Adriel Rowley Samba Member
Joined: October 12, 2006 Posts: 4748 Location: Mesa, Arizona
Tram Samba Socialist
Joined: May 02, 2003 Posts: 22727 Location: Still Feelin' the Bern- Once you've felt it you can't un- feel it.
Posted: Mon Jun 04, 2012 1:20 pm Post subject: |
Adriel Rowley wrote: |
Tram wrote: |
Adriel, RTV won't work. Maybe use the Airtex 2000 pump for a Ranger as a temporary measure? |
Sure strange R.T.V. would not work. Bet it has to do with bonding to the metal, right?
Hmmm, I will think on that. |
No, it has to do with not being impervious to gas. _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
Posted: Mon Jun 04, 2012 2:36 pm Post subject: |
Tram wrote: |
Tram wrote: |
No, it has to do with not being impervious to gas. |
Any fuel? How about oil? Good to know sometimes.
Oh, and what modifications to the wiring are needed for the pump? I am on edge of deciding... _________________ Please consider I am Autistic, so I process information differently and still working on social skills. Thanks.
Dad's 1964 Beetle purchased September 1968.
https://www.thesamba.com/vw/forum/viewtopic.php?p=9252810#9252810
1971 Sunroof Squareback with Fuel Injection
http://www.thesamba.com/vw/forum/viewtopic.php?t=219811&highlight=squareback+rejuvenation |
Posted: Mon Jun 04, 2012 2:44 pm Post subject: |
Tram wrote: |
Tram wrote: |
Oh, and what modifications to the wiring are needed for the pump? I am on edge of deciding... |
I'd make up a couple of jumper wires from the Airtex pump that have male spade connectors on the other end so you can plug into your existing fuel pump plug without cutting/ splicing anything. Remember, the - wire on the Airtex plugs into the brown wire on the pump plug.
You'll need to leave the return line from the pump to the tank blocked off.
This way you can go back to OE later if you want. _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
ibjack Samba Member
Joined: February 06, 2002 Posts: 2106 Location: Imperial Beach CA
Posted: Mon Jun 04, 2012 4:22 pm Post subject: |
Jack, how do you have time to waste? Funny how you make sure your notchback is not showing! I rather see you put the time into getting your notchback running (why else would it be in that odd spot?). |
This is the photo YOU took at spring break. I asked you to tell me when you were coming. You have once again ignored me. I haven't blocked you in on purpose. I want you car GONE. I have not ignored you, but I have a job where I work 60 hours a week, nor have tried to make this sitation any more difficult. Please text me if you have any questions. _________________ '68 Lotus White T34 automatic sunroof
'64 Manila Yellow T34
'65 Sea Blue Square Panel
the1500club.com
Shop Lacky at the T3/34 Factory, https://www.facebook.com/profile.php?id=100094313902074 |
Posted: Mon Jun 04, 2012 8:14 pm Post subject: |
I am a good mechanic, better than Jack or you would like to know it seems. I am not as good as you two, or many others, but I might be more creative. I mean, you both do not work on F.I. or understand it. G-d gave use each unique talents, which for you include fuel pumps and a vast knowledge of 1500's. Jack it is keeping in daily driver order what many would have scrapped years ago.
It was driving great, then for a while, had an electrical issue, which I am not sure I ever solved. Once I had it solved, the fuel pump went bad. So I had Adney rebuild it and all was great. Then sometime it seized and Jack thought it had been that way. If this was a mechanical pump, it be so easy. I would have you rebuild it knowing that there would be no issues.
It will run, just need reliable parts.
I was told it would work as the same front beam in that thread. All that needs to be done is remove the fuel pump bracket. Is this wrong?
Wiring has been sorted, just looks bad as the turn signal relay needs to be replaced, I.I.R.C.. _________________ Please consider I am Autistic, so I process information differently and still working on social skills. Thanks.
Posted: Mon Jun 04, 2012 8:19 pm Post subject: |
ibjack wrote: |
This is the photo YOU took at spring break. I asked you to tell me when you were coming. You have once again ignored me. I haven't blocked you in on purpose. I want you car GONE. I have not ignored you, but I have a job where I work 60 hours a week, nor have tried to make this sitation any more difficult. Please text me if you have any questions. |
I just got a text from Jack, and he said because I was being difficult, he was going to call the police if I did not give prior waring of when I was coming to tow. I guess he has force me into spending money I did not want to. Same he had to be like a child and play tit for tat. Guess sometimes I should not be nice. Another reason for not living. _________________ Please consider I am Autistic, so I process information differently and still working on social skills. Thanks.
notchboy Samba Member
Joined: April 27, 2002 Posts: 22461 Location: Escondido CA
Posted: Mon Jun 04, 2012 8:31 pm Post subject: |
Not taking sides because I wasn't involved, but I think the "piling- on" here is both useless and counterproductive.
The issue is that Jack wants the car gone, and Adriel needs/ wants to get it.
That's it.
