FastbackFynn Samba Member
Posted: Thu May 05, 2016 2:05 pm Post subject: Re: Fuel injection relief here! |
Hi,
The whole FI system from my '72 fastback has been nicked! and was wondering if it could fit one of the custom systems i've got from a beetle inlet manifold with a modern VCI? I'm pretty sure they are the same engine apart from the cooling system so it should work.
Thanks
Fynn |
t-royR Samba Member
Joined: April 19, 2012 Posts: 464 Location: Minnesota
Posted: Tue May 10, 2016 7:19 am Post subject: Re: Fuel injection relief here! fuel damper |
I am replacing the fuel pump and hoses on my 69 fasty fuel injection. Where can i purchase a new fuel damper? _________________ T-roy
75 Super
71 Super
71 Ghia coupe auto-stick
71 Ghia conv
69 Fasty
74 Ghia conv |
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34003 Location: Conejo Valley, CA
Posted: Tue May 10, 2016 8:38 am Post subject: Re: Fuel injection relief here! fuel damper |
t-royR wrote: |
I am replacing the fuel pump and hoses on my 69 fasty fuel injection. Where can i purchase a new fuel damper? |
Many just run the car without one, with no ill effects. But they do show up in the Samba classifieds regularly. |
Donnie strickland Samba Member
Joined: December 21, 2009 Posts: 2403 Location: Moody, AL
Posted: Tue May 10, 2016 10:00 am Post subject: Re: Fuel injection relief here! |
FastbackFynn wrote: |
Hi,
Thanks
Fynn |
It depends on your system -- we need more information. Post some pictures. _________________ 71 Elm Green FI A/T Squareback |
t-royR Samba Member
Posted: Tue May 10, 2016 10:19 am Post subject: Re: Fuel injection relief here! |
i'll have to snap a photo. However, what I have in my car matches exactly what is described in the repair manual for 1969 type 3 electronic fuel injection. Problem is, I can' find any for sale anywhere. At least, not under the name "fuel damper".
It is recommended for FI engine. Not sure what side-effects removing this could have. my understanding is that it is designed/intended to remove (dampen) the pulses of pressure created by the fuel pump. _________________ T-roy
75 Super
71 Super
71 Ghia conv
69 Fasty
74 Ghia conv |
Tram Samba Socialist
Joined: May 02, 2003 Posts: 22712 Location: Still Feelin' the Bern- Once you've felt it you can't un- feel it.
Posted: Tue May 10, 2016 10:28 am Post subject: Re: Fuel injection relief here! |
t-royR wrote: |
It is recommended for FI engine. Not sure what side-effects removing this could have. my understanding is that it is designed/intended to remove (dampen) the pulses of pressure created by the fuel pump. |
That's exactly correct, and I've never seen any ill effects from not having one. I don't know that they've been available new for decades. Clean your old one up and repaint it if you want 100% authenticity. _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
t-royR Samba Member
Posted: Tue May 10, 2016 10:30 am Post subject: Re: Fuel injection relief here! |
thanks. I'm sure mine is o.k. just thought I'd replace it along with other parts i'm replacing, as figured it was cheap.
