48 pm Post subject: |
cdennisg wrote: |
jpeters wrote: |
I could measure one for you, but I don't recall exactly where ET measurements are made. |
you measure the distance from the center of the rim, to the area that touches the brake drum
it can take positive and negative values, hope this helps _________________ regards
Uli
Posted: Sat Apr 06, 2013 6:56 pm Post subject: |
OK. I guess it could be hard to determine the exact center of the rim, but I am willing to give it a try. _________________ nothing |
Posted: Sat Apr 06, 2013 7:04 pm Post subject: |
jpeters wrote: |
Shouldn't you just be able to measure total width and divide by 2, then subtract that from backspace? |
what he said _________________ regards
Uli
Posted: Sat Apr 06, 2013 7:07 pm Post subject: |
jpeters wrote: |
That would make perfect sense to a man that has not had a few stouts on his Saturday evening of watching hockey.
If you are patient, I will measure a few 14, and 15 inch wheels tomorrow.
If you are impatient, I will measure them tonight. There may very well be a difference. _________________ nothing |
Posted: Sat Apr 06, 2013 7:19 pm Post subject: |
cdennisg wrote: |
jpeters wrote: |
If you are impatient, I will measure them tonight. There may very well be a difference. |
i am way ahead of you, currently in Japan i am working on Sunday already _________________ regards
Uli
Posted: Sat Apr 06, 2013 7:29 pm Post subject: |
Thanks. I'll get some pics and measurements tomorrow. _________________ nothing |
Posted: Sun Apr 07, 2013 5:11 pm Post subject: |
Sorry, haven't done it yet. It has been absolutely pouring rain all day, so I have not been out to the shop or the backyard.
I'll give it a try tonight. _________________ nothing |
flemcadiddlehopper Samba Member
Joined: December 05, 2011 Posts: 2332 Location: Kelowna, BC. Canada.
Posted: Sun Apr 07, 2013 5:51 pm Post subject: |
Hey there, I had a 15" and a 14" hanging around so I thought I'd measure them for you (even though it's raining here too) .
Here is what I came up with using the ruler they gave my kids in grade three:
J4x15 rim - ET32
J5x14 rim- ET50
For interest sake, the difference from outside edge of rim to mounting flange is 5mm between the two rims (the wider rim being the 14").
Again not too sure as to the accuracy of these measurements, given the rudimentary tools used, and the mosquitoes are just starting to come out now.
Gordo. _________________ Everybody Dies....Some Never Live.
Retrograde Garage. Vintage Aircooled, and others. |
Posted: Sun Apr 07, 2013 9:10 pm Post subject: |
I took a series of photos with measurements this afternoon. I'll get them up here ASAP. _________________ nothing |
Posted: Sun Apr 07, 2013 9:36 pm Post subject: |
OK, here is a bus 14. Total width first, then a measurement from the inner bead lip to the face where the drum contacts the wheel.
Now, a bus 15" wheel, non-crowsfoot.
And just for comparison, a wide five beetle smoothie.
Sorry for not doing this with a metric tape, it didn't occur to me at the time. _________________ nothing |
Posted: Mon Apr 08, 2013 6:42 am Post subject: |
Correct me if I am wrong (as if I have to add that on the Samba) but, rim width is measured from tire seating surface to tire seating surface, and ET is measured from centre line to mounting flange. Right?
I could not find any J stamping on my 14" rim, bus rims are 5" wide, aren't they?
