zuggbug Samba Member
Joined: June 17, 2008 Posts: 3479 Location: Anderson SC
Posted: Mon Jul 11, 2016 4:50 am Post subject: Re: What did you do for your Bus today? |
Red Fau Veh wrote: |
Malokin Martin wrote: |
Spent the better part of a Sunday getting the greaseball of a 40 horse extracted from the bus and pulling foam out from everywhere. We actually had fun doing it.
As a side note, the interior panels were held on by at least 500 hex drywall screws
coincidentally my buddy in Seattle spent time taking the foam out of our find this weekend. You think you have foam everywhere.
_________________ SOUTHERN INTEGRITY AIRCOOLERS
58 15 window
56 westy |
Enkiel Samba Member
Joined: October 21, 2004 Posts: 2771 Location: Quebec, Canada
Posted: Mon Jul 11, 2016 5:49 am Post subject: Re: What did you do for your Bus today? |
first time i see foam inside an engine bay... look scary _________________ 1964 Turkis Flipseat |
POS Samba Member
Joined: December 27, 2004 Posts: 285 Location: In a bus, down by the river in Boonville MO
Posted: Mon Jul 11, 2016 2:56 pm Post subject: Re: What did you do for your Bus today? |
that looks like fun... _________________ kombisutra wrote:
"This thead is about badgers, not hyenas.... get back on track ok?" |
Col_Forbin Samba Member
Joined: November 25, 2011 Posts: 84 Location: Austin, Texas
Posted: Mon Jul 11, 2016 3:15 pm Post subject: Re: What did you do for your Bus today? |
yikes! at least it doesnt appear to have held much moisture.. _________________ Goin' where the climate suits my clothes
Levon the 66 Westy:
http://www.thesamba.com/vw/forum/viewtopic.php?t=655780
71 Deluxe Bay |
Daddybus Samba Member
Posted: Mon Jul 11, 2016 7:38 pm Post subject: Re: What did you do for your Bus today? |
Made some guards for the tail lights. Prepping for a SST attempt in 2017.
pyrOman Fire Master
Joined: July 21, 2003 Posts: 12409 Location: Over 2002 posts deleted!
Posted: Tue Jul 12, 2016 7:08 am Post subject: Re: What did you do for your Bus today? |
So the Dromy's engine leaks a bit of oil... like who has a forkin vw aircooled engine that DOESN'T!!!
While I could and should make a effort to better seal it, that just cannot happen in the crunch time left before the Twin Lakes trip coming up. While I prolly be taking caboose on the caravan, pulling the trailer and such, just in case I figured a way to at least mitigate the "oil-leak-on-the-muffler-misting" issue. If not just to prevent that mist from falling on whoever is following me, at least it should keep it from spotting the crap out of the back of the bus. You all know what I'm talking about here.
The most annoying leak is coming out of the push rod tubes on the 3-4 head. After a good half hour at my first attempt at that ended up in failure, decided to stop that and move to the second phase, BIG "oil leak catch tin" for the whole engine. Once I got that figured out, it dawned on me to "match" that for the heads! So I created sleds that should drive the leak away from the header.
Here's the pix:
The "catch all" tin.
This was the main source of the mist, a leak right on the very hot J-tube.
The other side.
_________________ Some people are so busy being clever they don't have time enough to be wise. |
Red Fau Veh Samba Member
Joined: September 07, 2012 Posts: 3037 Location: Prescott Az.
Posted: Tue Jul 12, 2016 8:49 am Post subject: Re: What did you do for your Bus today? |
Sploosh!
_________________ 1971 Deluxe Sunroof Bay 1905 stroker, dual idf40's, 74mm Scat forged crank, engle 110 cam. CB 044 heads, AutoCraft rockers, chromoly push rods
1973 Orange transporter stock type 4 with dual 40 Dellortos and Empi single quiet pack
1969 Adventurewagen blue whale Gene Berg 1776 built by Dave Kawell dual 36 DRLA's, Vintage Speed exhaust, Bosch 019 screamer
1961 Swivel Seat camper, L345 grey
Touch Nicks Thing wrote: |
Swivel Seat panels are for people with no friends |
Posted: Sun Jul 17, 2016 12:21 pm Post subject: Re: What did you do for your Bus today? |
Removed the dangling 12v power outlet that used to get caught in the deck lid when I closed the engine compartment and replaced it with a solid-mounted 12v outlet. |
Posted: Sun Jul 17, 2016 4:27 pm Post subject: Re: What did you do for your Bus today? |
Sump drain plug sealing washer failure...I guess that I'll be making a mess changing it out today. |
64 ragtop volks Samba Member
Posted: Thu Aug 04, 2016 10:19 am Post subject: Re: What did you do for your Bus today? |
finally got a flat ice pic dove blue door,ans had friend put some logos on it.
