richardandtory Samba Member
Joined: November 01, 2014 Posts: 9 Location: Bath, UK
Posted: Mon May 16, 2016 12:30 pm Post subject: Re: What did you do for your Bay recently? |
wet_bread wrote: |
richardandtory, your photos look like modern version of the '70s advertising. "Home is where you park it." Thanks for sharing! And keep up the good work. - Walter |
Thanks Walter! |
sean14538 Samba Member
Joined: June 03, 2014 Posts: 161 Location: West Jefferson, OH
Posted: Mon May 16, 2016 5:25 pm Post subject: Re: What did you do for your Bay recently? |
Thrasher22 wrote: |
sean14538 wrote: |
I was refering more to the vinyl refresh and crack repairs, but you right that I painted the metal too...will have to see |
That looks fantastic. Did you re-vinyl the dash, or are you just really good at crack repairs? |
Thank you! I sprayed it with adhesive promoter and black vinyl paint. The cracks that were there, one pretty good one and a few minors I fixed with
epoxy putty. _________________ '71 Westy - 1600cc
Build Thread:
http://www.thesamba.com/vw/forum/viewtopic.php?t=631317
How to post photos:
pitbug Samba Member
Joined: May 10, 2010 Posts: 549 Location: San Angelo, Tejas
Posted: Wed May 18, 2016 6:06 am Post subject: Re: What did you do for your Bay recently? |
So over the winter/spring I've have my tranny replaced with Rancho FF, and a makeover with fresh paint, fresh yellow tint and airbrush art work, I wanted to go old skol), I like the way it turned out, the front is for fun, the rear is for relaxing.
not easy to see the yellow tint.
Driver side door
Passenger side
Rear relaxing hatch
_________________ 71' Bus "Sunshine"
68 Eriba Puck!! |
khalimadeath Samba Member
Posted: Thu May 19, 2016 3:35 pm Post subject: Re: What did you do for your Bay recently? |
Wired up a stereo. Works perfect, looks great.
hiraxx Samba Member
Joined: October 22, 2015 Posts: 41 Location: Philippines
Posted: Thu May 19, 2016 5:06 pm Post subject: Re: What did you do for your Bay recently? |
just sharing.
3 Amigos Racing Samba Member
Joined: February 16, 2014 Posts: 58 Location: Phoenix
Posted: Sun May 22, 2016 12:13 pm Post subject: Re: What did you do for your Bay recently? |
Front end complete renew end to end, every bolt, seal bearing, snubbers, steering assembly, ball joints, tie rods, shocks, brakes blah blah..
onurenka Samba Member
Posted: Sun May 22, 2016 2:58 pm Post subject: Re: What did you do for your Bay recently? |
Brought it out to see the sun.
FlatfourFrenchy Samba Member
Joined: March 13, 2013 Posts: 297 Location: Boonville, MO
Posted: Mon May 23, 2016 6:50 am Post subject: Re: What did you do for your Bay recently? |
I found a $2.00 high/low headlamp relay at the MOKAN car show/swap and now I have new headlights shining brightly. I work on cars for a living and fix headlights regularly but when they have not been on in 25 years it is kinda special. For me anyhow.
_________________ 1971 Tin Top Westy Campmobile 70 |
Jalabert Samba Member
Joined: December 06, 2005 Posts: 631 Location: On the coast in NZ, somewhere...
Posted: Thu May 26, 2016 3:11 pm Post subject: Re: What did you do for your Bay recently? |
Sweet work, pitbug. Love this thread, so many random bits of inspiration - even if they wouldn't fit my bus. _________________ http://thickrubber.blogspot.com/ Writing, Surfing, and Exploring NZ's deep south by VW...
'73 westy, 1700 type 4 with 34icts |
Trashman Samba Member
Joined: May 18, 2016 Posts: 280 Location: Santa Cruz, CA
Posted: Fri May 27, 2016 2:01 pm Post subject: Re: What did you do for your Bay recently? |
I rekeyed all the locks on my bus to use the same key. Got a key that matched the code on all the locks but the PO had messed with the tumblers so I had to change all of that up.
