mattmcbroom Samba Member
Joined: April 12, 2015 Posts: 31 Location: United States
Posted: Fri Feb 26, 2016 9:17 am Post subject: Re: "What wheels fit?" The ultimate wheel post. |
I was referring to the ones on the syncro.
Will these 18s need any machining to fit my 2wd??
_________________ '99 Chevy Tahoe 4x4
'91 Volvo 240 wagon
'84 Westfalia
'78 Yamaha xs650 special
'85 vanagon gl
'92 volvo 240 sedan
'01 saab 9-5
'97 awd Astro
Live to love and love to live but don't forget to give the love and love to give |
Posted: Fri Feb 26, 2016 11:40 am Post subject: Re: "What wheels fit?" The ultimate wheel post. |
mattmcbroom wrote: |
Yes, those would have to be machined to open up the center cap area in order to fit onto a 2wd. _________________ "Sometimes you have to build a box to think outside of." - Bruce (not Springsteen)
Surfy Murphy Samba Member
Joined: September 05, 2013 Posts: 139 Location: Brooklyn, New York
Posted: Sat Feb 27, 2016 4:47 pm Post subject: Re: "What wheels fit?" The ultimate wheel post. |
I have a set of 20mm spacers made by t3 technique up for grabs and 3 audi allroad rims, powdercoated to match stock. Spacers work with ET45 wheels on syncro only. PM me if interested....I switched to CLKs. _________________ 1987 Orly Blue Sunroof Syncro, EJ25 |
Posted: Fri Mar 04, 2016 2:18 pm Post subject: Re: "What wheels fit?" The ultimate wheel post. |
Found a nice set of merc wheels? Anyone seen these before or ran with em??
'91 Volvo 240 wagon
'84 Westfalia
'85 vanagon gl
'92 volvo 240 sedan
'01 saab 9-5
'97 awd Astro
Dub Misfits Samba Member
Joined: September 10, 2015 Posts: 38 Location: Laying under a broken VW in Maryland somewhere
Posted: Sat Mar 05, 2016 6:35 pm Post subject: Re: "What wheels fit?" The ultimate wheel post. |
Picked up some SSR Strahl wheels a little while back. 17x8 17x9 ET is either 38 or 45. I have yet to measure them. They will be drilled and inserted to 5x112.
Jim Hunter Samba Member
Joined: February 14, 2014 Posts: 107 Location: MB, Slovenjia
Posted: Tue Mar 08, 2016 12:28 pm Post subject: Re: "What wheels fit?" The ultimate wheel post. |
There is two types types 8x16 ET62 and 6.5x16 ET47
Posted: Tue Mar 08, 2016 1:37 pm Post subject: Re: "What wheels fit?" The ultimate wheel post. |
Yeah, Jim Hunter is correct. Those wheels came in 16x8 ET62 and 16x6.5 ET47. The 16x6.5 ET47 wheels were never imported into the US, but there are lots of the 16x8 ET62 version. Either one could be used on a Syncro, but the 16x8s are not a good choice for a 2wd. No matter what, the installation would requires spacers or adapters to make them work. _________________ "Sometimes you have to build a box to think outside of." - Bruce (not Springsteen)
oceanair Samba Member
Joined: June 09, 2013 Posts: 720 Location: Victoria, BC
Posted: Mon Mar 14, 2016 7:16 pm Post subject: Re: "What wheels fit?" The ultimate wheel post. |
Will these fit on my 84 Tintop? What would it take to get them on?
Thanks --
http://www.usedvictoria.com/classified-ad/-set-of-Genuine-16-RS4-Audi-rims-with-tires-_26437704 _________________ 84 Vanagon Pop Top Conversion from Tin Top, 1970 Ghia - all sweet rides! Love em!
Previous: Green 72 Tin Top, White 72 Westy, Blue 64 Beetle, Yellow 71 Squareback, 2014 Jetta TDI Wagon - wish I could have them all back! |
WedgeAntillies Samba Member
Joined: April 07, 2008 Posts: 166 Location: Maple Ridge, BC
Posted: Tue Mar 15, 2016 7:01 am Post subject: Re: "What wheels fit?" The ultimate wheel post. |
You can make those wheels fit, but you will need to have the center bores opened up to 66.56mm. For parts, you will need spacers front and rear, small ball seat front lug bolts, small ball seat rear lug nuts and longer rear studs. You will not easily be able to run the front center caps unless you modify both the grease caps and the center caps. _________________ "Sometimes you have to build a box to think outside of." - Bruce (not Springsteen)
Posted: Tue Mar 15, 2016 10:04 am Post subject: Re: "What wheels fit?" The ultimate wheel post. |
Thanks -- sounds like a lot more than i was hoping for -- are the longer studs a big deal to get and change? Do you sell those as well? Are they a good size for my 1.9?
