PASHN8 Samba Member
Joined: January 30, 2011 Posts: 152 Location: Melbourne, Australia
Posted: Tue Nov 04, 2014 4:32 pm Post subject: |
EverettB wrote: |
It looks great.
Are you going to run a fake regulator to complete the look or convert a round regulator to 12v? |
Thanks Everett
Funnily enough i've started a thread here to try and work out the best way to do it ->http://www.thesamba.com/vw/forum/viewtopic.php?t=611326
I'm not sure the method to convert the reg, nor am I sure which is the correct reg to use if keeping the original as a dummy? _________________ www.dinography.com.au - Dino!
1957 11-Window Split Bus
1954 3-fold Sunroof Oval Beetle
*** Looking for '56 Porsche T1 356A 1300 engine no. 22373 *** |
RockStock Samba Member
Joined: November 26, 2004 Posts: 3929 Location: England
Posted: Fri Oct 09, 2015 1:38 pm Post subject: |
_________________ -StockRocks- |
OgCalLook Samba Member
janerick3 Samba Member
Posted: Sat Oct 10, 2015 11:41 am Post subject: |
It has the 25hp oil filler cap, so I'm guessing this is from 1953... _________________ Thanks,
Jan K. |
splitjunkie Samba Member
Posted: Sat Oct 10, 2015 11:56 am Post subject: |
'53 -'55 had the clip on oil cap with the dimple but was longer than the earlier non clip/dimple 25 hp version. I can't tell from the picture which one but the distributor on that engine has a vacuum advance so it can't be a '53 because it would have the centrifugal only distributor if it were a '53. _________________ Chris
Posted: Sat Oct 10, 2015 12:02 pm Post subject: |
Its got the round regulator. Its got the holed coil bracket. 30hp.
So I class that as right to go in the 54/55 Engine Thread.
Boy you guys are harsh. Derek is right to hesitate. _________________ -StockRocks- |
Posted: Sun Oct 25, 2015 12:08 pm Post subject: |
Cool clear period Speedwell (Pepco?) -supercharged 30hp pic
Big spring, offset round regulator, fat-lip top pulley (marked), wire-clip distributor, fan-housing ink... _________________ -StockRocks-
Posted: Sun Oct 25, 2015 7:02 pm Post subject: |
it even has the "uterus" manifold. _________________ Chris
EverettB Administrator
Joined: April 11, 2000 Posts: 69823 Location: Phoenix Metro
Posted: Mon Oct 26, 2015 4:00 am Post subject: |
EverettB wrote: |
What do you mean by fan-housing ink? |
motofly196 Samba Member
Joined: June 01, 2008 Posts: 1467 Location: Eastern WA
Posted: Mon Oct 26, 2015 6:28 am Post subject: |
Dang...that inner belt is SO close to the generator pulley/nut. How close does it get when the engine is revved? That is a really sweet set-up!!! I like how the regulator was raised to clear the supercharger!!! NICE work! |
Posted: Mon Oct 26, 2015 8:39 am Post subject: |
Im sure fan-housing markings have been discussed somewhere...they rub off very easily so most have been lost?
Is that charger Speedwell or Pepco? They look similar.
Here's a recent shot of a Pepco in a 55 Barndoor. Good detail of a 54/5 30hp from another angle. I always think the long pump>carb fuel line looks a bit odd. Curved on the oval's engine.
Telephunken Samba Member
Joined: November 23, 2004 Posts: 274 Location: Northern California
Posted: Sun Dec 27, 2015 11:07 pm Post subject: Re: 1954 & 1955 engines whats not correct! |
Awesome thread. One of the most informative ive ever read. I know this is a replay to an older posting, but id like to add to what someone posted earlier about the strap style air cleaners vs. The "two clip" type.
I think janerick3 said that both knecht and Mann types were used in both 54 and 55. However, People keep saying that others have the "wrong air cleaner, that it should be the single strap type...."
I fan further confirm what janerick3 said. I have two "TWO clip" style cleaners, and one is date stamped 12/54 and the other is date stamped 8/55. Both are the exact Mann "two clip" air cleaners, not the single strap style.
Btw, does any one know what the smaller sized Mann air cleaners are from. I have a very original one that has the decal still on it. Its a Mann, but smaller in diameter than my other ones.....?? |
Joined: April 27, 2002 Posts: 6371 Location: Pentwater, Michigan
Posted: Thu Dec 31, 2015 6:35 pm Post subject: Re: 1954 & 1955 engines whats not correct! |
Interesting that a Speedwell engine would still run a DVDA beetle distributor. It's dated between December 1953 and July 1954 based upon the fact that there is a separation between the vacuum pipe port and the rest of the vacuum canister body. The other pic also had the vacuum advance but I cannot tell its vintage from the large scale photo. _________________ Roads Scholar &
1961 (October)Single Cab- Road Trip Workhorse |
Posted: Thu Dec 31, 2015 6:46 pm Post subject: Re: 1954 & 1955 engines whats not correct! |
The only factory ink stamp on a 36 hp fan shroud that I have ever seen is this one:
Just to the right of the oil fill. It's M 178 and I have to be very careful not to clean that area aggressively as I accidentally washed the stamp off the front side without even realizing it the first time I cleaned it. M 178 represents Speed Governor which was installed but rarely on buses only.
The distributor on the Barndoor Speedwell is either an 010 or 019 based on the badge. They were not manufactured until the mid 1960's. I would have chosen either a VJ 4 BR 2, 3 or 8 or perhaps a 1960 only VJ 4 BR 25 as more period correct for a Barny. _________________ Roads Scholar &
Posted: Mon Feb 22, 2016 9:27 am Post subject: Re: 1954 & 1955 engines whats not correct! |
Nice restored 54/55 engine in a double-door bus.
Cant pick out too many differences from factory! Filter sticker, silver lower pulley nut, silver top pulley washers, blue coil?
Wondering if the tank>pump fuelpipe should have a gentler, uniform rear curve.
Posted: Mon Jun 13, 2016 10:57 am Post subject: 30hp fuel pump tinware |
^^Thanks
30hp pump drip tray tinware...two versions
Which is early?
When was the change?
Posted: Mon Jun 13, 2016 12:25 pm Post subject: |
EverettB wrote: |
RockStock wrote: |
EverettB wrote: |
This is what I suspected but what did that or what does that indicate?
What is the significance of that mark? |
While a split, this is from a 1952 Road and Track article and clearly shows an F and what appears to be an A on the shroud.
