nlorntson Crazy VW Lady
Joined: March 13, 2004 Posts: 3776 Location: Twin Cities, MN
Posted: Mon Jun 13, 2016 2:12 pm Post subject: Re: 30hp fuel pump tinware |
RockStock wrote: |
^^Thanks
30hp pump drip tray tinware...two versions
Which is early?
When was the change?
The one on the left with no long channel is 25hp I think. 36hp has a channel.
RockStock Samba Member
Joined: November 26, 2004 Posts: 3921 Location: England
Posted: Mon Jun 13, 2016 3:45 pm Post subject: Re: 1954 & 1955 engines whats not correct! |
I have the channelled tin on a 56/7 engine. _________________ -StockRocks-
EverettB Administrator
Joined: April 11, 2000 Posts: 69734 Location: Phoenix Metro
Posted: Mon Jun 13, 2016 5:23 pm Post subject: Re: 30hp fuel pump tinware |
RockStock wrote: |
^^Thanks
Which is early?
I don't see this listed in Progressive Refinements but I do believe this extended into 1954 for some time (at least)
The left one is earlier. _________________ How to Post Photos
txoval Samba Member
Joined: January 23, 2004 Posts: 3540 Location: The Woodlands, TX
Posted: Mon Jun 13, 2016 6:58 pm Post subject: Re: 1954 & 1955 engines whats not correct! |
The one on the left is what is on my November 54 |
laneven28 Samba Member
Joined: January 09, 2007 Posts: 312 Location: Cedar Hills, Utah
Posted: Tue Jun 14, 2016 8:33 am Post subject: Re: 1954 & 1955 engines whats not correct! |
I have a January 55 with the smooth cup _________________ 1950 Pearl Grey Hoffman Standard Split Window
1954 Iceland Green Euro 3-Fold Oval
1955 Strato Silver Transitional 3-Fold Oval
1956 Iris Blue Convertible
1958 Pearl White Lowlight KG Convertible
1961 Turkis Ragtop |
TheLadyBug Samba Member
Joined: August 17, 2014 Posts: 639 Location: Saskatoon, Saskatchewan, Canada
Posted: Tue Jun 14, 2016 9:40 am Post subject: Re: 1954 & 1955 engines whats not correct! |
Well that's crappy for me; the piece I have had the groove. Glad to have seen this. I guess I get to spend even more on engine tin! Lucky me. _________________ Charmaine
1954 Beetle - because I can
2016 Golf highline - hubby’s daily
2016 Golf R - my daily |
1sqr2nv Samba Member
Joined: October 21, 2004 Posts: 73 Location: SJB, Ca.
Posted: Tue Jun 14, 2016 11:44 am Post subject: Re: 1954 & 1955 engines whats not correct! |
My car is a May of 55. I believe everything to be somewhat original. The engine is set up with late 55/56 tin etc.. Is this set up correct?
Posted: Wed Jun 15, 2016 12:34 am Post subject: Re: 1954 & 1955 engines whats not correct! |
^Someone may know straight off, but you could start with verifying your engine number/date.
Then can research using Progressive Refinements/Engine section (ie look for top pulley nut size reduction note, or oil filler pipe design change note)
http://oacdp.org/progref4061.html _________________ -StockRocks- |
Posted: Wed Jun 15, 2016 12:46 am Post subject: 30hp plug lead pipe clamps |
Drip tray, thanks for chiming in with your versions & dates. Useful - plse add to this, anyone.
Here's another good one
Plug lead pipe clamps...two versions
Early version (right/bottom) has a weld nut on the back bracket with a precise machine screw similar to (but longer than) a tinware screw. These are on my June 54 engine.
Late version, no weldnut, traditional screw. Smaller hole on front bracket.
As usual, early version is nicer! When was the change?
You can tell which version you have by looking at the screw head. Is it shallow and rounded, or deeper and square shouldered? _________________ -StockRocks- |
Posted: Wed Jun 15, 2016 7:47 am Post subject: Re: 1954 & 1955 engines whats not correct! |
1sqr2nv wrote: |
I don't think it is original. I believe your engine should resemble a 54 engine in May of 55, not the 56/57 which it appears to be.
Pulleys are different, big nut, fuel pump, regulator should be round. But the best way to check would be looking in the progressive refinements. But please get that fuel filter out of the engine bay.
Rock stock. Way to go. Now I need to find older versions of those little plug wire tube clamps.
Here's my shameless plea for both the under fuel pump tin and those clamps if anyone has extra. _________________ Charmaine
txoval Samba Member
Posted: Wed Jun 15, 2016 7:07 pm Post subject: Re: 1954 & 1955 engines whats not correct! |
LadyBug, I know you are very particular, but you could easily modify the plug wire clamps to resemble the other version. Just trying help you
They could also be swapped out later if needed...driving these cars is more fun then building them |
3foldfolly Samba Member
Joined: March 08, 2009 Posts: 894 Location: Edwardsville, Il
Posted: Wed Jun 15, 2016 7:18 pm Post subject: Re: 1954 & 1955 engines whats not correct! |
txoval wrote: |
Every time she looks at them she'll know they aren't correct. She has to be able to sleep at night. I think that's admirable. |
txoval Samba Member
Posted: Wed Jun 15, 2016 9:10 pm Post subject: Re: 1954 & 1955 engines whats not correct! |
I never said it wasn't admirable...but if these clamps cause someone to lose sleep (not saying that's the case) they need real help.
I would also rather run an incorrect part then my car be undriveable...not that these clamps would stop the car from running. |
Posted: Wed Jun 15, 2016 11:00 pm Post subject: Re: 1954 & 1955 engines whats not correct! |
TheLadyBug wrote: |
1sqr2nv wrote: |
Here's my shameless plea for both the under fuel pump tin and those clamps if anyone has extra. |
[code]My engine number is 1082913 |
Posted: Thu Jun 16, 2016 7:00 am Post subject: Re: 1954 & 1955 engines whats not correct! |
3foldfolly wrote: |
txoval wrote: |
See, I frequently don't sleep at night so I do lay in bed thinking about the car. Last night my kids slept awesome so naturally I was wide awake with allergies. Thinking about finding more stuff for the car. It's half the fun is the excitement when you find what you're looking for.
I considered adding the speednut to the clamps I have. I assume it's m6. _________________ Charmaine
txoval Samba Member
Posted: Thu Jun 16, 2016 2:45 pm Post subject: Re: 1954 & 1955 engines whats not correct! |
I'd imagine M6 would be too big for that one...probably M5
Oops, the OP said similar to tin screws, so M6
Posted: Thu Jun 16, 2016 7:53 pm Post subject: Re: 1954 & 1955 engines whats not correct! |
m6 x 1mm pitch |
Posted: Fri Jun 17, 2016 7:13 pm Post subject: Re: 1954 & 1955 engines whats not correct! |
[quote="TheLadyBug"][quote="3foldfolly"][quote="txoval"]
Posted: Sat Jun 18, 2016 3:07 am Post subject: Re: 1954 & 1955 engines whats not correct! |
3foldfolly wrote: |
TheLadyBug wrote: |
See, I frequently don't sleep at night so I do lay in bed thinking about the car. |
Omg this is exactly me.
It's 4am here.
I hope I don't need to be certified as crazy.
I think I'm going to tackle adding the m6 weldnut to the clamps. Can I assume that the weldnut faces out? Can I see one up close actually in place? _________________ Charmaine
