dexit Samba Member
Posted: Sun Jul 26, 2009 5:50 am Post subject: |
my friend ask me to check this lenses, but thanx to this topic - i don't need any answers
greetings from belgrade,
dean
Scotty Samba Member
Joined: July 02, 2003 Posts: 1525 Location: Northampton - Uk
Posted: Tue Jan 26, 2010 6:49 am Post subject: |
Anchovy wrote: |
Here is a working list of lens type and year. Please feel free to update as you see fit.
To summarize:
1949 - 1950? = Large sliver, no logos.
1950? - 1952? = Large sliver, Hella logo only.
1952? - 1953 = Large sliver, Hella and squiggly.
1953 - 1954 = Small sliver, Hella and squiggly. |
I believe the lenses are the same from beginning of production until the end of 52 - large silver no logos. My 52 (may) had lenses without any logos on prior to me owning it. For sale picture:
I guess what we need to confirm is when the hella logo appeared (very beginning of 53?) and when the squiggle appeared _________________
EverettB wrote: |
http://scottys-stuff.blogspot.com/ |
SplitPersonality Samba Member
Joined: September 26, 2004 Posts: 630 Location: Norway
Posted: Thu Feb 04, 2010 2:48 pm Post subject: I found some NOS headlamps - 4 styles |
From some old stock at a dealership I have a load of bus headlamps. At least three of these are for a Barndoor and they are all the same style..
Part number: 211 941 021 A
Narrow sliver, VW logo opposite sliver, no "NL"-mark...
From what VIN/date to what VIN/date were these used??
There are also 3 other styles of non-Barndoor lenses....check my pics in the "Parts - Bus"-gallery. I would appreciate to hear the use-dates for the three other styles as well.
Part numbers for the 3 newer styles:
211 941 021 D
211 941 039 A
211 941 040
Thank you in forehand! |
tazm Samba Member
Posted: Thu Feb 04, 2010 10:26 pm Post subject: |
Oysteyn,
IMO this is not a barndoor headlight t Check the date stamps on the bucket and reflector, I think late 55 or 56
Regards,
Guido |
Ed Economy Samba Member
Joined: January 08, 2006 Posts: 302 Location: Lost In LA
Posted: Fri Jul 02, 2010 8:15 am Post subject: Early bus headlight reflectors |
This week I purchased a large load of misc nos parts, In this load there was a nice pile of early bus headlight pieces & parts. Most items mainly the reflectors are Hella. None of my books (later) show the reflector part numbers I have. I know they are from the 50’s possible early 60’s
Some are wrapped in VW cardboard 211 941 152, More in the vw blue box 211 941 151 A , Large stack no box 211 941 152A They all take the early bulb holders same as split? There are a few odd one with no part numbers. I was wondering if any of these are barndoor. I looked thru all the headlight threads but there is nothing on just reflectors.
Panelvan Samba Member
Posted: Sun Jan 09, 2011 12:51 pm Post subject: |
Hi
Recently found on a 54 barndoor.
Small hella logo and snake,a line cross the lense.
"oben" stamped on the top
On the bottom , stamped
AGREE AB/TP 512
I-63636
GERMANY
IMPORTE D'ALLEMAGNE
Both were with stamped hella ring , single rivet and drain hole
Could it be original lense ???? or aftermarket ???? or......????
_________________ http://rascal.skynetblogs.be/ |
janerick3 Samba Member
Posted: Sun Jan 09, 2011 9:16 pm Post subject: |
French market lenses--possibly correct for the '54. This was covered in another thread on the Oval Window forum recently, which stated they were '52-only.
http://www.thesamba.com/vw/forum/viewtopic.php?t=441558
What are the date codes printed on the bucket(s)? They shouldn't be later than mid-'54. _________________ Thanks,
Jan K. |
Posted: Mon Jan 10, 2011 12:37 am Post subject: |
Oh interesting , the headlights were on a French bus.
