Filthy Dub Samba Member
Joined: February 17, 2016 Posts: 65 Location: Jacksonville Beach, Fla.
Posted: Sun Apr 10, 2016 8:38 pm Post subject: Re: What did you do for your Bay recently? |
Couldn't pass up on the beautiful weather this weekend, so I installed a new window channel after removing the old one that had rusted and managed to seal itself to the window. I did salvage the old rubber and now the window goes up and down without getting stuck.
I also replaced the original bowden tube, which proved to be a bit of a bitch. The old one was so rusted and falling apart the clutch cable wouldn't even slide out.
Nothing too flashy, but it's the small stuff! _________________ 1971 Westfalia Bay Window Bus |
jtauxe Samba Member
Joined: September 30, 2004 Posts: 5780 Location: Los Alamos, New Mexico
Posted: Thu Apr 14, 2016 11:35 am Post subject: Re: What did you do for your Bay recently? |
MonkeySee wrote: |
I want to do that dash light LED conversion but don't remember where I saw that. Anyone have that info? |
Just get yourself some of these
https://www.superbrightleds.com/cat/instrument-cluster-gauge/filter/Base_Type,24,1,4336:
and replace the old filament bulbs.
Important note: This works only for the dash illumination, NOT for the idiot lights, which are part of important circuits.
Another important note: Since LEDs are actually diodes, it matter which way they go in, since current flows only one way. It's a 50-50 chance, so if it doesn't work the first time, flip the LED 180 degrees.
Tip: If you get them in red, then the light is easier on the eyes at night. That'w what they use in ships' wheelhouses, and I did it, too, to good effect. They are so cheap, buy a few white and a few red and see for yourself. _________________ John
http://vw.tauxe.net
1979 Champagne Sunroof, 1974 Westfalia Automatic, 1979 Transporter, 1972 Sportsmobile, 1973 Transporter Wild Westerner, 1974 Westfalia parts bus, 1975 Mexican single cab *FOR SALE*, 1978 Irish 4-door double cab RHD
74superTN Samba Member
Joined: April 01, 2007 Posts: 675 Location: Port Saint Lucie, FL
Posted: Thu Apr 14, 2016 2:42 pm Post subject: Re: What did you do for your Bay recently? |
Installed a new passenger and driver side mirror, two new window cranks and just finished regreasing my cv joints and installing new cv boots and bolts. First car show ever will be this weekend! _________________ 73 Thing
80 Vanagon Westy |
scrivyscriv Samba Electrician
Joined: October 04, 2011 Posts: 2922 Location: Memphis
Posted: Thu Apr 14, 2016 3:12 pm Post subject: Re: What did you do for your Bay recently? |
started back on my poor man's CHT special.. i think i'm getting somewhere with it.
_________________ Robert in Memphis
Engine rebuild thread
If you're ever in the Memphis area, you are welcome to stop by for advice and help. |
BerryBus Samba Member
Posted: Sun Apr 17, 2016 7:03 pm Post subject: Re: What did you do for your Bay recently? |
This spring had rubbing/grinding noise in right front wheel. No real play. Pulled drum and Chinese outer bearing race had rough spot and the grease was black. So installed new Timkin outer wheel bearings in the front, Inner bearing seal, repack all and grease the front axle. Inner wheel bearings were Timken, were in excellent shape. Found a zerk missing on left hand side of axle.
Another might as well, pulled the rear heat vent hose and cleaned out; a spring, pennies, bolt, leaves and a piece of flooring. Adjusted cable under seat a little. Now have a little air moving to the back! First time since I had him.
Next, rear brakes, inspect and repack bearings and new master cylinder. The master cylinder is leaking. _________________ 1970 7 Pass/Riviera/Westfalia - Ours
1968 + 1971 Bus Trailer
1991 Porsche 964 C4 Cabriolet - Mine
2005 New Beetle Convertible - Wife
2012 Touareg TDI |
Jalabert Samba Member
Joined: December 06, 2005 Posts: 631 Location: On the coast in NZ, somewhere...
