1955ccbug Samba Member
Joined: October 03, 2004 Posts: 730 Location: Olympia wa
Posted: Thu Jun 25, 2009 7:49 am Post subject: |
Do you guys use anything on the oil pump to pump cover gaskets? I used a ultra light film of gray RTV last time and still get drips. Or do you install them dry? Thanks. BTW, this is a brand new CB pump and cover..I'd hope it wasn't warped, but I didn't check. |
busman78 Samba Member
Joined: August 17, 2004 Posts: 4520 Location: Oklahoma City, OK
Posted: Thu Jun 25, 2009 9:29 am Post subject: |
Best to check the cover and pump body on a flat surface with some 220 grit wet with a light oil and figure 8 it till it is flat. |
Posted: Sun Jun 28, 2009 9:34 am Post subject: |
Sealant on the oil pump cover gasket? |
Sigurd Samba Member
Joined: April 18, 2006 Posts: 2639 Location: Rockford, IL
Posted: Sun Jun 28, 2009 9:41 am Post subject: |
I would. |
GeorgeL Samba Member
Posted: Sun Jun 28, 2009 3:13 pm Post subject: |
1955ccbug wrote: |
A thin film of Hylomar wouldn't hurt. My Meximotor arrived with what looked suspiciously like Hylomar on the case joint and just about every gasket joint. It hasn't leaked yet. |
Posted: Fri Jul 03, 2009 10:34 pm Post subject: |
Thank you. |
Lag_Smurf Samba Member
Posted: Sat Jul 18, 2009 1:12 pm Post subject: |
Here's a case study:
http://www.ehylomar.com/Sealing-VW-Engine-with-Hylomar-UB?sc=7&category=34
Please note that Hylomar comes in several different formulations.
Universal Blue is the acetone-solvent formula which will thicken after application. You can get it from Harley Davidson dealers under part number 99653-85.
Racing formula (RF) has lower viscosity and will also thicken. It uses the same acetone solvent as Universal Blue It is the one commonly marketed through Harbor Freight and other automotive sources. Permatex has recently begun distributing this formula in blister packs.
Advanced Formula (AF or HPF) is runnier still and does not thicken. It is available in tubes or brush-top cans, but is harder to find. This is the formula previously distributed by Permatex.
Aerograde (PL-32) is the original Rolls Royce formulation with methylene chloride solvent. It's expensive and can't be sold in some states with wussy environmental regulations. In these states you will find it with acetone solvent as Aerograde Ultra.
So, which one to use? I've used them all and while they have different consistencies they all seem to seal well. My personal preference is the Universal Blue whose higher viscosity makes getting a thin but even layer on a joint surface easier. It think it really boils down to what you get used to.
Most of these come in squeeze tubes of either 35ml (1.2 ounce) or 75ml (3.0 ounce) capacity. These look the same in photographs, so be sure of which one you are looking at when buying. Prices are all over the place, too, so shop around and don't forget to add shipping costs to the total. Hylomar isn't that hard to find these days, but some sellers still think that those little tubes are made of gold. |
Stuggi Samba Member
Joined: October 16, 2007 Posts: 1208 Location: Jakobstad, Finland
Posted: Mon Aug 24, 2009 5:08 am Post subject: |
Sigurd wrote: |
To my knowledge, there are no paper gaskets for the bigger cylinders. When I did my 94s, I dabbed a little on the lip that sits on the case. Don't put any on the part of the cylinder that slides into the case. |
Ever heard of gasket paper? Cut out the shape you need, smear both sides and the sealing surfaces with Permatex Aviation and off you go. _________________ 1970 Beetle
1969 Panelvan
Orange VW Fest!
Pulled out of a Lake Fest! |
Sigurd Samba Member
Posted: Tue Aug 25, 2009 7:39 am Post subject: |
Hm. I hadn't thought of that. My 3/4 side is doing fine with red RTV, but the 1/2 side didn't like the RTV for some reason. |
Sigurd Samba Member
Posted: Thu Sep 10, 2009 5:55 am Post subject: |
I figured out why the one side was leaking. The front edge of the cylinder bores were all 0.008" lower than the rear edge. The cylinders were tipped towards the front! Now that it's been re-bored, I'll probably use the RTV again.
I will place another vote for Curil T. The stuff literally melts away with brake cleaner and a paper towel. No leaks on the parting line either. |
Stuggi Samba Member
Sigurd Samba Member
Posted: Fri Sep 11, 2009 6:45 am Post subject: |
I'm only using it because Permatex Aviation and paper gaskets leaked on my singleport. Would Curil T work here instead? |
Stuggi Samba Member
Posted: Fri Sep 11, 2009 10:24 am Post subject: |
Dunno, I have no experience with Curil T, but it seems to have good rep around here.
Permatex Aviation is IMHO the best stuff, seals everything really nice. I usually coat both sides of the gasket (if used) and the sealing surfaces, nice "thick" layer. _________________ 1970 Beetle
1969 Panelvan
Orange VW Fest!
modok Samba Member
Joined: October 30, 2009 Posts: 26779 Location: Colorado Springs
Posted: Fri Mar 05, 2010 10:36 pm Post subject: |
In reverence of all this heated sealant bla bla bla, I conducted my own experiment last year.
I sealed the case halves of my engine together with....................Ketchup.
Yes ketchup.
I'm not kidding.
I've been driving it long enough that I think the results are in.
So, what do you think happened?
Guess the outcome of my experiment!! |
Sanny Samba Member
Joined: August 18, 2008 Posts: 159 Location: Los Osos, Ca
Posted: Fri Mar 05, 2010 11:03 pm Post subject: |
uuuhhh..... the engine produced an order of fries? |
modok Samba Member
Posted: Fri Mar 05, 2010 11:05 pm Post subject: |
I wish.
I was going to use barbecue sauce at first, but I decided ketchup is more standardized. I prefer barbecue sauce myself. |
Sigurd Samba Member
Posted: Fri Mar 05, 2010 11:37 pm Post subject: |
It's so nuts, I think it might have worked. |
Posted: Sat Mar 06, 2010 1:37 pm Post subject: |
Well, ketchup has a healthy dose of vinegar (acetic acid).
So, for well-cleaned case halves, they may well get a chemical reaction between the acid and the metal that results in a good solid seal. The reaction products on both sealing surfaces would occupy the same space and become one mass.
If it did, don't count on getting a good seal the second time. In fact, getting the cases split may be problematical if they become too well married by the chemical reaction!
Please, nobody tell GEX about this! |
modok Samba Member
Posted: Sat Mar 06, 2010 1:42 pm Post subject: |
WOW, that's profound.
I'm not sure I buy it though, silicone is chock full of this acid, and does not seem to do any harm.
I promise I will report back next time I split it.
Ok, the "acid theory" seems to warrant further study. |
