Bruce Samba Member
Joined: May 16, 2003 Posts: 17273 Location: Left coast, Canada
Posted: Fri Jul 01, 2016 12:33 am Post subject: Re: GL 4 or GL 5 - "Official Gear Lube Topic" |
Wildthings wrote: |
It is rather pointless to say you "switch to GL-5" unless you specify which oil you switched to as many GL-5 oils give considerably worse shifting. You should also say what oil you switched from. |
Just as pointless as you saying "many GL-5 oils give considerably worse shifting." without stating exactly which brands of oil you think are inferior.
I recently started driving a car I've owned for many years but was stored the whole time. The gearbox has very low mileage on it, and even less on the GL-4 the PO put in it. The shifting was so bad I contemplated having to do a rebuild on the trans. The force to get it into each gear was quite high, and 1st gear synchro was completely ineffective.
I decided to change out the low mileage GL-4. I gathered up all the mixed brand oil I had and put it in. 1 qt of Pennzoil 80W-90, half a qt of Castrol 80W-90, and 1 qt of Royal Purple 75W-90. All GL-5 of course.
On the very first shift into 2nd I could immediately tell it was much better. Overall, I would say it now takes about 1/3 of the effort to shift. The synchros work so much better, including the suspected bad 1st gear synchro.
So much for your claim of GL-5 shifting bad and GL-4 being good. _________________
Posted: Fri Jul 01, 2016 3:50 am Post subject: Re: GL 4 or GL 5 - "Official Gear Lube Topic" |
Did you bother to read the note half way down the page on your second link?
"MTL, MT-85 & MT-90 are not for use in differentials with hypoid gears" |
Sandbar Norm Samba Member
Joined: August 02, 2008 Posts: 115 Location: A Sandbar in Fl.
Posted: Fri Jul 01, 2016 6:06 am Post subject: Re: GL 4 or GL 5 - "Official Gear Lube Topic" |
Wildthings wrote: |
Well that makes it easy to choose. |
udidwht Samba Member
Joined: March 06, 2005 Posts: 3777 Location: Seattle, WA./ HB, Ca./ Shizuoka, Japan
Posted: Mon Sep 12, 2016 9:34 am Post subject: Re: GL 4 or GL 5 - "Official Gear Lube Topic" |
Have only run this since rebuilding the trans years ago. No problems.
http://www.amsoil.com/shop/by-product/gear-lube/synthetic-80w-90-gear-lube/?code=AGLQT-EA _________________ 1972 Westy Hardtop/Type-4 2056cc
96mm Biral AA P/C's~7.8:1CR
71mm Stroke
73 Web Cam w/Web solids
Bosch W8CC plugs
S&S 4-1 w/Walker QP 17862
3 rib 002 Trans
185R14 Hankook tires |
srfndoc Samba Member
Posted: Thu Oct 06, 2016 8:45 am Post subject: Re: GL 4 or GL 5 - "Official Gear Lube Topic" |
Been using this for 4 years on a new transmission with no issues:
_________________ RPM=(MPH*336* (R&P*4th*1.26))/Tire Diameter in inches |
modok Samba Member
Joined: October 30, 2009 Posts: 26740 Location: Colorado Springs
Posted: Thu Oct 06, 2016 6:18 pm Post subject: Re: GL 4 or GL 5 - "Official Gear Lube Topic" |
yeah, it works, but it works better with the right oil.
It says right on the front, it's intended for if you have a limited slip syncros. |
neil68 Samba Member
Joined: March 17, 2007 Posts: 3440 Location: Calgary, Canada
Posted: Thu Oct 06, 2016 8:20 pm Post subject: Re: GL 4 or GL 5 - "Official Gear Lube Topic" |
Valvoline™ High Performance Gear Oil is a high quality lubricant to keep your vehicle running in great condition and avoid loss of corrosion protection.
Additional product benefits include:
-Outstanding thermal stability for cleanliness and longer service life
-Reduced chattering in limited-slip differentials
-Gear teeth wear protection from pitting and scouring
-All hypoid differentials (conventional and limited slip) and manual transmissions in passenger cars, light trucks, sport utility vehicles, vans and heavy-duty trucks where an API-GL5 or MT-1 fluid is specified. _________________ Neil.