Posted: Sat Apr 23, 2016 11:26 am Post subject: Re: What did you do for your Bay recently? |
Glad to see I'm not the only one having fun with brakes. Weird tinkling noise under braking, so pulled both drums and painted them while I was there. Culprit was the parking brake lever, too much play in it, letting it ride out against the hub. Shimmed it in tight with a c-clip. Put it all back together and taught my son some new swear words wrestling with the star adjusters. Arms feel like I've wrestled a hippo, but on the upside the parking brake is back to being super. _________________ http://thickrubber.blogspot.com/ Writing, Surfing, and Exploring NZ's deep south by VW...
'73 westy, 1700 type 4 with 34icts |
EricKM Samba Member
Joined: July 23, 2000 Posts: 11 Location: Cardiff, Ca
Posted: Tue May 03, 2016 7:01 am Post subject: Re: What did you do for your Bay recently? |
Rebuilt the wing windows. Thank you R Atwell for the excellent tutorial! Been meaning to do this for years, just been putting up with the whistling. My new favorite tool is the pop riveter, by the way. The window post had completely separated from the window but now is tightly attached with three new rivets. This was not a difficult job, just time consuming. Pulled all the rear windows out this past week and did some grinding of rust and minor body work in anticipation of new paint.
http://www.thesamba.com/vw/forum/album_cat.php?cat_id=11
christine72 Samba Member
Joined: August 31, 2014 Posts: 84 Location: Portland, Oregon
Posted: Tue May 03, 2016 11:05 am Post subject: Re: What did you do for your Bay recently? |
Tackled the mildew that covered the top of the pop-up.
Have found that scrubbing it off the sides just brought it back within a few days. Magic Eraser got it off and kept it at bay for months. So, on to the top the of the top:
Before:
Top of image shows progress with hosing it off - not much affect there.
Grey area on the far right shows after scrubbed vigorously with a brush and cleaner. Still not so good.
On the left the white area is where I wiped with a Magic Eraser. No elbow grease required. Remarkable. And keeps the mildew off for months (here in the PacNW)
After
Beautiful. Those black spots in the before pic are tufts of moss. Had to scrape them off for the Magic Eraser to remove those marks too.
_________________ '74 Bay - ASI camper body w/'72 Bay - undercarriage and a '76 2000cc rebuilt engine
Past VWs
1967 Fastback (my first car); 1971 Square back; Several Jettas '88 -'97
The one I regret not buying:
72 Karmann Ghia, with autostick. |
williamM Samba Member
Joined: August 07, 2008 Posts: 4333 Location: southwest Arizona
Posted: Thu May 05, 2016 10:47 am Post subject: Re: What did you do for your Bay recently? |
I changed out the T-1 oil pump for the correct T-4 and parked in front of neighbors house for a pending roof/gutter replacement. next will be to put the Riveria camper kit back in and fire up the coleman heater.
edit- and -- it hasn't rained here in 2 months so just as the transplant is in progress- guess what. _________________ some days I get up and just sit and think. Some days I just sit.
opinion untempered by fact is ignorance.
Don't step in any!
stonecat Samba Member
Joined: December 20, 2012 Posts: 14 Location: Montgomery
Posted: Thu May 05, 2016 12:48 pm Post subject: Re: What did you do for your Bay recently? |
jtauxe, how many LEDs does it take to replace all of the dash lights? I think I'm going to try these on my '78 bus.
jtauxe wrote: |
MonkeySee wrote: |
Tip: If you get them in red, then the light is easier on the eyes at night. That'w what they use in ships' wheelhouses, and I did it, too, to good effect. They are so cheap, buy a few white and a few red and see for yourself. |
Danwvw Samba Member
Posted: Thu May 05, 2016 1:09 pm Post subject: Re: What did you do for your Bay recently? |
I did it on our 1971 Bay Window Bus, Much improved. I left the old incandescent in the Alternator light position as it's part of the alternator charging circuit and part of the fuel pump control circuit but the others are LED's now. Much Brighter too. I can't Remember how many white led's are needed for the back lighting may be 3? But the LED's won't Dim down right when you twist your dimmer knob? But the Two Turn Signal bulbs are nice you don't want supper bright for them or the others but Super brite leds are good for the back ground dash lighting.
