EverettB Administrator
Joined: April 11, 2000 Posts: 69809 Location: Phoenix Metro
Posted: Sat Jun 18, 2016 6:46 am Post subject: Re: 1954 & 1955 engines whats not correct! |
TheLadyBug wrote: |
I think I'm going to tackle adding the m6 weldnut to the clamps. Can I assume that the weldnut faces out? Can I see one up close actually in place? |
It faces out from the clamp:
The weld nut is the inside clamp though so when it's installed, the weld nut is toward the front of the car and if you are facing the engine you see the screw head.
(I have a feeling this is obvious to you but I figured why not be super clear anyway for others reading) _________________ How to Post Photos
TheLadyBug Samba Member
Joined: August 17, 2014 Posts: 639 Location: Saskatoon, Saskatchewan, Canada
Posted: Sun Jun 19, 2016 3:04 pm Post subject: Re: 1954 & 1955 engines whats not correct! |
EverettB wrote: |
TheLadyBug wrote: |
(I have a feeling this is obvious to you but I figured why not be super clear anyway for others reading) |
Thanks Everett. So in fact once installed, you cannot tell that there's a weldnut. _________________ Charmaine
1954 Beetle - because I can
2016 Golf highline - hubby’s daily
2016 Golf R - my daily |
txoval Samba Member
Joined: January 23, 2004 Posts: 3552 Location: The Woodlands, TX
Posted: Sun Jun 19, 2016 8:04 pm Post subject: Re: 1954 & 1955 engines whats not correct! |
Yes, exactly what I was getting at...l
If you're not worried about using the 54 Uterus intake manifold, this is minor |
Posted: Sun Jun 19, 2016 8:20 pm Post subject: Re: 1954 & 1955 engines whats not correct! |
txoval wrote: |
I want to actually drive the car. The uterus is such a catastrophic failure of a part... Buying one makes little to no sense _________________ Charmaine
Posted: Sun Jun 19, 2016 10:54 pm Post subject: Re: 1954 & 1955 engines whats not correct! |
TheLadyBug wrote: |
EverettB wrote: |
TheLadyBug wrote: |
Thanks Everett. So in fact once installed, you cannot tell that there's a weldnut. |
Yes but you KNOW
Plus you can tell just looking at the little screws from the front... if you are one of the crazy 1%ers that knows what you are looking at. _________________ How to Post Photos
Posted: Mon Jun 20, 2016 10:58 am Post subject: Re: 1954 & 1955 engines whats not correct! |
EverettB wrote: |
TheLadyBug wrote: |
EverettB wrote: |
TheLadyBug wrote: |
Yes but you KNOW
Plus you can tell just looking at the little screws from the front... if you are one of the crazy 1%ers that knows what you are looking at. |
Haha yup and that's why I'll go to the length to modify it I also went to great length to ensure the codes on my semaphore arms were correct. Will anyone see? Nope. I'll KNOW it's right heh. I'll pick up some of these m6 screws and have them plated black. _________________ Charmaine
splitjunkie Samba Member
Posted: Mon Jun 20, 2016 1:03 pm Post subject: Re: 1954 & 1955 engines whats not correct! |
TheLadyBug wrote: |
EverettB wrote: |
TheLadyBug wrote: |
EverettB wrote: |
TheLadyBug wrote: |
Yes but you KNOW
Haha yup and that's why I'll go to the length to modify it I also went to great length to ensure the codes on my semaphore arms were correct. Will anyone see? Nope. I'll KNOW it's right heh. I'll pick up some of these m6 screws and have them plated black. |
They should be either cad or zinc plated. You are looking for Cheese head screw. Fillister is a close head shape but it has a slightly rounded top surface whereas a Cheese head screw is flat on top. _________________ Chris
RockStock Samba Member
Joined: November 26, 2004 Posts: 3924 Location: England
Posted: Tue Jun 21, 2016 8:52 am Post subject: Pipe clamp screws |
Quote: |
They should be either cad or zinc plated |
No, black. Early and late. Unless you have some evidence... _________________ -StockRocks- |
motofly196 Samba Member
Joined: June 01, 2008 Posts: 1467 Location: Eastern WA
Posted: Tue Jun 21, 2016 8:55 am Post subject: Re: 1954 & 1955 engines whats not correct! |
This thread is getting to be too much...
Tube brackets= painted black
Screw= Cad plated |
Posted: Tue Jun 21, 2016 9:12 am Post subject: Re: Pipe clamp screws |
RockStock wrote: |
No, black. Early and late. Unless you have some evidence... |
I meant the screws are plated and the brackets painted black. _________________ Chris
Posted: Tue Jun 21, 2016 9:20 am Post subject: Re: Pipe clamp screws |
splitjunkie wrote: |
RockStock wrote: |
I meant the screws are plated and the brackets painted black. |
I meant the screws are black and the brackets are black. I even entered the Post Subject ^^ _________________ -StockRocks- |
carnut63 Samba Member
Joined: May 14, 2009 Posts: 336 Location: Murrieta, CA & Everett, WA
Posted: Tue Jun 21, 2016 4:47 pm Post subject: Re: 1954 & 1955 engines whats not correct! |
All this talk about these brackets make me want to go out there and put mine on with JB Weld. _________________ Tyson
---> Mar 2 1955 Strato Silver Oval <---
---> July 1957 ragtop project <---
---> May 5 1966 Ghia <---
---> 1962 Ruby Red Deluxe (sold) |
1sqr2nv Samba Member
Joined: October 21, 2004 Posts: 73 Location: SJB, Ca.
Posted: Thu Jun 23, 2016 9:12 pm Post subject: Re: 1954 & 1955 engines whats not correct! |
"^Someone may know straight off, but you could start with verifying your engine number/date"
Here is a picture below of my engine number. The car has an early pan with heater knob behind ebrake, bullet front fenders and snowflakes.
Posted: Thu Jun 23, 2016 10:18 pm Post subject: Re: 1954 & 1955 engines whats not correct! |
Did your engine have some performance parts on it? Or just the bypass filter? |
Posted: Fri Jun 24, 2016 8:51 am Post subject: Re: 1954 & 1955 engines whats not correct! |
motofly196 wrote: |
Just the bypass. |
bavarian1 Samba Member
Posted: Fri Sep 30, 2016 11:18 am Post subject: Re: 1954 & 1955 engines whats not correct! |
Looks like a resistor maybe added to the coil? I assume the wire has broken off, any ideas? |
nlorntson Crazy VW Lady
Joined: March 13, 2004 Posts: 3783 Location: Twin Cities, MN
Posted: Fri Sep 30, 2016 11:32 am Post subject: Re: 1954 & 1955 engines whats not correct! |
Noise suppression for a radio. |
Joined: April 27, 2002 Posts: 6371 Location: Pentwater, Michigan
Posted: Sun Oct 02, 2016 7:27 pm Post subject: Re: 1954 & 1955 engines whats not correct! |
The resistors usually came as part of a larger kit. There may be more resistors on the car, at the generator and radio. _________________ Roads Scholar &
1961 (October)Single Cab- Road Trip Workhorse |
Chrisisw Samba Member
Joined: May 30, 2004 Posts: 148 Location: Amsterdam, Holland, Europe
Posted: Fri Sep 08, 2017 3:31 am Post subject: Re: 1954 & 1955 engines whats not correct! |
This winter I will tear apart the engine of my January 1954 and build it up again using all, period correct, reconditioned parts that I have collected over the years.
One question to the experts: the generator strap, should this be painted or not?
Thanks, Chris |