The single rivet and hella logo
Typ 180EO25-2r
K 1019
For sure I21
Don't really visible for the first letter or number but after ...136J
phil1957 Samba Member
Joined: July 10, 2006 Posts: 231 Location: montreal, Quebec
Posted: Tue Jan 11, 2011 7:04 am Post subject: |
anyone know what year these lenses are for?
Kais Collection vintage treasures
Joined: February 18, 2005 Posts: 1570 Location: Rotterdam, The Netherlands
Douglas711 Samba Member
Joined: June 21, 2006 Posts: 272 Location: Riverside, CA
Posted: Tue Aug 23, 2011 10:30 pm Post subject: Re: Is this BD |
I'm guessing 1954 or 1955. However, the seller isn't showing any clear pictures of the bucket or markings, so I'm betting it's off the non-BD '55 he is parting out. _________________ Thanks,
Jan K. |
FritzCP Samba Member
Joined: October 23, 2005 Posts: 463 Location: Wisconsin
Posted: Tue Jul 23, 2013 10:31 am Post subject: |
I found this bucket. It looks like US Spec Barndoor bucket, but the lens is fluted. There is VW stamped in the glass at the top, and on the bottom is a Bosch symbol, as well as a Bosch written in script. I didnt see these lenses posted, any ideas on origin?
trim ring is single rivet, hella stamped with screws at 5 and 7 o'clock.
note the glass is installed upside down. _________________ Fritz Custom Products
Fritz 10 - Tin Screw Torquer
Fritz 124 - Crank Pulley Puller
Fritz 70 - 6306 Bearing Puller
Fritz 44 - Dizzy Puller |
Posted: Tue Jul 23, 2013 8:55 pm Post subject: |
The lens is circa 1955-60 Bosch Type 1, not original to the Hella design bucket.
Does the rim have a drain hole on the side?
Is there a date code (not visible in the pictures) stamped in white paint near the springs? It should have a letter, followed by 2 to 4 numbers.
Are the plated pivot arms marked "Links" (left) or "Rechts" (right)?
If this is truly a barndoor sealed-beam bucket, it has to be one of the earliest produced (1953 or early 1954). I have only seen one other barndoor sealed-beam assembly (late '54-'55) and it was on a '67 bus. _________________ Thanks,
Jan K.
Scotty Samba Member
Posted: Wed Jul 24, 2013 12:51 am Post subject: |
It's not a bus headlight, the fluting in the glass is 90 degrees out. That's from a beetle _________________
EverettB wrote: |
Posted: Wed Jul 24, 2013 7:59 am Post subject: |
Quote: |
Does the rim have a drain hole on the side? |
Yes it has a drain hole making it a drivers side (LHD) bucket
Quote: |
Is there a date code (not visible in the pictures) stamped in white paint near the springs? It should have a letter, followed by 2 to 4 numbers. |
there is no date code paint marks anywhere around the black painted bucket
Quote: |
Are the plated pivot arms marked "Links" (left) or "Rechts" (right)? |
No, the outer pivot arm is not marked but "links" is printed on the inner headlight housing (see pic). the pivot arms do look like they are right and left specific do to tab shape.
Posted: Thu Jul 25, 2013 6:44 am Post subject: |
volksheime wrote: |
The date stamp is barely visible next to the fingertip in the picture.
If it contains an "L" = 1953, "M" = 1954
In any case, this is a genuine early barndoor sealed-beam bucket! _________________ Thanks,
Jan K. |
Posted: Thu Jul 25, 2013 8:05 am Post subject: |
holy cow good eye on seeing that!
Ive been staring at it, and its definitaly an L followed by 4 numbers, I believe are 1218 _________________ Fritz Custom Products
Posted: Thu Jul 25, 2013 9:49 pm Post subject: |
L1218 = Dec '53. The date codes on these pre-Dec '54 buckets with no Hella logo either have the "18" or they don't. _________________ Thanks,
Jan K. |
Scotty Samba Member
Posted: Fri Jul 26, 2013 12:54 am Post subject: |
I stand corrected, the lens confused me.... _________________
EverettB wrote: |