Peace! _________________ T-roy
75 Super
71 Super
71 Ghia conv
69 Fasty
74 Ghia conv |
Posted: Tue May 10, 2016 10:52 am Post subject: Re: Fuel injection relief here! |
Donnie strickland wrote: |
Hi,
Thanks
Fynn |
It depends on your system -- we need more information. Post some pictures. |
This reply was for Fynn, not t-royR. _________________ 71 Elm Green FI A/T Squareback |
Posted: Tue May 10, 2016 10:55 am Post subject: Re: Fuel injection relief here! |
t-royR wrote: |
Peace! |
Unless it's cracked, no need to replace it. It's hollow, so it can't go bad unless it's leaking. _________________ 71 Elm Green FI A/T Squareback |
t-royR Samba Member
Posted: Tue May 10, 2016 10:59 am Post subject: Re: Fuel injection relief here! |
Excellent! _________________ T-roy
75 Super
71 Super
71 Ghia conv
69 Fasty
74 Ghia conv |
t-royR Samba Member
Posted: Tue May 10, 2016 12:15 pm Post subject: Re: Fuel injection relief here! Fuel filter for Fuel Injection |
Do i need to purchase a special fuel filter for fuel injection, or does standard fuel filter suffice? _________________ T-roy
75 Super
71 Super
71 Ghia conv
69 Fasty
74 Ghia conv |
KTPhil Samba Member
Posted: Tue May 10, 2016 12:19 pm Post subject: Re: Fuel injection relief here! Fuel filter for Fuel Injection |
t-royR wrote: |
Do i need to purchase a special fuel filter for fuel injection, or does standard fuel filter suffice? |
Original style FI filters are hard to come by. There is an equivalent metal round filter that can be made to work. You cannot use the cheap plastic conical filters made for low pressure systems like carburetors.
Google part number 311133511C and find both types. Note size of nipples when choosing; some are stock, some aren't.
Original:
Replacement:
Posted: Tue May 10, 2016 4:51 pm Post subject: Re: Fuel injection relief here! |
I use one of the metal filters. Go to the parts house and find one with 5/16 nipples. _________________ 71 Elm Green FI A/T Squareback |
t-royR Samba Member
Posted: Wed May 11, 2016 5:56 pm Post subject: Re: Fuel injection relief here! - gas tank hookup |
Putting new pump in my 69 FI fasty. See two pipes coming out of gas tank (wasn't hooked up when i bought it). Does it matter which one is for pulling fuel versus which one to use for returning fuel to tank? One comes directly out of the center of bottom of tank while the other comes out slightly off-center on the bottom of the tank. _________________ T-roy
75 Super
71 Super
71 Ghia conv
69 Fasty
74 Ghia conv |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17970 Location: Eugene, OR
Posted: Wed May 11, 2016 6:45 pm Post subject: Re: Fuel injection relief here! |
The outlet with the nut on it has the fuel sock attached & is the supply line. The metal supply line is on the driver side of the tunnel. _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
t-royR Samba Member
Posted: Sun May 15, 2016 10:52 am Post subject: Re: Fuel injection relief here! - electrical thingy?? |
I am about to put the engine in, and so have started checking out the electrical under the dash to get ready to start it. Don't know what this electrical part is that is handing down behind the steering column. Help!!! _________________ T-roy
75 Super
71 Super
71 Ghia conv
69 Fasty
74 Ghia conv |
Posted: Sun May 15, 2016 11:07 am Post subject: Re: Fuel injection relief here! |
Relay missing its cover? Copy & paste the Forum Code 'img' link on the right side to show us what you're talking about!
Posted: Sun May 15, 2016 12:46 pm Post subject: Re: Fuel injection relief here! |
It's the fuel pump relay that's missing its cover. _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
KTPhil Samba Member
Posted: Sun May 15, 2016 8:00 pm Post subject: Re: Fuel injection relief here! |
Tram wrote: |
It's the fuel pump relay that's missing its cover. |
Yup; the giveaway is the plastic sheath on the wires. |
t-royR Samba Member
Posted: Wed May 18, 2016 5:07 pm Post subject: Re: Fuel injection relief here! What fuel pump to use |
O.K. I just received my second Airtex fuel pump in the mail, and this one also does not seem to be the correct one. I'm getting frustrated here.
I bought the Airtex E2000. It came and is obviously designed to go in the tank.
i bought the Airtex E2001. It looks closer, but has a large threaded end for fuel input. It is about 1/2 inch in diameter and is threaded. The cap on that end reads, "new filter required this end". Is this a pump I can use? Looks like i need an adapter for the large end, so I can put a fuel line on it. Or, some kind of screw on filter. HELP!! Do I need to switch to Delphi pump? Those pics of it also look like it has a large end. _________________ T-roy
75 Super
71 Super
71 Ghia conv
69 Fasty
74 Ghia conv |