_________________ 1960 Beetle And 1679cc DP W-100 & Dual Zeniths! |
skull stitches Samba Member
Posted: Fri May 06, 2016 8:11 pm Post subject: got my 74 running |
removed all the AC weight from my 74 after getting her running after a year of sitting. my son, Link, helped me out polishing up the hubs.
Posted: Sun May 08, 2016 9:47 pm Post subject: Re: What did you do for your Bay recently? |
A few things while camping in Walla Walla this weekend.
1. Drain Valve and hose for the reservoir fell off in my hand. It was gooped on by PO with some kind of clay. So took out the box seat housing the reservoir and got a hose properly clamped on. Took apart and re-conditioned the valve. All good and in working order now!!
2. Installed a replacement for the flip-up table that opens out at the sliding door (for a stove).
3. Accelerator assembly bracket came off one of the carbs while driving down the highway 2 hours from home. While waiting for AAA tow (an hour) that would get me as far as 30 miles from home - found the bolts deep in the engine compartment and got it all re-assembled. Made it the rest of the way home without incident.
An awesome Mothers Day - really. Feeling quite empowered! _________________ '74 Bay - ASI camper body w/'72 Bay - undercarriage and a '76 2000cc rebuilt engine
Past VWs
tootype2crazy Samba Member
Joined: October 08, 2007 Posts: 1276 Location: St. Louis Missouri
Posted: Tue May 10, 2016 7:00 am Post subject: Re: got my 74 running |
skull stitches wrote: |
Awesome! You're getting him started right. Train that next generation of VW lovers. _________________ air-cooled or nothing for me
1978 Sunroof Deluxe Bus (daily driver)
1978 Transporter (mom's, making into a camper)
1970 Single Cab 2.1 turbo/EFI 6 Rib, 78 front beam, vanagon backing plates on rear (project)
2001 GTI VR6 (wife's) |
AircooledHome Samba Member
Joined: October 13, 2015 Posts: 273 Location: California
sean14538 Samba Member
Joined: June 03, 2014 Posts: 161 Location: West Jefferson, OH
khalimadeath Samba Member
3 Amigos Racing Samba Member
Joined: February 16, 2014 Posts: 58 Location: Phoenix
Posted: Thu May 12, 2016 3:24 pm Post subject: Re: What did you do for your Bay recently? |
Front beam end to end rebuild and renew. Every piece removed, inspected, renewed and re painted and reinstalled. $$ costly but tight as new. Ball joints, tie rods, wheel bearings brakes.etc the whole thing. Topped with an empi sway bar. Heading to the rear next week. |
busboytom Samba Member
Joined: October 23, 2015 Posts: 19 Location: Western Wisconsin
Posted: Thu May 12, 2016 8:11 pm Post subject: Re: What did you do for your Bay recently? |
I had nothing to do with this except pay the bill....old vanagon seats now with appropriate plaid to go into the 77 Westy. A wise old man once said "son, you better have a comfortable bed, shoes and a place to sit, cause you're gonna be in one of em all the time". Now extended Roadtrip ready! Just had new front whell arches welded in too. Parts were more than an inch different from right to left.
_________________ 77 Westfalia w/Sears trailer 179kmi 2.0L FI
68 Westy Sportmobile (saved from salvage)
71 T3 Squareback 54Kmi 1.6L FI |
snallygaster Samba Member
Joined: May 31, 2014 Posts: 8 Location: United States
Posted: Thu May 12, 2016 9:01 pm Post subject: |
California Westy wrote: |
I threw a rock at it!!! |
Was it an OG rock or Chinese aftermarket? _________________ ++++++++++
"Daylee" the '75 Sunroof Transporter
Totally stock and OG
('cept for the Mexican hubcaps and 80s radio).
White on Ceylon Beige
Western Connecticut |
