supermanbidder Samba Member
Randy in Maine Samba Member
Posted: Mon Mar 04, 2013 2:10 pm Post subject: |
I would not a clue what you are trying to measure there.
On my Type 4 engine it is in this taco plate inspection cover that my buddy Phil made for me....
Posted: Mon Mar 04, 2013 10:02 pm Post subject: SERIOUSLY I NEED HELP??? |
thats not on my engine i had come across it doing an image search and i just wanted some people to tell me what they thought .. i have no idea where i can put my oil temp sensor ??? i heat that putting it in the drain plug gives inaccurate readings , i dont have an external filter setup ,,, and my engine is already together rebuilt so i can mod the case in front like i have seen some do SERIOUSLY I NEED HELP??? has anyone modded the oil filter pump to ad a sensor somehow i have a maxi 2 pump ? |
neil68 Samba Member
Joined: March 17, 2007 Posts: 3440 Location: Calgary, Canada
Posted: Mon Mar 04, 2013 10:30 pm Post subject: Re: SERIOUSLY I NEED HELP??? |
supermanbidder wrote: |
If you don't mind me repeating what I posted earlier in this thread, there is way too much unsubstantiated talk about "accurate" readings and "better" sender positions. I haven't found any substantial temperature difference between the various senders (I have not used that adaptor sender that ACN sells, but it looks fine as well).
Just think about it for a minute: some are saying that you need the sender in the external filter mount to measure oil that has come from the sump via the oil pick-up tube just a few seconds ago (very little cooling occurs during the journey through the oil line to the filter-mount sender).
In your situation, I would not bother modifying the combination oil-filter pump (as it's the same situation...oil has just been sucked up from the sump). Just use a dipstick sender, or VDO oil-relief sender, or one of the sump senders...that's all you really need. _________________ Neil.
Der Kleiner Rennwagens
68 Beetle 2332 cc, 204 WHP
12.5 seconds @ 107 mph
Dynojet Test: https://www.youtube.com/watch?v=M9B_H3eklAo |
Glenn73 Samba Member
Joined: May 30, 2011 Posts: 1190 Location: West Jordan UT
Posted: Tue Mar 05, 2013 8:56 am Post subject: |
Actually it would not give you either CHT or OT. |
flyboat Samba Member
Posted: Tue Mar 05, 2013 11:59 am Post subject: |
It has a receiver for the factory head temp sensor. I don't recall the calibration. I believe it was only on the FI engines as part of the signal to send more fuel or less, _________________ 79 super Vert
62 Ragtop Bug
66 tintop Westy
Porsche 914
09 Z06 Vette track car |
FV195 Samba Member
Joined: February 19, 2005 Posts: 480 Location: carlisile, pa
Posted: Tue Mar 05, 2013 12:58 pm Post subject: |
ok, had a sender in my deep sump, no reading at all? switched to relife sender, good readings, haven't checked against another source.
cht stays stady even when oil changes.
think sump was not grounded real well |
Posted: Tue Mar 05, 2013 1:45 pm Post subject: |
That is for the Temp Sensor II which is required with FI (to let the ECU know if the engine is warm or cold to adjust the fuel mixture).
It is not a suitable location if you are trying to monitor the cylinder head test though.
Some of us use these for that purpose.....
http://www.dakotadigital.com/index.cfm/page/ptype=...cat248.htm
and the sender is located at the spark plug. |
Posted: Tue Mar 05, 2013 2:55 pm Post subject: |
Im thinking if i put the sensor in the drain plug it should have some sort of shield put around it to protect it from damage and to block it also from cooling air while driving |
carl4x4 Samba Member
Joined: March 20, 2012 Posts: 679 Location: United Kingdom
Posted: Tue Mar 05, 2013 4:17 pm Post subject: |
CSP sell something that do just that:
_________________ 1969 UK Karmann Ghia build http://www.thesamba.com/vw/forum/viewtopic.php?t=518789&highlight= |
Hotrodvw Samba Member
Posted: Tue Mar 05, 2013 4:43 pm Post subject: |
But it's finned for cooling? _________________ '67 Sunroof
Eric
78x94 with IDA's....oober fun
Horsepower is an addiction........Addictions cost
lots of money!
Hose & Fittings |
Posted: Wed Mar 06, 2013 4:29 am Post subject: |
Don't worry about it. |
fory Samba Member
Joined: October 23, 2011 Posts: 166 Location: McKinleyville, CA
Posted: Wed Mar 13, 2013 8:24 pm Post subject: |
I saw this asked earlier in the thread with no response to it.... I read on the vw-resource website that they say to use the drain plug sensor on a single relief case... why is this? They give no reason...
I run my sender in the relief valve on my single relief case and I have no temp reading issues or oil pressure issues to my knowledge (I only run the dummy light for pressure though)... If this was such a bad spot for a sender, why would VDO, of all manufacturers, offer this as an option? They seem to be one of the best, next to (old) SW..
I do agree with previous statements that 100% accuracy is neither possible nor nesseccary... All I want to know is when its warmed up, and when I need to pull over at the next stop and let it cool off. Usually it me thats overheating before my Bug anyways... _________________ Drive fast, take chances, pass on the right!! |
Posted: Wed Mar 13, 2013 8:50 pm Post subject: |
I've noticed most if not all manufacturers will have you mount their product in a bolt on fashion. I think this is to keep the liability to a minimum as well as the appeal to the buyer. When you have to get out the big tools, it kills curb appeal. I'm guessing VDO said "hey, oil goes here, let's put a sender there!". _________________ '67 Sunroof
Eric
lots of money!
Hose & Fittings |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31361 Location: Hot Arizona
Posted: Thu Mar 14, 2013 12:13 pm Post subject: |
I installed my temperature sending unit in the oil drain pan in 1976. Yes, it did break once, but no oil leaked out, and I threaded one in from VDO and it has worked fine.
I say that one isn't really looking for a specific degree that's bad, but more likely looking for a temperature increase that's out of your normal.
That's what they're good for, same as coolant gauge in a traditional vehicle. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Posted: Thu Mar 14, 2013 8:46 pm Post subject: |
Cusser. How did you break it once ?... Just wondering because i am using a sump talk also so im worried about it being to low |
skapunkfoo Samba Member
Joined: November 02, 2012 Posts: 150 Location: Wherever the Army sends me.
Posted: Thu Apr 18, 2013 4:14 pm Post subject: |
here is the location of my oil temp sensor.
Is this a good spot? I seem to get good readings.
yes i know the engine is dirty. _________________ 1964 Beetle
VW Challenge - come join the fun.
http://www.thesamba.com/vw/forum/viewtopic.php?t=592483 |
Posted: Thu Apr 18, 2013 9:39 pm Post subject: |
skapunkfoo wrote: |
yes i know the engine is dirty. |
Is it good? Have you compared it to anything else? That will tell you if it's any good for approriate readings. _________________ '67 Sunroof
Eric
lots of money!
Hose & Fittings |
