Replacing Convertible Support Rails Explained
jaxvert
jaxvert is offline
PostPosted: Tue May 25, 2010 10:33 am    Post subject: vert rails Reply with quote
During my project i cut the bottom half of the 62 donor sedan from New mexico. The rear luggage tray and front and back qtr. panels, front hump rear humps etc. were left welded to the 62 rails etc. basically cut the bottom 8" of complete sedan and welded it back to the vert body. I flipped the 62 rails over and welded my vert sapports in. the biggest thing here is to keep them outside of the pan gasket seat area. if you move them to far towards the pan seat area they will not clear the pan. I picked up my rails from wolfberg west. nice stuff. only after market steel on the hole vert. And this vert should have been laid to rest. 2 more block sandings and it goes to the paint both.
The only bondo filling i did on the vert was the rear qry. panels about a 4" cut across. and 2" on the front panels. Inside the wheel wells I used a seam sealer and rubberized undercoating.
1.Bead blasted.
2. 2 coats zinc primer
3. interior and underbody coated with F-150 2 part epoxy. (hard core stuff)
4. Under body coated with commercial rubberized paintable undercoating.
Rust suxs
Dave[/youtube][/url]
1963 Original Anthracite L469 vert.
1963 Ragtop (stolen years ago) low life fuckers !
Braukuche
Braukuche is offline
PostPosted: Sat Jul 31, 2010 7:39 am    Post subject: Re: vert rails Reply with quote
I am about to do the rails on my '60. The car is up on saw horses with the doors on. I havea few questions:
I you leave the doors on don't they essentially provide a three point support for the opening preventing the body from "tacoing?"
Can the old rails be removed with a air chisel top break the spot welds or is the metal lip on the heater channel too thin and will tear necessitating the drilling out of the spot welds?
What are the big holes on the inside of the support rails for?
Is it safe to assume you have to plug weld it on both sides of the heater channel?
Thanks.
WrennMetallWerks
WrennMetallWerks is offline
PostPosted: Fri Aug 06, 2010 10:16 pm    Post subject: Re: vert rails Reply with quote
Thanks.
⚒ Believe In The Power Of Positive Thinking ⚒
Purpose Over Pleasure 🕊
“Hard Werk ⚒ God First “
https://music.youtube.com/watch?v=0-PSeV52tZ4&si=wpcuRnQyvIFo2nCJ
https://music.youtube.com/watch?v=PaCorLXzC5w&si=cbzT8fjlzVlIWfSV
https://music.youtube.com/watch?v=_aoE5aYSutY&si=mkZKPxd_41QA1kfs
https://music.youtube.com/watch?v=_NzUyyVexAE&feature=share
https://music.youtube.com/watch?v=UI8yUrIWS7E&feature=share
GüteAndTite
Early Convertible Güru
GüteAndTite is offline
PostPosted: Wed Dec 15, 2010 2:35 am    Post subject: Reply with quote
So I read through the 4 pages on this thread and know where to buy and how to make late model body braces, and where to buy rails and how to measure the body. but I already firgured out that stuff years ago.
but can someone actually post step by step pictures of the process of removing and replacing the support rails. This thread is called Replacing Convertible Support Rails Explained right?
what spot welds on what panels need to get removed? where do you cut?
where do you weld up the panels when resintalling it, and lastly how did you align it? PICTURES PEOPLES!!
lucy got some splaining to do
Official 58-60 "Early Big Window" Convertible Thread & Registry
http://www.thesamba.com/vw/forum/viewtopic.php?t=426481
F&S Saxomat Automatic Clutch System Thread
http://www.thesamba.com/vw/forum/viewtopic.php?t=462533
61-67 Delanair Air conditioning Thread
http://www.thesamba.com/vw/forum/viewtopic.php?t=457944&highlight=air+conditioning
PUNCTUATION CHANGES THE WORLD: "I need to help my uncle, Jack, off a horse" is way better than, "I need to help my uncle jack off a horse"
FloridaVert
FloridaVert is offline
PostPosted: Thu Dec 16, 2010 4:28 pm    Post subject: Reply with quote
I'd like to know the same thing as guteandtite.
jaxvert
jaxvert is offline
PostPosted: Mon Dec 27, 2010 12:34 pm    Post subject: Pictures Reply with quote
I've got a few from my project, there a pain the asss to post on here, drop me your email and i will send them.
David
Scott Faivre
Scott Faivre is offline
PostPosted: Thu Mar 17, 2011 11:44 pm    Post subject: Reply with quote
I can't really help you guys with "cut this weld here" and "grind this spot here" because my car had the original rails removed along time ago and those gnarly looking box tube and angle iron pieces welded in. If you take sometime and look at the construction of the lower body, the heater channels and the support rails, you should be able to decifer what needs to happen to remove the rotted rails.