Now make it happen. _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
EverettB Administrator
Joined: April 11, 2000 Posts: 69824 Location: Phoenix Metro
ibjack Samba Member
Posted: Mon Jun 04, 2012 8:57 pm Post subject: |
Sorry Everett I really just want it gone, that's it plain and simple. I have kept many details relating to this whole situation private but Adriel does not see the importance of this. I would ask that this thread be locked as there is no progress being made, at this time, to getting Adriels car running. I'm hoping that after all that has transpired since this thread started, that Adriel can keep or find a good home for this car. _________________ '68 Lotus White T34 automatic sunroof
the1500club.com
blankmange Type 3 Darksider
Joined: July 17, 2004 Posts: 11498 Location: Bloßer Stahl-preapocalyptic MidCoast
Posted: Tue Jun 05, 2012 4:04 am Post subject: |
I understand that you have a hard time seeing the forest due to the trees, Adriel... but you have taken a difficult situation and are simply making it worse...
Jack, being the reasonable person that he is, would now be in his rights to give you a deadline to remove the car and then charge you a storage fee every day after that. So now your issue has become simplified: don't worry about fixing it and driving it off into the sunset - bite the bullet and tow it off of Jack's property.
Perhaps this is not the hobby for you - at least until you get space of your own to work on a car, store it and the parts for it, etc...
Throwing gas on the fire by making snide remarks at Jack or anyone else will not help the situation, nor will making asides about committing suicide, your Asperger's, your religion, your up-bringing, or anything else that is irrelevant to what needs to happen now....
Perhaps this should be locked until a resolution is completed... _________________ póg mo thóin
Certified DHS Technician
Samba Member # 24517 |
Posted: Tue Jun 05, 2012 8:17 am Post subject: |
blankmange wrote: |
Perhaps this should be locked until a resolution is completed... |
I now realize I somehow made it worse. Not sure, but if I have time, will discuss with Dr. Fader.
I too feel this is getting too out of hand, and canceled some things and put the house at risk to see about getting this out sooner than later. If BettyAnn finds out I towed the Squareback she will most likely not go forward with the house. I need this to be able to get the Master's, so by doing this, it is putting the Squareback before education. But, I feel I owe this to Jack considering all that he has done. Yes, I now realize driving it off was not an option.
I did not realize I had made snide remarks and if you want to point them out privately, I be more than grateful. I am sorry this has gotten out of hand and inappropriate.
I am tempted to say something about paragraph four, but concerned it might be considered arguing, which adults do not do.
U-Haul opens at 9:00 and will find out then whether they have a trailer. Until the Squareback is out of Jack's, I will not be posting, and hope this can stay quite until then, effectively locking it until progress happens.
Thank you for following the request! _________________ Please consider I am Autistic, so I process information differently and still working on social skills. Thanks.
notchback Insensitive Jerk
Joined: December 16, 2003 Posts: 7024 Location: Behind the Zion Curtain
Posted: Tue Jun 05, 2012 9:24 am Post subject: |
Tram wrote: |
Look- What are we, Split Bus elitists? I thought we were all Type 3 Geschwistern here. If you jackasses can accept a total skull- whacked nutbag like me, Adriel should be a walk in the gosdamn park.
Oh, wait... most of you people have never met me. Maybe that explains why I'm so freakin' happy. Possible? Discuss. |
Having met both you and Adriel, I consider you absolutely normal. _________________
zeen wrote: |
Arguing with johnnypan is like mud-wrestling a pig. After a while you realize he just enjoys playing in the mud, winning the contest is not the point. |
FU#3 |
BWD Samba Mailman
Joined: August 23, 2002 Posts: 2154 Location: In bed.
Posted: Tue Jun 05, 2012 10:02 am Post subject: |
blankmange wrote: |
Sometimes I wish I could commit suicide. It be selfish, but I would not have to deal with a unloving, hateful, cold, and cruel world. |
you should seek therapy, period....
of course, you'll respond with a litany of reasons why you can't do such a thing, but seriously, get some help.... |
NOW! _________________ BWD
JHC
member #2850
1966 Beetle
_____________________________ |
ibjack Samba Member
Posted: Tue Jun 05, 2012 6:36 pm Post subject: |
squareback is gone........thanks Adriel for getting it done sooner than we agreed. _________________ '68 Lotus White T34 automatic sunroof
the1500club.com
pedro sainz Samba Member
Posted: Tue Jun 05, 2012 7:45 pm Post subject: |
ibjack wrote: |
squareback is gone........thanks Adriel for getting it done sooner than we agreed. |
THE END _________________ 68 T34 1600 Automatic
62 T34 Cabriolet Prototype
N.O.N.A member #3
The Truth is Out There |
Posted: Tue Jun 05, 2012 8:14 pm Post subject: |
Well, THAT certainly was exhausting. Good on ya, Adriel. Bout time! _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
ALLWAGONS Samba Member
Joined: June 03, 2000 Posts: 4189 Location: Pasadena CA/DTLA soon China
Posted: Tue Jun 05, 2012 10:35 pm Post subject: |
I really hope this was some kind of joke! _________________ I'd be UNSTOPPABLE if not for Law Enforcement and PHYSICS.
NON INFLUENCER APPROVED |