EverettB Administrator
Joined: April 11, 2000 Posts: 69824 Location: Phoenix Metro
Posted: Thu Aug 04, 2016 5:27 pm Post subject: Re: What did you do for your Bus today? |
Nice Ike _________________ SOUTHERN INTEGRITY AIRCOOLERS
58 15 window
56 westy |
oldthingguy Samba Member
Joined: December 02, 2007 Posts: 146 Location: California
Posted: Thu Aug 04, 2016 10:10 pm Post subject: Re: What did you do for your Bus today? |
Forgot to post - installed my safari's last week.
_________________ 73 914 2.0 - sold
63 single cab
73, 73 and 74 Thing - gone
64 notch - gone
60 23 window - gone
57 oval - gone
plus a few others I should have kept |
frehstan Samba Member
Joined: November 05, 2005 Posts: 49 Location: Washington, USA
Posted: Mon Aug 08, 2016 1:43 pm Post subject: Re: What did you do for your Bus today? |
Started to look it over more closely and figure out where to start on my new '63 single cab project. Attempted to make an operable gas gauge but P/O had painted the tank sender and all, so no joy yet. Also cleaned a pound or so of dirt from the drivers side rear corner.
Looking forward to many more hours of wrenching and driving pleasure, and a few busted knuckles. |
Enkiel Samba Member
Posted: Mon Aug 08, 2016 2:33 pm Post subject: Re: What did you do for your Bus today? |
decided to try to remove the crack on my steering wheel...
before ;
after ;
EmpiGT Samba Member
Posted: Mon Aug 08, 2016 3:49 pm Post subject: Re: What did you do for your Bus today? |
got a good sun burn today color sanding and buffing, only did the driver's side. I look like a ripe tomato right now, but the 45 year old repaint really shined up well.
before...
after...
GLHTurbo Samba Member
Joined: March 30, 2009 Posts: 1376 Location: New Jersey
Posted: Mon Aug 08, 2016 6:22 pm Post subject: Re: What did you do for your Bus today? |
Came out great. Set up the ez up tent for the rest of the job.
EmpiGT wrote: |
before...
after...
_________________ 1957 Beetle
1966 Bus |
EmpiGT Samba Member
Posted: Mon Aug 08, 2016 6:46 pm Post subject: Re: What did you do for your Bus today? |
Ya I should, it's in the shade of the shop building until about 11am. color sanding took off the rust stains running down the nose. I kind of wanted to leave it but buffing removed it too. I'm trying to sale the bus right now but having second thoughts I think in the next couple weeks I'll weld in the rear wheel arches and rockers and blend them in then stick a motor in. And drive it until my big project is done. |
Big Bill Samba Member
Joined: June 21, 2005 Posts: 1782 Location: Santa Rosa, Ca
Posted: Sat Aug 20, 2016 5:38 am Post subject: Re: What did you do for your Bus today? |
Adjusted the link pins,and brakes. Greased the front end and had new tires installed. |
crukab Samba Chef
Joined: December 13, 2002 Posts: 6116 Location: Vermont
Posted: Sat Aug 20, 2016 6:38 pm Post subject: Re: What did you do for your Bus today? |
Tweeked the Brakes & hosed out the dusty engine compartment, took it on a nice Saturday cruze...
Hit a cool (1)55,555 miles:
Crappy cell pic.... BUT it happened to hit here:
On the way to the Punch Bowl in Warren Vt. ..... _________________ Tom
My Pops:
In the yard right now:
'51 Dodge 5 window truck
'65 Bug
'66 Singlecab
'82 Rabbit Truck Diesel from CALI
'86 Doublecab W/T
'88 Dodge Ram pickup
'11 Jetta Wagon |