It's a lot of work, but I also feel it's a lot of fun to sit back when your done and say, "Yup! I saved another one!" Wink
Scott Faivre
66 Sedan & 64 Convertible
64 Vert Resto Gallery
GüteAndTite
PostPosted: Fri Mar 18, 2011 10:08 am    Post subject: Reply with quote
Scott Faivre
I realize that rust and previos hacks make a difference as more may need replacement, however there's got to be a list of spot weld row here, cut seam weld here, remove this panel, then this one,clamp here tack here, I'm just saying, bentley did it for many panels, but not this one. I'm patching mine not replacing, but it would be nice to have an over all knowledge of the procedure
Jeff 62 Vert
Jeff 62 Vert is offline
PostPosted: Sun Apr 03, 2011 11:48 am    Post subject: Reply with quote
"Bug Me" video series, video number 7 shows exact, step by step instructions. Best all around resource for tackling the heater channel and reinforcement rail replacement for convertibles. Complete "tack here, stitch weld there" video instructions.
Scott Faivre
PostPosted: Tue May 17, 2011 10:31 pm    Post subject: Re: vert rails Reply with quote
Thanks.
Those holes are for access to the body/pan bolts. Yes, you'll need to weld on both sides of the rail. It's not thin sheet metal, so a simple "plug" or "rosette" weld from your 120AC welder is probably not the best choice. You need some serious power to attach these things to the heater channels. Remember these are the basis of the integrity of the car. You want those suckers on there good!
Scott Faivre
GüteAndTite
PostPosted: Sun May 22, 2011 12:04 pm    Post subject: Reply with quote
SO AFTER SKIMMING THRU 4 PAGES IN THIS THREAD I see no step by step on support rails. any help there guys?
jaxvert
jaxvert is offline
PostPosted: Mon May 23, 2011 2:40 pm    Post subject: channel / rail replacement Reply with quote
Good n tight, email me, i can send some pics and explain how i did mine. look at my pics on the gallery.
Jaxvert
GüteAndTite
PostPosted: Mon May 23, 2011 2:48 pm    Post subject: Re: channel / rail replacement Reply with quote
Jaxvert
thanks for the offer, but can you post it up here for the benefit of other samba members as well, I hate to be greedy and do it by PM. Thanks- Bret
GüteAndTite
PostPosted: Mon Jun 27, 2011 2:11 pm    Post subject: Re: channel / rail replacement Reply with quote
guteandtite wrote:
Jaxvert
or you can email it to me at [email protected]
Geezer
Geezer is offline
PostPosted: Thu Oct 20, 2011 5:38 pm    Post subject: Chuck's Convertible "How to Support Rail Replacement&qu Reply with quote
I was disheartened after obtaining this 4 page flyer for $18.95. I was heading in the general direction of the support rail install that it describes anyway. I thought they had a trick ? Nope. The last page covers the torch cutting out of a support rail at Fast Wrecking in Duarte, Ca. 2 photos. The flyer also shows a rail that has to be cut and hammered into shape at the front. The work is performed by Robco Collision Repair. He cut the old out with a plasma cutter and MIG welded in the rail. Sad
legotech7
legotech7 is offline
PostPosted: Sat Jun 16, 2012 8:57 am    Post subject: Reply with quote
Just caught this support rail thread. Good info.But unless your HC are really FUBAR, you won't need anything like those support braces from BUGSTUFF.
Too expensive! I will be doing my HC soon, and will use a one inch angle iron for what ever length of the door is with the doors still attached to the car. And drill a couple of holes and use 1/4 inch self tapping screws. That's what they used in the BugMe video and seemed to have braced very well. That will only leave two small holes in the pillars and you can weld them in or what ever. No need to buy pricey tools for a one time deal.
Chris Vellat
Chris Vellat is offline
PostPosted: Sat Sep 08, 2012 5:21 pm    Post subject: Reply with quote
Pricey tools aren't required - but generally using simple tools means headaches (R&D work) and less than desirable outcome without exceptional attention - which is generally the trade-off, cheaper often takes longer and/or turns out poorly...
Any tips on installing the convertible rails to a `69 sedan? Straight forward so long as the pans/channels are in good shape?
(3) '69's
'67 Baja
'74 Super
'73 Bay
(2) '77's
agfussell
agfussell is offline
PostPosted: Sat Nov 10, 2012 5:52 pm    Post subject: Re: Pictures Reply with quote
David
I saw your post on bracing the vert, I'm a new V/W owner needing to replace heater ch. and support Hoping you could e-mail me the pictures you have. much appreciate. afussell; ([email protected])
DKO
DKO is offline
PostPosted: Wed Nov 28, 2012 3:05 pm    Post subject: Reply with quote
Here's some assistance including pics on another site:
http://personal.cfw.com/~ctvert/poj/heater/
far rider Premium Member
far rider is offline
PostPosted: Thu Nov 29, 2012 7:28 pm    Post subject: Reply with quote
I have a very rusty 63 convertible. The body has been separated from the pan and I have removed the doors and put braces in their place. I've read about the need for bracing but am wondering if its okay to replace both wheelhouse and lower firewall before removing channels without any additional bracing (other than the door braces) before tackling the heater channels. Appreciate any thoughts or comments.
67 zenith blue sunroof
Contentment; when what you have is what you want.
Page 4 of 6