Der Kleiner Rennwagens
68 Beetle 2332 cc, 204 WHP
12.5 seconds @ 107 mph
Dynojet Test: https://www.youtube.com/watch?v=M9B_H3eklAo |
fivelugshortaxle Samba Member
Joined: May 13, 2011 Posts: 4254 Location: Aumsville, Oregon
Posted: Sat Oct 08, 2016 8:12 pm Post subject: Re: GL 4 or GL 5 - "Official Gear Lube Topic" |
neil68 wrote: |
-All hypoid differentials (conventional and limited slip) and manual transmissions in passenger cars, light trucks, sport utility vehicles, vans and heavy-duty trucks where an API-GL5 or MT-1 fluid is specified. |
Neil....what do you use in your transaxle? About to fill my new Rancho box and shove it in the 68 tomorrow. What do you recommend? My 68 will be street/strip.....built 2276. Built Rancho transaxle. _________________ Good things come to those who wait.
2332 with lots of goodies....
Rotating assembly balanced by Brothers VW
4340 84mm crank
AA 94mm p&c' s
Total seal 2nd ring, rest are Grants
5.5 h beams
Magnum straight cuts
Steve Long XR310 on a 106
CB 1.4 rockers
CB Magnaspark 2 distributor
NGK D7ea plugs
A1 lowdown 1 3/4 with single muffler
Dellorto 48's with 40 venturies
Kennedy Stage 2 with Daiken disc |
neil68 Samba Member
Posted: Sat Oct 08, 2016 10:10 pm Post subject: Re: GL 4 or GL 5 - "Official Gear Lube Topic" |
I use 75W90 GL5 synthetic, but you might be able to use 80W90 in your location (I've been through there many times ).
I use whatever my FLAPS has on the shelf: Motomaster currently, but Valvoline before that, and Castrol. I like the improved shifting with synthetic and GL5 protection at the race track, but also because of our fluctuating weather up here:
Posted: Sun Oct 09, 2016 7:29 am Post subject: Re: GL 4 or GL 5 - "Official Gear Lube Topic" |
neil68 wrote: |
Thanks _________________ Good things come to those who wait.
4340 84mm crank
AA 94mm p&c' s
5.5 h beams
CB 1.4 rockers
NGK D7ea plugs
Posted: Tue Oct 11, 2016 3:35 pm Post subject: Re: GL 4 or GL 5 - "Official Gear Lube Topic" |
modok wrote: |
As mentioned by neil68, it supports both conventional and limited slip differentials. _________________ RPM=(MPH*336* (R&P*4th*1.26))/Tire Diameter in inches |
modok Samba Member
PopPop Jambon Samba Member
Joined: November 23, 2016 Posts: 125 Location: Florida
Posted: Tue Dec 20, 2016 8:48 am Post subject: Re: GL 4 or GL 5 - "Official Gear Lube Topic" |
54 pages of "No GL-4, Yes GL-4, No GL-5, Yes GL-5" and still going strong. |
60ragtop Bonneville Belt Bitch
Joined: March 13, 2006 Posts: 7800 Location: Big Wonderful WYO 82401
Posted: Wed Dec 21, 2016 11:53 am Post subject: Re: GL 4 or GL 5 - "Official Gear Lube Topic" |
Better not go anywhere near the oil thread then _________________ Rick
Certified Mechanic by the State of Michigan in 1977
ASA certified in 1987
Certified Hunter Wheel Alignment Master Technician 1986
tasb wrote: |
I've restored a large number too, but I don't toot my horn quite as loud.
sb001 wrote: |
maybe he just snapped cause his car sucked |
Busfixer Samba Member
Joined: March 13, 2016 Posts: 25 Location: Midland, Texas
Posted: Mon Jan 02, 2017 5:38 pm Post subject: Re: GL 4 or GL 5 - "Official Gear Lube Topic" |
Hello this is Busfixer. I have 40 yrs experience working on bugs and buses, all my own or family owned. When I rebuilt my son's 1978 Camper equipped with factory 091 4 speed, I simply drained and replaced the GL4 fluid with modern Mobil 1 GL5 synthetic gear oil. The original transmission was not rebuilt because it worked perfectly. Sounds logical, doesn't it?
