Melville Engineering steel and pipe 54' rhd single
Page: Previous  1, 2, 3 ... 7, 8, 9 ... 14, 15, 16  Next
bigbulli
bigbulli is offline
PostPosted: Wed Sep 16, 2015 2:37 pm    Post subject: Reply with quote
Thanks Todd!
1954 Barndoor
1955 Oval
zuggbug
zuggbug is offline
PostPosted: Wed Sep 16, 2015 5:59 pm    Post subject: Reply with quote
You have raised the bar Todd. Outstanding.
SOUTHERN INTEGRITY AIRCOOLERS
58 15 window
56 westy
thezombikiller
thezombikiller is offline
PostPosted: Thu Sep 17, 2015 5:14 am    Post subject: Reply with quote
Very nice work. Nice find on the brake shoes too
60 SO 23
youtube channel
Shop blog
npbusguy
npbusguy is offline
PostPosted: Wed Oct 14, 2015 9:42 am    Post subject: Reply with quote
Sweet! Perhaps the best update out of nowhere that I have seen.
vdouglu
vdouglu is offline
PostPosted: Wed Oct 14, 2015 10:14 pm    Post subject: Reply with quote
gatorwyatt wrote:
This is a fun fact. After different cross matching part numbers the front shoes for barndoor brakes are the same as Porsche 944 for the late 70's to early 80's rear. One hole needs to be drilled for a spring but other than that they fit.
Even more fun facts ... they are the same as Super Beetle and Thing rears.... Wink with the need to drill out the same hole. I've bought them for $10 a set and worked great on my bus... Cool
Great job on the bus! Looking good! Very Happy
Brian_1952
Brian_1952 is offline
PostPosted: Fri Oct 16, 2015 3:01 pm    Post subject: Reply with quote
gatorwyatt wrote:
Had to remove the original bushings for the upper shock mounts because the bolts were cross threaded and coarse thread all thread.
Had new bushings made and welded in by a local machine shop friend. Yes, the detail for the original upper shock lock washer in the outer portion was missed. Oh well.
Original / glass bead
Ballotini glass beads in AE grade provide this type surface. No they were not " vapor blasted"
Powder coated in satin black
Yellow zinc / clear zinc / black nickel plating
After boiling in transmission fluid I got the Pistons to come out and the original cylinders had some minor pitting. I honed the pits clean and found some rubber kits on eBay.
Plated in yellow zinc while I was at it.
First I would like to say amazing job And I thought that was funny that you use my words "fun facts"
(20-024785)Ambulance (20-037784)truck (20-035850)panel
(20-035778)kombi
WANTED 52 parts and NOS sheet-metal
gatorwyatt
gatorwyatt is offline
PostPosted: Sat Oct 17, 2015 8:15 am    Post subject: Reply with quote
I felt I needed to carry on the tradition, Brian. Keep your "Fun Facts" post coming. Always like them.
Thanks for all the kind works fellas. The transaxle is next...
www.blastserv.com
wanted:
RHD Barndoor floor mat..reproduction is fine
gatorwyatt
PostPosted: Fri Nov 27, 2015 6:26 am    Post subject: Re: Melville Engineering steel and pipe 54' rhd single Reply with quote
Did a cleanup on the steering box. You can see these boxes are date coded like most of the mechanical parts are. Mine is dated 9/54 which makes it 2 months prior to production of the truck (11/54). It is stamped on the flat area where the tube meets the casting.
Degreased in parts washer, glass beads for general cleanup, masked the seal surfaces and used a mild abrasive on entire box for adhesion and followed with a satin black powder coat.
Plater has hardware at the moment.
Paper gaskets don't seem to be easy acquire. May have to make one.
www.blastserv.com
wanted:
Brian_1952
PostPosted: Sat Nov 28, 2015 3:45 am    Post subject: Re: Melville Engineering steel and pipe 54' rhd single Reply with quote
I have seen them on here for sale I actually he didn't know what they were four at first I believe
(20-035778)kombi
kalymnos Premium Member
kalymnos is offline
PostPosted: Sat Nov 28, 2015 7:25 am    Post subject: Re: Melville Engineering steel and pipe 54' rhd single Reply with quote
And 17.7.54 [July, 17th 1954] date of molding or cast; cool
scvw
scvw is offline
PostPosted: Sat Nov 28, 2015 9:22 am    Post subject: Re: Melville Engineering steel and pipe 54' rhd single Reply with quote
I can tell this is gonna be good. What condition was the pin in?
