snookerdude Samba Member
Joined: June 30, 2004 Posts: 914 Location: central florida
Posted: Wed Apr 19, 2006 8:45 pm Post subject: engine compartment cardboard |
the cardboard insert that goes beside the battery and hides the fender well is held up with metal bend over tabs that are spot welded to the underside of the read deck frame. the tabs are broked off one the drivers side and i don't want to do a repair that would be paint envasive like spot welding or screwing or pop riviting. the only idea i have so far is to j b weld some replacement tabs on it. anyone addressed this problem before.. ain't it fun??? |
Gary Person of Interest
Joined: November 01, 2002 Posts: 17069 Location: 127.0.0.1
Posted: Wed Apr 19, 2006 9:04 pm Post subject: |
I would weld in new tabs and secure the material with screws. Screw this JB Weld hack job nonsense.
Then again, that's just me. _________________ West Virginia State Board of Education v. Barnette, 319 U.S. 624 (1943) |
70 140 Samba Member
Joined: September 22, 2002 Posts: 8471 Location: Ontario Canada
Posted: Thu Apr 20, 2006 8:07 am Post subject: |
my tabs are all still there, I just don't have the fiberboard. I was actually contemplating taking them out and making some aluminum panels to fit in. |
Posted: Thu Apr 20, 2006 8:08 am Post subject: |
70 140 wrote: |
I've seen that done, but aluminum scratches easily. Just an observation and not a criticism. _________________ West Virginia State Board of Education v. Barnette, 319 U.S. 624 (1943) |
Posted: Thu Apr 20, 2006 8:13 am Post subject: engine compartment cardboard |
my ghia will have a paint job needed in the next couple of years but not at this time. ICY: a weld will require grinding/smoothing and painting that will have to be addressed on the outside skin of the car too. don't want to go there until the car gets a paint job. at that time i can remove any hack job for the good job. by fastening "the material" with screws did you mean the cardboard? thanks for your response. dave aint it fun? |
Posted: Thu Apr 20, 2006 8:25 am Post subject: cardboard |
got a suggestion from another forum site. velcro.. sounds like a good nonenvasive, temporary soultion.... ain't it fun??? |
Buggeroff Argumentative Bastard
Joined: October 16, 2004 Posts: 1124 Location: Lake of the Ozarks, Missouri
Posted: Thu Apr 20, 2006 10:36 pm Post subject: Re: cardboard |
snookerdude wrote: |
Rivet. _________________ "Chris of the Ozarks"
Headlinerless 57 Ghia
Thread deleter extrordinaire. |
Karmann Gheezer Samba Member
Posted: Fri Jul 22, 2016 8:55 am Post subject: Re: engine compartment cardboard |
Bringing an old thread from the dead.
When the clips broke off or the cardboard inserts got wet these would most often get discarded.
Anyone making these with cardboard like the originals?
I like the velcro idea.
NOVA Airhead Samba Member
Joined: July 20, 2005 Posts: 5221 Location: Richmond, VA
Posted: Fri Jul 22, 2016 12:33 pm Post subject: Re: engine compartment cardboard |
The ones on my current Ghia are in good shape. However this was not the case on my last Ghia where they were missing.
I had found some roofing material at Home Depot that was a pretty close match. Cut and fitted it.
This was a while ago so I have no idea if they still have it but you might want to take a look at the roofing material they have there. I used a heavy tar like material used for capping the peak on a roof. _________________ Ghia Owner Emeritus |
SoCalJes Samba Member
Joined: November 02, 2011 Posts: 1093 Location: Broward, FL
Posted: Fri Jul 22, 2016 1:19 pm Post subject: Re: engine compartment cardboard |
Why not use a rivet? Paint the rivet and it will disappear, when you decide to paint the car remove the rivet, weld it back grind it smooth and paint. _________________ Jesse
71 Ghia
______________________________________
Just because it didn't come that way, doesn't mean it shouldn't have. |