Also, I started scraping off all rattle can primer overspray that the PO got on all the windows. Next is to take some oven cleaner to the primer on the body to take it down to the OG neptune blue. _________________ Bagged 1968 Neptune Blue "Deluxe" |
Posted: Sun May 29, 2016 10:50 am Post subject: Re: What did you do for your Bay recently? |
I started cleaning the inside of my bus today for the first time ever. All I did here in the picture was sweep the floor. You probably cant tell hahaha. It still needs a good scrub down.
christine72 Samba Member
Joined: August 31, 2014 Posts: 84 Location: Portland, Oregon
Posted: Sun May 29, 2016 12:40 pm Post subject: Re: What did you do for your Bay recently? |
Have been having a slowly escalating slow start issue.
Found that the ground strap from the transmission had loosened; tightened her down and now she turns over immediately.
Also after having locked my keys in the bus many times! I've hooked up the driver door Buzzer/Dome switch.
Something is loose in the ignition switch because the buzz is intermittent and cuts out, so that's on the agenda today. There is also a little bit of play in the ignition switch.
So off I go to tackle that. _________________ '74 Bay - ASI camper body w/'72 Bay - undercarriage and a '76 2000cc rebuilt engine
Past VWs
1967 Fastback (my first car); 1971 Square back; Several Jettas '88 -'97
The one I regret not buying:
72 Karmann Ghia, with autostick. |
zoobum Samba Member
Joined: June 09, 2015 Posts: 211 Location: Los Angeles
Posted: Sun May 29, 2016 1:43 pm Post subject: Re: What did you do for your Bay recently? |
Painting
_________________ -Zach
1979 CA Riviera 2.0L FI |
EricKM Samba Member
Joined: July 23, 2000 Posts: 11 Location: Cardiff, Ca
Posted: Sun May 29, 2016 7:50 pm Post subject: Re: What did you do for your Bay recently? |
Maaco Paint job - not too bad. Re-assembled the doors, windows, trim and slider. I need a beer.
_________________ 77 Kombi Champagne Edition
78 Westfalia Champagne Edition
02 Jetta GLI
08 Golf R32
15 Golf TDI - cleaner than your diesel truck |
Posted: Sun May 29, 2016 8:47 pm Post subject: Re: What did you do for your Bay recently? |
maaco aint bad if you prep it well. |
wcfvw69 Samba Purist
Posted: Sun May 29, 2016 8:55 pm Post subject: Re: What did you do for your Bay recently? |
EricKM wrote: |
That's a great looking bus!
Give us some details. You said Maaco painted it? Did they do the bodywork as well? What's the going rate for a Maaco paint job these days? _________________ Contact me at [email protected]
The Samba member since 2004.
EricKM Samba Member
Posted: Mon May 30, 2016 6:37 am Post subject: Re: What did you do for your Bay recently? |
Thanks! For primer, base coat, clear coat, both colors including the wheels and inside the doors, color sand and polish for $2300. They did some extra stuff including painting POR-15 in the wheel wells. I painted the damn thing 8 years ago and I swear it cost me more to do it (without the countless hours of block sanding). I did remove all the windows, trim (inside and out) and bumpers. The only caution is Maaco taping skills. Not so good. The line between colors is pretty crappy. I left the new windshield and rubber in place and the overspray has taken several hours of work. What do they say? "Roll down the windows and we'll do the interior for free", definitely applies here. Overall I'm very happy for the price though. No garage so I have a cover. See how long the "rust repair" lasts...[/img] _________________ 77 Kombi Champagne Edition
02 Jetta GLI
08 Golf R32
Posted: Mon May 30, 2016 10:01 am Post subject: Re: What did you do for your Bay recently? |
EricKM wrote: |
Thanks! For primer, base coat, clear coat, both colors including the wheels and inside the doors, color sand and polish for $2300. They did some extra stuff including painting POR-15 in the wheel wells. I painted the damn thing 8 years ago and I swear it cost me more to do it (without the countless hours of block sanding). I did remove all the windows, trim (inside and out) and bumpers. The only caution is Maaco taping skills. Not so good. The line between colors is pretty crappy. I left the new windshield and rubber in place and the overspray has taken several hours of work. What do they say? "Roll down the windows and we'll do the interior for free", definitely applies here. Overall I'm very happy for the price though. No garage so I have a cover. See how long the "rust repair" lasts...[/img] |
It's not cheap to paint a VW, even when our labor is free. I spent over $1300 dollars in materials when I painted my 67 bug. I did use the best PPG paint and supplies though. The sand paper, primer, reducer, hardener, masking tape, paint, thinner, etc.. adds up quickly.
Your bus looks great for a $2300 dollar paint job. _________________ Contact me at [email protected]