58 Coral Red ragtop(Diana's car)
57 PG/SG standard
63 Ruby Red SC
WTB - Sigla popout glass like in my ad.
http://www.thesamba.com/vw/classifieds/detail.php?id=1667775
exotic plants
exotic plants is offline
PostPosted: Sat Nov 28, 2015 9:43 am    Post subject: Re: Melville Engineering steel and pipe 54' rhd single Reply with quote
Pure bad ass work man!
1956 Beetle - Jungle Green.
Parts needed to complete:
Front driver side fender.
Rear driver side fender.
Cash waiting.
gatorwyatt
PostPosted: Sat Nov 28, 2015 9:44 am    Post subject: Re: Melville Engineering steel and pipe 54' rhd single Reply with quote
Assuming you are talking about on the end of the shaft...it was in great shape. The box obviously has low miles on it. The entire front end was in good shape just old and neglected. I am even restoring both tie rods and drag link because they are tight and smooth.
www.blastserv.com
wanted:
gatorwyatt
PostPosted: Sat Jan 30, 2016 6:03 am    Post subject: Re: Melville Engineering steel and pipe 54' rhd single Reply with quote
It was time to make another stab at progress and prepping the already completed messed up welding seemed moving backwards but it's the right direction. I removed all of the rest of the misc hardware and bolts still in the under side. Since the truck is going to be blended (at this point) I blasted the new metal and the underside only.
Loading in booth
I would never agree to this set up for a customer. Blasting a bus is the most extensive type of blasting with all the cross members and blind areas. Then add a single cab it has a twice the cross members. A rotisserie is always required when we shoot the underside but for my situation and being I own the business I bent my own rule. Needless to say it was not fun but, my main man AJ did it without one complaint.
It's unfortunate that the whole left side will have to be removed in order to index the gate holes properly. I Removed all the green lacquer primer and once all the blasting was complete the entire underside and all replacement metal was applied with phosphoric acid. This is a step most commonly messed up on. The general thought is to blast metal and quickly cover it with epoxy. The problem is epoxy dries hard as nails with in its overcoat window of typically 72 hrs. So once it dries it needs to be sanded vigourasly to get your sandable primer to adhere. With the business I am in and the amount of high traffic work we do, we usually find that the professionals do the steps the way we profess to. Blast to white metal > apply phosphoric acid > metal work stage (cut grind weld) > chemical clean and prep > apply epoxy primer > directly on wet epoxy apply sandable primer > do filler and skim coats. If you disagree just read the spec sheets made by the manufactures of the chemicals.
The worst part ever... Phosphoric acid application.
Next step....
www.blastserv.com
wanted:
scvw
scvw is offline
PostPosted: Sat Jan 30, 2016 9:48 am    Post subject: Re: Melville Engineering steel and pipe 54' rhd single Reply with quote
I'm liking those last two pics!! I'll be making a few trips to NC.
57 PG/SG standard
63 Ruby Red SC
campingbox Premium Member
campingbox is offline
PostPosted: Sat Jan 30, 2016 12:04 pm    Post subject: Re: Melville Engineering steel and pipe 54' rhd single Reply with quote
I think Mark would tell you to keep blasting - is there gonna be any dove blue left?
hugheseum
hugheseum is offline
PostPosted: Sat Jan 30, 2016 1:01 pm    Post subject: Re: Melville Engineering steel and pipe 54' rhd single Reply with quote
nice!!!!!!! your chemical process is correct too very nice
Have a great day!
gatorwyatt
PostPosted: Sat Jan 30, 2016 4:44 pm    Post subject: Re: Melville Engineering steel and pipe 54' rhd single Reply with quote
I can keep going at any point. The fact that it has all blue removable panels and they are all in relatively good shape it will look the part.
www.blastserv.com
wanted:
PostPosted: Sat Jan 30, 2016 11:47 pm    Post subject: Re: Melville Engineering steel and pipe 54' rhd single Reply with quote
I'm sure it will look killer either way. I expect it will be side by side with my '55 soon. I think your single has more blue paint on it though....
zuggbug
zuggbug is offline
PostPosted: Tue Feb 02, 2016 7:49 pm    Post subject: Re: Melville Engineering steel and pipe 54' rhd single Reply with quote
Woohoo...
58 15 window
56 westy
Page 8 of 16