Empirical data many times trumps laboratory data due to unknown factors. For some unknown reason, my son's 1978 091 started whining in 2nd and 3rd gear with the GL5 fluid in it after 5 years. I told him to drain the fluid and he found brass shavings and particles in the fluid. Had him fill it with Royal Purple GL5 but too late.
The 091 is now rebuilt by a well known shop and the main shaft was replaced. However, the empirical evidence of brass/bronze shavings remains and I can't help thinking the GL5 contributed greatly to this.
We will use Amzoil 75W-90 GL4 in the new transmission which I have no doubt will preserve all gears and synchronizers with the stock engine. If you have a stock or warmed over engine, use GL4. If you have a hot rod VW, use GL5 or the best you can get and forget about synchronizer life - save the gears with extreme pressure lubricant. Take it or leave it - Busfixer |
Danwvw Samba Member
Posted: Mon Jan 02, 2017 5:57 pm Post subject: Re: GL 4 or GL 5 - "Official Gear Lube Topic" |
I had one getting a lot of silver in it. But don't think it had anything to do with the fluid, I think it's probably because the gear adjustments or ring & pinion setups are not set properly. _________________ 1960 Beetle And 1679cc DP W-100 & Dual Zeniths! |
Krochus Samba Member
Joined: January 01, 2017 Posts: 892 Location: NW Arkansas
Posted: Tue Jan 10, 2017 5:22 pm Post subject: Re: GL 4 or GL 5 - "Official Gear Lube Topic" |
In the Jeep community where the yellow metal synchros were a concern many of us swapped to 15/40 rotella motor oil with completely satisfactory results
And in fact it became recommended by mopar as I recall |
scottyrocks Samba Member
Joined: August 19, 2016 Posts: 2645 Location: Long Island, NY
Posted: Tue Feb 28, 2017 7:38 pm Post subject: Re: GL 4 or GL 5 - "Official Gear Lube Topic" |
Holy guacamole, what a thread.
54 pages over almost 9 years, and it took until about page 53 to get close to what many of us who own stock, older VWs might want to know – what to use in our 40 (or 36) hp monsters.
So many of you have written anecdotes that say 'I used GL5 this or GL4 that,' but there is little in the way of brands or any other info mentioned for others to narrow down what's good and what's bad, as we now all know that not all GL4s and 5s are all good and/or bad (did I cover all the bases?).
And when a product is mentioned, sometimes I have read how good something is (i.e. - Redline), and then someone else comes along and tears it a new anal aperture (i.e. - separation of additives from base).
So what I have been able to garnish (thus far) is that I want something as close in formulation as possible to what Volkswagen put in my Type 1 transaxle. I'm not worried about 40 rip-roaring hp and non-hypoid gears tearing up my R&P. I will assume what I want is a GL4 which will, coincidentally, not cause me worry about corroding or peeling yellow metal parts.
I want my smooth shifting to stay smooth. What brand and designation/other info/'model' of gear oil is closest to the VW stuff and/or will fulfill my wants and needs?
Thanks. |
modok Samba Member
Posted: Tue Feb 28, 2017 9:31 pm Post subject: Re: GL 4 or GL 5 - "Official Gear Lube Topic" |
Napa sells "stay lube" brand gl4, it's the only gl4 on the shelf of any place in town.
I don't expect that it would be great, but it's probably more than adequate to work in place of what VW put in there.
I think if you wanted a particular brand of gl4 oil you could do it, but it might be special order, or from overseas. I like valvoline, so, http://valvolinebulgaria.bg/dev/en/products/transm...75w-90.php
Why is it only sold in europe? Conspiracy? |
vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15279 Location: Deep in the 405
Posted: Wed Mar 01, 2017 4:08 am Post subject: Re: GL 4 or GL 5 - "Official Gear Lube Topic" |
The GL-5 myth that it eats yellow metals was a problem from 20 years ago that just has not gone away. Notice how in these 54 pages there are no pictures of parts that are eaten up.
I have run GL5 Valvoline Durablend gear oil for 20 years and have never had the internal parts eaten up by chemicals. _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
Featured in Dec. 2001 HOT VW's Magazine page 63
Watch my racing video's http://www.youtube.com/user/okvwracer/videos |
