Afterlame Samba Member
Posted: Sun Nov 15, 2009 7:01 am Post subject: Re: primer color for panel interior |
booyak wrote: |
does anyone know of a good match for the primer color for the interior of a 59 panel? Thx |
Interested too !
to make some area outside but it's probably the same primer that inside (?)
Nobody as a reference ? |
joebug1956 Samba Member
Joined: August 08, 2006 Posts: 362 Location: Richmond VA
Posted: Sat Dec 26, 2009 9:03 pm Post subject: |
Anyone know what I can use to paint the deluxe split window dash pods with? |
Ady6119 Samba Member
Posted: Fri Jan 22, 2010 11:13 am Post subject: |
How much paint do i need for my bus 21 win. deluxe '67?
I have;
3 Liter BC red for middle side and under chassis
3 Liter white for top side and interior + thinner and hardener,
Should be enough ? |
Sanny Samba Member
Joined: August 18, 2008 Posts: 159 Location: Los Osos, Ca
Posted: Thu Jan 28, 2010 8:57 pm Post subject: Dove Blue in Valspar or PPG? |
Does anyone have the formula in Valspar or PPG for Dove Blue or should I just custom match a piece of the original paint color? |
flyertim Samba Member
Joined: September 17, 2009 Posts: 554 Location: medina, ohio
Posted: Sat May 15, 2010 8:04 am Post subject: L351 Korallenrot (Coral Red) |
my local paint jobber found the code for L351 Coral Red (56-58 beetle) from BASF.
this is for their UNO (single stage) line of paint:
color id: MS137584
solution id: CL682996
SC01 (base booster) = 89.5
SC77 (iron red) = 659.7
SC90 (white) = 813.4
SC10 (mixing clear) = 955.0
SC63 (chrome yellow) = 1044.6
SC25 (carbon black) = 1074.0
this will give you 1 quart of paint. _________________ "Broadsword calling Dannyboy"
my '57 rebuild:
http://www.thesamba.com/vw/forum/viewtopic.php?t=369883 |
MichaelTucson Samba Member
Joined: February 07, 2008 Posts: 9 Location: Binghamton, NY
Posted: Mon May 17, 2010 8:09 pm Post subject: Bahia red ('71) code? |
Does anyone know a PPG code for Bahia red? (vw code L30E).
Mike |
themobilenotary Samba Member
Joined: May 23, 2007 Posts: 51 Location: Torrance, CA
Posted: Tue May 25, 2010 8:47 pm Post subject: Re: Dove Blue in Valspar or PPG? |
Sanny wrote: |
Dove Blue VW Color L-31
RGB 144 176 232
HEX 90BOE8
PPG Code 11668
Craig _________________ 1958 Single Cab
1970 Fastback |
Posted: Fri Sep 24, 2010 1:05 pm Post subject: Re: Bahia red ('71) code? |
MichaelTucson wrote: |
Mike |
For reference for anyone, the PPG code for Bahia Red ('71, L30E) is 71852.
I saw that on page 1 of this topic, someone had posted a link to a site where you can look them up. Don't mean to be redundant, but since it looks like a bunch of us missed that link, here it is again:
http://tcpglobal.com/autocolorlibrary/acl_files/volkswagen.html _________________ '63 Ghia
'71 Super Vert
'71 Ghia |
jb17atita Samba Member
Joined: June 06, 2010 Posts: 58 Location: Caracas, Venezuela
Posted: Thu Feb 17, 2011 9:04 am Post subject: Re: Dove Blue in Valspar or PPG? |
themobilenotary wrote: |
Sanny wrote: |
RGB 144 176 232
HEX 90BOE8
PPG Code 11668
Craig |
Nice!!
By any chance won't you have those codes for L35 - Metallic Blue? |
Davemccabrio Samba Member
Posted: Thu Apr 14, 2011 6:04 am Post subject: L274 code |
Does anyone have the codes/ formula for L274 Sand Beige? Need it for my wheels, and I need it soon!
Thanks! |
cavi21 Samba Member
Joined: April 22, 2010 Posts: 6 Location: Buenos Aires
Posted: Tue Jun 07, 2011 1:31 pm Post subject: |
If you need any color information that was made with Glasurit, you have in their webpage all the mixin information, it's really easy to use.
You have to put in Manufacturer Volkswagen, then select the year and write the color in the "color name box", there are more options too.
Then you click in the search button and will show you the colors, click over the color you need the mixin, then below select Line and after that click in the "next button", you will have all the information you want!
I hope this help anyone
http://coloronline.glasurit.com/
That's the link. |
David Samba Member
Joined: June 29, 2004 Posts: 2027 Location: Raleigh, NC
Posted: Thu Sep 01, 2011 7:18 pm Post subject: |
cavi21 wrote: |
That's the link. |
Thank you, this is very helpful! There's a guy over in the Oval forums looking for this information. _________________ Cheers,
Dave
*October '54 Ragtop
Stuggi Samba Member
Joined: October 16, 2007 Posts: 1208 Location: Jakobstad, Finland
flawedmasterpiece Samba Member
Posted: Sun Oct 30, 2011 6:40 am Post subject: dupont to glasurit |
Hello,
I am finally ready for paint on my 56 ragtop after more than 5 years of "when I can weekends". I did a trade with a fellow that is the towns best paint and restoration guy and he will be painting it for no charge to me. Problem is we can not find a conversion from the Glasurit Polar Silver (L324) to Dupont paints. I was wondering if there is anyone out there that has painted one in a close color and might have a corresponding code for me. Any assistance will be helpful as always. I will also post this in Oval section but wanted to post it here to cover my bases.
Thanks |
Bill Sullivan Samba Member
Joined: January 18, 2012 Posts: 878 Location: Georgetown, SC
Posted: Fri Apr 06, 2012 6:09 am Post subject: Need Wild Westner paint codes |
for 1973 transporter ... Do not find it on vw color chart. Tks Bill |
ppgpaintlady Samba Member
Posted: Fri May 11, 2012 12:57 pm Post subject: Bordeaux Red L51 - PPG Mixing Code |
I need your help, my painter cannot find a PPG Mixing code/formula for L51 Bordeaux Red.
Any help would be appreciated.
thx.
---The only one I found was for a 1984 VW BORDEAUX RED PPG#51884 OEM#LB3A.
Hope that helps! |
Posted: Fri May 11, 2012 1:01 pm Post subject: Re: Dove Blue in Valspar or PPG? |
Sanny wrote: |
As there are a few on file, for Dove Blue. It would be best to take a piece with you to make sure they can mix the correct color. |
Posted: Fri May 11, 2012 1:06 pm Post subject: Re: Bahia red ('71) code? |
Mike |
http://tcpglobal.com/autocolorlibrary/acl_files/volkswagen.html |
code has since changed to PPG#2698 |
Posted: Fri May 11, 2012 1:12 pm Post subject: Re: L99D |
boxofrox2 wrote: |
Was wondering if L99D is available. |
PPG info = Topaz Poly 1975-1976 -->#2886 and yes! |
Austin16V Samba Member
Posted: Mon Jun 18, 2012 7:05 am Post subject: L21 Mixing codes |
Hi,
My local paint shop have no codes for L21 (pearl Grey).
I am after some 2K and some cellulose.
They use ICI for 2K and Maxmayer for celly.
Any help appreciated!
Thanks |
