Utiledulci Samba Member
Joined: January 06, 2005 Posts: 85 Location: Marlboro OH
Posted: Sat Aug 19, 2006 9:05 pm Post subject: Wiring an externally regulated alternator |
Still have my regulator...will an externally regulated alternator wire right up to it? What's the gig? |
Erik G Samba Member
Joined: October 16, 2002 Posts: 13281 Location: Tejas!
bill may Samba Member
Joined: August 27, 2003 Posts: 14160 Location: san diego,ca
Posted: Sun Aug 20, 2006 6:20 am Post subject: Wiring an externally regulated alternator |
Ok, so you answered one question, that is "no" to using my regulator. Can anyone answer the more important question of how do I wire it up then? I saw the info from "Speedy Jim" and the wiring diagram but it does me no good if I don't know what type of regulator to use. Hello? I know its not rocket science. It's an old VW. |
Russ Wolfe Samba Member
Joined: October 08, 2004 Posts: 25187 Location: Central Iowa
Posted: Sun Aug 20, 2006 7:05 am Post subject: Re: Wiring an externally regulated alternator |
aenonauto wrote: |
It is rocket science when you get into electronic voltage regulators.
What is tha actual alternator that you have?? Can you get us a picture? _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Gary: OK. Ima poop. |
Posted: Sun Aug 20, 2006 7:20 am Post subject: Alternator |
I can't figure out how to post a pic on this page...I'll put one in the Gallery under Microbuses... |
Posted: Sun Aug 20, 2006 7:27 am Post subject: |
Here it is, straight off the Samba.
Part you want is in the lower left corner.
Go to the technical section under wiring, Type 1, 74 up with external regulator. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
sloans265 Samba Member
Posted: Sun Aug 20, 2006 7:37 am Post subject: |
Why did you even decide to use that outdated unit, with out having figured wiring part out first? Even after you get the wiring problem solved you still have to get a reg. I've heard those are getting harder to find(I could be wrong). Do yourself a favor and either put back on the Generator that went with the reg you got or get yourself a AL82N. Internally regulated NEW Bosch alt. If $ is an issue go to any auto chain and order one of their rebuilt AL82X (bosch #). _________________ 1970 Lotus White Panel
In search of any Pensacola Fla dealership items |
Posted: Sun Aug 20, 2006 7:43 am Post subject: Alternator |
This unit just happened to come with the motor I just picked up, thought I'd use it but it looks like its not feasible. Just gonna go with my old generator for now to get back on the road. Thanks for your help. |
Posted: Sun Aug 20, 2006 7:51 am Post subject: |
THat would be your best bet. I just found the reg you need for that alt. Bosch # 0 190 600 017. $67 at CIP1. Kind of high considering for @ $40 more you could get a new internally reg. alt. Save yourself any grief and run that gen. _________________ 1970 Lotus White Panel
Posted: Sun Aug 20, 2006 7:54 am Post subject: Re: Wiring an externally regulated alternator |
aenonauto wrote: |
im a school janitor,and i figured out you need a 73/74 voltage regulater for an alternater. _________________ Admin note: Bill Passed away - July, 2017
1965 panel bus-Kermit
"Camping is cheaper than therapy"
www.sv2s.com
www.steeringboxscrapers.net
SBS #100
http://www.thesamba.com/vw/forum/viewtopic.php?t=453617 |
roberto Samba Member
Joined: December 10, 2002 Posts: 833 Location: West Central Ohio
Posted: Sun Aug 20, 2006 9:05 am Post subject: |
Is what everyone is trying to say, is that the reg is specific to those motorola alt's. no ifs, ands, or buts.
and your best bet would be to move on to a newer internally regulated unit. other wise go back to a genny/reg set up. |
ollie Samba Member
Joined: September 03, 2002 Posts: 46 Location: St Leonards on Sea, UK
Posted: Sun Aug 20, 2006 2:35 pm Post subject: |
here you go...
hsimpson Samba Member
Joined: February 18, 2006 Posts: 49 Location: Bessemer,Alabama
Posted: Fri Apr 06, 2007 9:13 pm Post subject: |
is this alternator internal or external regulated? _________________ 63 Panel
61 Beetle |
Posted: Fri Apr 06, 2007 9:21 pm Post subject: |
hsimpson wrote: |
is this alternator internal or external regulated? |
That one in the pic is externally regulated. See the 1 large post(wire to battery) and the the 3 prong connector (going to reg) An internally regulated would just have 2 conections. One to the battery (post) and one for the warning light (male spade terminal) _________________ 1970 Lotus White Panel
Scorcho Samba Member
Joined: May 04, 2012 Posts: 386 Location: Chicago, IL
Posted: Thu Jun 30, 2016 10:14 am Post subject: Re: Wiring an externally regulated alternator |
Trying to wire my internally regulated generator right now and these are the cables I have on my regulator. I've been reading about blue to green but I don't have a green wire. Can anyone help me by telling me which wires join together? |
busdaddy Samba Member
Posted: Thu Jun 30, 2016 11:36 am Post subject: Re: Wiring an externally regulated alternator |
Do you mean internally regulated alternator? If so then connect red to the big post and blue to the small spade. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Thu Jun 30, 2016 3:32 pm Post subject: Re: Wiring an externally regulated alternator |
busdaddy wrote: |
Do you mean internally regulated alternator? If so then connect red to the big post and blue to the small spade. |
Yes alternator. Still used to having a generator obviously haha. So I don't need the wires that are connected to the D+ and DF? Just need to extend the red and blue one? |
Posted: Thu Jun 30, 2016 3:58 pm Post subject: Re: Wiring an externally regulated alternator |
Scorcho wrote: |
busdaddy wrote: |
Yep, you can ditch the old regulator too, unless it's used as a terminal block to connect the battery to the rest of the bus. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Thu Jun 30, 2016 5:09 pm Post subject: Re: Wiring an externally regulated alternator |
Wow that's actually pretty simple thanks!!! |
