Globespotter Samba Member
Joined: February 16, 2012 Posts: 1765 Location: Newmarket, ON
sean14538 Samba Member
Joined: June 03, 2014 Posts: 161 Location: West Jefferson, OH
dillon70 Samba Member
Joined: October 20, 2008 Posts: 234 Location: Ventura, Ca.
Posted: Sun Jun 12, 2016 9:33 pm Post subject: Re: What did you do for your Bay recently? |
Just ordered my new 1835 and freeway flyer from Wright Gearbox. I'm freakin stoked and can't wait to post some pics, in approx. 3 weeks...... |
secretsubmariner Champagne Wrangler
Joined: January 08, 2011 Posts: 3104 Location: Tulsa, OK
Posted: Mon Jun 20, 2016 12:23 pm Post subject: Re: What did you do for your Bay recently? |
sean14538 wrote: |
Started working on the front cab floor, Sound deadening and carpet. I think it is going to look good!
Hell yeah dude! What's that stuff called? I like it. _________________ -Tony
ᏣᎳᎩᎯ ᎠᏰᎵ
1978 Champagne Edition Bus FI
1970 Auto Fastback FI |
Posted: Mon Jun 20, 2016 12:38 pm Post subject: Re: What did you do for your Bay recently? |
Peal and seal, quick roof, etc etc, it is 17.50 at the local store for a roll
secretsubmariner wrote: |
sean14538 wrote: |
Hell yeah dude! What's that stuff called? I like it. |
_________________ '71 Westy - 1600cc
Build Thread:
http://www.thesamba.com/vw/forum/viewtopic.php?t=631317
How to post photos:
Tcash Samba Member
Posted: Mon Jun 20, 2016 1:43 pm Post subject: Re: What did you do for your Bay recently? |
sean14538 wrote: |
Started working on the front cab floor, Sound deadening and carpet. I think it is going to look good! ☮ ✌ |
Once you get it cut to size. You can take it to an upholstery shop and have the carpet edged.
Or home supply stores have glue on carpet edging (binding)
It finishes it of nicely.
Good luck
Tcash |
justcruzin Samba Member
Joined: July 31, 2005 Posts: 1493 Location: United States
notchboy Samba Member
Joined: April 27, 2002 Posts: 22416 Location: Escondido CA
Posted: Thu Jun 23, 2016 9:07 pm Post subject: Re: What did you do for your Bay recently? |
justcruzin wrote: |
Made a new sticker for it. Now just to fill it up.
t3kg wrote: |
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
SamboSamba22 Samba Member
Joined: August 06, 2015 Posts: 2772 Location: Benton, Arkansas
Posted: Fri Jun 24, 2016 10:48 am Post subject: Re: What did you do for your Bay recently? |
Globespotter wrote: |
Think I found the leak in my windshield seal. Gap at top where the rain gutter water flows. Siliconed it on both sides, and crossing fingers.
Also crawled under the Westy and good and bad news. The good news is that the heater flaps seem to work fine. The bad news is that the cable(s) from the dash are not connected to the flaps, nor do they seem to move properly. Guess it's time for new cables. How hard are they to do? Does the one cable open both flaps?
Tried to adjust the clutch, but can't easily get to the wingnut. Is there an easy way to do it? I don't have a hoist. |
Best luck I’ve had adjusting clutch cables, with the wing nut being very difficult to maneuver is using a pair of needle nose pliers. It’s still a pain, but if my monkey hands can get in there, it can be done! _________________ The Bus Barn Ltd. Co.
Oct. ’67 Double Cab (’68 Crew Cab)
[url=http://www.vw-mplate.com/mplate-44412.png]Click to view image[/URL]
March '69 Delivery (Panel Bus)
[url=http://www.vw-mplate.com/mplate-44414.png]Click to view image[/URL] |
Posted: Fri Jun 24, 2016 11:46 am Post subject: Re: What did you do for your Bay recently? |
sean14538 wrote: |
Peal and seal, quick roof, etc etc, it is 17.50 at the local store for a roll |
Thanks! _________________ -Tony
ᏣᎳᎩᎯ ᎠᏰᎵ
Posted: Sat Jun 25, 2016 8:25 pm Post subject: Re: What did you do for your Bay recently? |
Just picked up my bus today from The Wright Gearbox with a newly installed 1835cc paired with a freeway flyer. Rick does great work. That dude is 100% legit!!
christine72 Samba Member
Joined: August 31, 2014 Posts: 84 Location: Portland, Oregon
Posted: Sun Jul 03, 2016 11:24 pm Post subject: Re: What did you do for your Bay recently? |
sean14538 wrote: |
Quick Roof made a world of difference quieting the ride in my bus. I also put it over rear floor and behind the zbed. Smaller coverage on the doors too. _________________ '74 Bay - ASI camper body w/'72 Bay - undercarriage and a '76 2000cc rebuilt engine
Past VWs
1967 Fastback (my first car); 1971 Square back; Several Jettas '88 -'97
The one I regret not buying:
72 Karmann Ghia, with autostick. |
Posted: Sun Jul 03, 2016 11:52 pm Post subject: Re: What did you do for your Bay recently? |
Replaced fuel filler neck. Completely eliminated Gas odors inside the bus.
Bleeding, peeling pinstripes removed. Rubbed out the stains and waxed.
Touch up paint: front edge of slider and rear edge of driver doors chipped and rusted. Also other chips, etc. Looks great. Perfect colormatch. No pictures, forgot the before and afters.
Past VWs
cdennisg Samba Member
Joined: November 02, 2004 Posts: 20230 Location: Sandpoint, ID
Posted: Mon Jul 04, 2016 1:02 pm Post subject: Re: What did you do for your Bay recently? |
SamboSamba22 wrote: |
Best luck I’ve had adjusting clutch cables, with the wing nut being very difficult to maneuver is using a pair of needle nose pliers. It’s still a pain, but if my monkey hands can get in there, it can be done! |
Thanks! |
IF you can get a drop of oil on the cable threads it will help. Then use the vise grips to clamp the base of the threaded cable end, it will keep the cable from spinning. I like to use along pry bar from below the bus to take tension off the cable by prying the clutch lever forward, then spin the wingnut with my other hand. _________________ nothing |
Tcash Samba Member
wcfvw69 Samba Purist
Posted: Mon Jul 04, 2016 3:31 pm Post subject: Re: What did you do for your Bay recently? |
Another method that will work is using the vise grips to keep the cable from spinning as mentioned and then a small crescent wrench, tightened down on one of the two wings of the wing nut to turn it. If the wing nut is froze, the leverage on the crescent wrench handle helps to move it. _________________ Contact me at [email protected]
The Samba member since 2004.
FlatfourFrenchy Samba Member
Joined: March 13, 2013 Posts: 297 Location: Boonville, MO
Posted: Fri Jul 08, 2016 3:15 am Post subject: Re: What did you do for your Bay recently? |
I drove it for the first time. It all started about 4 years ago when I found it in a field, sunk down about 6 inches into the ground. One of the best feelings rolling down the street in my 71 that I brought back from the dead.
_________________ 1971 Tin Top Westy Campmobile 70 |
