vwboop Samba Member
Joined: April 04, 2004 Posts: 716 Location: Langley, BC
Posted: Sat Nov 28, 2009 6:36 pm Post subject: |
Visiting a friend today. His rottisserie goes off the bumper mounts and door hinge
_________________ "Love and good roads" |
johnny fever Samba Member
Joined: June 09, 2006 Posts: 28 Location: Beaver, Oregon
Posted: Sun Nov 29, 2009 6:43 pm Post subject: |
The upper brace runs along the drip rail and has a bend in it to match the bend in the rail. Because of the bend it wouldn't work flipped to the other side. You would have to rig a second set of mounting brackets and make another rail support for the other side. Possible, but not practical. On the double cab it simply ran past the end of the cab a way. And there is a lower brace as well. I'll have to PM Mike and see if he has any pics of his Dbl cab on the rig.
I get the concern about sandblasting. But I am using aircraft stripper and scraping the paint off, so the minor inconvenience is acceptable to me. This isn't going to be a show bus just a solid daily driver with a nice paint job. Nuttin' fancy. |
mtb7001 Samba Member
Joined: February 11, 2009 Posts: 899 Location: Meridian Idaho
Posted: Sun Nov 29, 2009 7:13 pm Post subject: |
Glad this thread popped back up, my issue is a supertight 2 car garage both width and length wise, of course I can leave one car out for side to side action but have no room to roll the "octo hoop" style back and forth ( I assume it's hard to scoot across the shop) I'm also too tight for the "end" style rotisseries (my front bumper is 4 ft from my bench). So I was real glad to see this one, wheels on the bottom and changing the side bars to allow for wheels while on it's side would be easy enough, and the lower bars don't stick out far enough to rip a shin... nice, I'm leaning this way. Johnny Fever could you tell me when the bus is leaned at a 45' angle what is the distance from floor to the highest point?, yes my garage ceiling is low too.
And what are doing with a mannequin in your shop? _________________ 63 15 window deluxe Turkis walk through 1500
"comfort the afflicted, afflict the comfortable" |
Posted: Mon Nov 30, 2009 4:11 am Post subject: |
Well, the real purpose of the shop is making surfboards. And mannequins are a great addition to any surfboard shop. They provide such good entertainment. They (there are 2 actually) kindly model my tee shirts and hold my shaping hat and mask. Great employees.
I'll try to measure the bus on the 45 tonight. I am able to roll it in a pretty narrow space but I do kind of wish it had wheels on the flip side. |
Posted: Tue Dec 01, 2009 4:15 am Post subject: |
Bus height while on a 45 is right at 7 ft. to the top corner of the drip rail. |
Charlie48ida Samba Member
BEANS Samba Member
Joined: April 13, 2006 Posts: 36 Location: Pittsburgh, PA
Posted: Sat Dec 26, 2009 7:06 pm Post subject: |
Finally got mine mounted up, and back home. I'll be starting a build thread here soon once the replacement metal starts coming in.
raul arrese Samba Member
Joined: July 23, 2006 Posts: 1330 Location: miami florida
Posted: Fri Mar 19, 2010 6:59 pm Post subject: |
good job to every one!!!! |
dubshack1 Samba Member
Posted: Mon Apr 05, 2010 8:34 pm Post subject: |
Anyone here know Andy Douglass from westfeild Indiana? |
krautwaggen Samba Member
Bendango Samba Member
Posted: Wed May 26, 2010 3:41 am Post subject: |
Rebirth - Beans (anyone else using the octagonal rotissarie)
Do these Rotissaries fit in one peice onto a Kombi or do they need to be fitted
in part to the Suspension mountings then have the 2nd part welded once in place?
I'm strugling to see it sliding on (especially in the rear) and in the first post - the octagon was cut in half.
Thanks!
Can't wait to do the job properly on the under side of the 61. _________________ I want a real garage.
WANTED - [WTB] 55-62 Bus Thin Lip Package Tray SWR
Getting Used - SWR 60 westy copy built by vw ( apparently )
http://www.thesamba.com/vw/forum/viewtopic.php?t=320866
Braukuche wrote: |
Where did you find the elephant dick? |
Posted: Fri Jul 09, 2010 11:22 am Post subject: |
Took some time - but fun building massive rings + even more fun rolling!
Mine's made with 50mm x 50mm but only 2mm wall thickness. I was worried it would'nt hold up so I added some supports at the top like someone suggested earlier ( don't tighten them too tight mine started to dent the roof a little)
Make working on it a pleasure even though mines not got much rust it was still worth it and now can sand blast it + I think the work will be finished better.
Cheers for all the info on this thread! _________________ I want a real garage.
Braukuche wrote: |
WrennMetallWerks Samba Member
Joined: December 06, 2007 Posts: 2655 Location: Rescue ca
silvertonguedevil Samba Member
Joined: September 26, 2010 Posts: 1692 Location: Vale, OR
Posted: Sat Dec 04, 2010 3:37 pm Post subject: |
TheResurrectionProject wrote: |
Hey Jason, what would you charge to make one of these? _________________ -Greg |
bill may Samba Member
Joined: August 27, 2003 Posts: 14160 Location: san diego,ca
Posted: Sat Dec 04, 2010 3:51 pm Post subject: |
bherder wrote: |
sled wrote: |
in the hands of a professional wire feed welder, yes I am sure he could put one together safely. In the hands of a novice home welder, I would HIGHLY suggest a 220 welder.
better to be safe than sorry, you wouldnt want this thing to collapse and smash your bus (and/or a person) |
That answers my question. Guess I'm buying a 220. I assume the 220 will dial down enough to mimic the lowest setting on the 110? I have a miller 110 and would get an equivalent 220. |
i use a miller 200 mig. it goes low enough for vw sheetmetal. _________________ Admin note: Bill Passed away - July, 2017
1965 panel bus-Kermit
"Camping is cheaper than therapy"
www.sv2s.com
www.steeringboxscrapers.net
SBS #100
http://www.thesamba.com/vw/forum/viewtopic.php?t=453617 |
ratherb-buggin Samba Member
Joined: January 30, 2005 Posts: 986 Location: Shawnee, KS
Posted: Thu Dec 09, 2010 11:39 am Post subject: |
Corey, any chance of getting plans or measurements on this one??
Two other friends and I would like to build one to rotate use on... no pun intended! haha |
Randall Samba Member
Joined: October 03, 2004 Posts: 1403 Location: Orange County, Alta California, El Norte
IN2RUST Samba Member
Joined: October 30, 2005 Posts: 1942 Location: West Coast
Posted: Thu Dec 09, 2010 5:29 pm Post subject: |
YUM! _________________ RUSTFARMER....I like anything old and rusty! |
tferr Samba Member
Posted: Sat Dec 11, 2010 10:32 am Post subject: |
I am having trouble figureing out my rear mount for my rotisserie. This is my front mount
Where do people mount to at the rear
Thanks |
j.pickens Samba Member
Joined: December 03, 2002 Posts: 9791 Location: Exit 7, New Jersey
Posted: Sun Dec 12, 2010 12:25 pm Post subject: |
Torsion spring mounting point or tranny horns.
The tranny horns probably need additional bracing if you're going to carry the entire weight of the bus.
Mine mounts on the torsion spring points. _________________ Founder and Chairman Emeritus, ECMSAS
BeaterBarndoor wrote: |
i wish more people would actually drive their vws rather than just talking about what they have in the garage. |
Red Fau Veh wrote: |
If you've seen one sunroof swivel seat kombi, you've seen them all! |