Thanks!! _________________ 84 Vanagon Pop Top Conversion from Tin Top, 1970 Ghia - all sweet rides! Love em!
Posted: Tue Mar 15, 2016 10:42 am Post subject: Re: "What wheels fit?" The ultimate wheel post. |
Changing the rear studs requires the removal of the 46mm axle nuts and hubs. Those nuts are torqued to 360 ft lb. If you have the right tools, it's not a big deal. If you don't have the right tools, it can be a real challenge. Once the nuts are removed, the hubs just slide off and you can press out the old studs and press in the new ones. _________________ "Sometimes you have to build a box to think outside of." - Bruce (not Springsteen)
makina Samba Member
Posted: Fri Mar 18, 2016 5:10 am Post subject: Re: "What wheels fit?" The ultimate wheel post. |
Hello, after rebuilding the heads & painting the bus. Finally it's time to upgrade the wheels I've invested hours I mean hours trying to learn all the dynamics of such. Spacers, studs, measurements etc etc ... So I'm looking at some really nice 17" 08 Audi rims, from what I have learned is that Audi rims are closer to our vans but I know they very from year to year, don't know how wide they are but I take it there no wider than 8" I'll try calling the dude later but I thought to post first to see if anyone has had similar experience. |
Posted: Sun Mar 20, 2016 2:11 pm Post subject: Re: "What wheels fit?" The ultimate wheel post. |
Would these be too much of a horsepower loss for my 1.9 tintop? If not, much to do to install them?
http://www.usedvictoria.com/classified-ad/Audi-A6-16-Wheels_27070932 _________________ 84 Vanagon Pop Top Conversion from Tin Top, 1970 Ghia - all sweet rides! Love em!
Posted: Sun Mar 20, 2016 5:17 pm Post subject: Re: "What wheels fit?" The ultimate wheel post. |
In order to run those wheels, you would need to have the center bores opened up to 66.56mmm and you would need spacers front and rear, new lugs front and rear and new rear studs.
The tires on those wheels are not usable on a Vanagon. They are too short and the load rating is not sufficient. A 205/60R16 with a load rating of at least 96 XL would be a perfect match with your 1.9. _________________ "Sometimes you have to build a box to think outside of." - Bruce (not Springsteen)
Posted: Sun Mar 20, 2016 9:20 pm Post subject: Re: "What wheels fit?" The ultimate wheel post. |
Thanks -- they sold fast! Already gone. Funny though. The tire size you recommended are the ones on my wife's Golf TDI --
Thanks -- I'll keep looking! _________________ 84 Vanagon Pop Top Conversion from Tin Top, 1970 Ghia - all sweet rides! Love em!
Justcantwait Samba Member
Posted: Sun Mar 20, 2016 10:00 pm Post subject: Re: "What wheels fit?" The ultimate wheel post. |
Having done my darnedest to read this thread as thoroughly as possible, I wanted to ask this newbie question before I go spend my dollars on a bad craigslist decision: will these work for my 1991 2wd Westy, and if so what adaptations do I need?
Set of 4 factory original alloy Audi rims. This 16" model came stock on A4, A6, S6 and Allroad from 1995-2004. 5-lug 5x112 mm bolt pattern. Tires are worn to the wear bars. $300 obo
I would like to put light truck tires on the rims, I was thinking Michelin Defenders, any recommendations appreciated! |
Posted: Mon Mar 21, 2016 5:55 am Post subject: Re: "What wheels fit?" The ultimate wheel post. |
Justcantwait wrote: |
Chances are very good that you can use those wheels, but there are a few things that you should be aware of. The first is that you will need to have the centerbores of these wheels machined to 66.56mm. The second is that many Audi/VW wheels have designs that make it difficult to impossible to get the center caps to fit.
Other than that, a set of spacers front and rear, new front lug bolts, new rear lug nuts and new rear wheel studs will get the wheels mounted up nicely.
I'm always open to having people send me links, photos or part numbers of the wheels that they are considering and I try to get back to them as quickly as possible with an answer. Sending me an email to the address in my signature is usually a bit quicker and easier. _________________ "Sometimes you have to build a box to think outside of." - Bruce (not Springsteen)
Posted: Mon Mar 21, 2016 10:10 am Post subject: Re: "What wheels fit?" The ultimate wheel post. |
Many thanks! |
wesitarz Samba Member
Joined: August 20, 2012 Posts: 1490 Location: Victoria,B.C.Canada
Posted: Fri Mar 25, 2016 4:19 am Post subject: Re: "What wheels fit?" The ultimate wheel post. |
Would this rim work as a spare? Fit the carrier?
Mercedes Benz 15" Wheel Rim 1989-1993 1264004102 65Jx15H ET 21.5
Thanks. |
