sean14538 Samba Member
Joined: June 03, 2014 Posts: 161 Location: West Jefferson, OH
themursenary Samba Member
Joined: March 30, 2015 Posts: 6 Location: United States
Posted: Mon Jul 25, 2016 7:51 pm Post subject: What did you do for your Bay recently? |
I replaced the flooring in my 1968 bus
Sprayed rust converter on the floor prior to adding the subfloor. Then placed a underlayment on top of subfloor then floating vinyl planks on top. Took me about 15-20 hours over a couple days to finish. Now I can finally put my pieces back in!
What did you do today? |
Nester355 Samba Member
Joined: July 28, 2010 Posts: 5 Location: QLD, Australia
Posted: Tue Jul 26, 2016 12:31 am Post subject: Re: What did you do for your Bay recently? |
Finally got this old girl registered. After a 2.5 year hiatus and a back yard respray I finally ironed most of the bugs out.
Took the time this week to make a glove box mount for the stereo, Then followed that with installation of an LED strip in the engine bay.
Fingers crossed I'll get some child restraints put in this month some time and take the kids for a spin.
Pinetops Samba Member
Posted: Tue Jul 26, 2016 6:51 am Post subject: Re: What did you do for your Bay recently? |
Looks good Nester. _________________ "A rolling bus gathers no rust." |
cbaucom1 Samba Member
Posted: Wed Jul 27, 2016 3:15 am Post subject: Re: What did you do for your Bay recently? |
Dang Nestor, looking good. That respray doesn't even look "backyard" to me. It does look kind of Miami Vice though. Those colors look like vacation mode to me. |
Posted: Wed Jul 27, 2016 3:19 am Post subject: |
Keith wrote: |
Gib_Gas wrote: |
Last weekend got a lot done. Drag link, tie rods, steering damper, sand and paint pop top, new seals and logos. For the roof I followed methods used by samba members. couple grits of sanding and 3 thin coats of rustoleum enamel gloss white. hardware, seals and logos from GoWesty.
first coat before and after
new footman's loops
new decal
pop top BEFORE
and AFTER
drag link
other good stuff |
Looks great! Where did you get your footman loops? |
"Footman's loops", that's what you call those? Interesting name... |
captincanuck Samba Member
Joined: August 13, 2014 Posts: 730 Location: The Great White North
Posted: Thu Jul 28, 2016 6:10 am Post subject: Re: What did you do for your Bay recently? |
cbaucom1 wrote: |
For some reason the colors reminds me of an icecream van.
Just needs a Tailgate tent installed and I'll take a holiday. Photos to be added! _________________ 1977 Microbus - Australian Import
2L, Dual carb, CJ engine, Manual
"Give me Six hours to chop down a tree, And I will spend the first four sharpening the axe" |
Globespotter Samba Member
Joined: February 16, 2012 Posts: 1770 Location: Newmarket, ON
christine72 Samba Member
Joined: August 31, 2014 Posts: 84 Location: Portland, Oregon
Posted: Fri Jul 29, 2016 5:42 pm Post subject: Re: What did you do for your Bay recently? |
A bunch of little things.
Best part - installed auxiliary battery charging relay.
Located a bay being parted out and picked up these OEM items in great condition.
Replace Dash vents to replace my crumbling and marred ones. Fresh air and heat vent covers(not shown).
Replaced door handles with cracked brackets for solid ones.
Replace cracked turn signal lenses with OEM (Hella) like new ones (not shown).
Replaced peeling and broken cab kick panels with solid ones covered in a thick faus black leather vinyl. Looks great!. Doubt these are OEM, no wiper reservoir sticker)
Replaced the catch that wasn't securing the camper table. Hope it works out. Had to pile crap against before, it to keep it from banging down the road. _________________ '74 Bay - ASI camper body w/'72 Bay - undercarriage and a '76 2000cc rebuilt engine
Past VWs
1967 Fastback (my first car); 1971 Square back; Several Jettas '88 -'97
The one I regret not buying:
72 Karmann Ghia, with autostick. |
Posted: Fri Jul 29, 2016 5:46 pm Post subject: Re: What did you do for your Bay recently? |
captincanuck wrote: |
Insulation and PVC foam headliner (door panels are also carpeted PVC foam) |
Looks nice!
Where did you get the headliner? Was it pre-cut/scored or do you have a pattern? _________________ '74 Bay - ASI camper body w/'72 Bay - undercarriage and a '76 2000cc rebuilt engine
Past VWs
rottenkid Samba Member
Joined: June 19, 2015 Posts: 236 Location: Warkworth, ontario
Posted: Fri Jul 29, 2016 6:15 pm Post subject: Re: What did you do for your Bay recently? |
I know someone that would like a headliner like that one. Is there a pattern for the headliner. |
obieoberstar Samba Member
Posted: Sat Jul 30, 2016 12:13 pm Post subject: Re: What did you do for your Bay recently? |
x2
Awesome headliner. I am looking for something similar. Initially considered using some ABS sheeting like the Werksberg panels, but finding it locally is proving to be difficult.
More info on this pvc foam sheeting please... |
iratehippie Samba Member
Joined: April 21, 2002 Posts: 401 Location: high on southern oregon mountaintop...
Posted: Wed Aug 03, 2016 9:19 am Post subject: Re: What did you do for your Bay recently? |
Replaced the fuel tank fill hose. _________________ 1972 westy
Type IV 1700/w Prog. Weber
"Tune in, Turn On, Dropout", Idiots school of VW Philosophy |
kile11 Samba Member
Posted: Wed Aug 03, 2016 6:57 pm Post subject: Re: What did you do for your Bay recently? |
Hi,
My temp sensor II wire was messed up so I put in some new wire, but it runs horrible and dies often. Is there a certain type of wire that I should be using that sends a more accurate signal? |
Posted: Wed Aug 03, 2016 7:27 pm Post subject: Re: What did you do for your Bay recently? |
obieoberstar wrote: |
x2
The PVC sheet was from a local plastic supply store (P&A Plastic). My mom was in the sign business and this is where she would get coroplast, acrylic sheets, lexen and the like. Maybe a Google of "plastic supplies" in your area would turn up something. Just ask is they have PVC foam sheets in white (I think this was 3mm).
No pattern, just traced the old one (which was already a copy of the original one) and cut it with an exacto knife. Still needs a little trim where it meets up with the paneling, but it should outlast the bus.
It also makes fantastic kick panels _________________ 1979 Westfalia "FireFly" Subaru 2.2 with Subaru gears 5spd.
Build Thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=634777&postdays=0&postorder=asc&start=0 |
Posted: Wed Aug 03, 2016 7:45 pm Post subject: Re: What did you do for your Bay recently? |
Thank you Captain for the info. I will see what is available in my area.
Maybe 2 years ago I cut new baltic birch sheets and glued on some nice headliner material from GoWesty. Sadly the glue has not held up on some pieces and am looking for a 'one-piece' solution for the long haul. |
dillon70 Samba Member
Joined: October 20, 2008 Posts: 234 Location: Ventura, Ca.
Posted: Mon Aug 08, 2016 1:07 pm Post subject: Re: What did you do for your Bay recently? |
Installed my Billet throttle cable roller. Pedal is like butter now:)
Before:
After:
MaddMatt Samba Member
Joined: April 25, 2009 Posts: 269 Location: tucson arizona
Posted: Wed Aug 10, 2016 9:54 am Post subject: Re: What did you do for your Bay recently? |
I just installed a stock exhaust on my 71. I have never had a stock exhaust before. Every VW I've ever owned has had an aftermarket exhaust on it when I've bought it.
I CANNOT BELIEVE THE DIFFERENCE.
If you are running a stock engine, run a stock exhaust. _________________ It will make it. Trust me.
Owned: 71 Superbeetle, 72 Superbeetle, 63 Baja (on 69 pan) 74 baja, 74 Karmann Ghia
Own: 71 Deluxe Bus |
Colonel Mosby Samba Member
Joined: February 23, 2014 Posts: 253 Location: Warrenton, VA
Posted: Fri Aug 19, 2016 10:47 am Post subject: Re: What did you do for your Bay recently? |
I set up my bus tent. Took 20 minutes. It is huge. Can't wait to go camping.
[/img] |
