old DKP driver Samba Member
Joined: March 30, 2005 Posts: 4145 Location: Los Gatos,Ca.
Posted: Wed Jul 27, 2016 9:44 pm Post subject: Re: The Tire Sticky |
I will post this again since Brian is more interested in BIG ASS Tires...
Looking for info on these tires purchased recently and how you rate them.
Nexen SV820's
Hankook RA18s
Vanco 2s
I have Vanco 8's on my Bus but,they are getting old and i need to replace
them.....I don't drive the bus many miles per year.
Thanks. Chris _________________ V.W.owner since 1967 |
DenverB Samba Member
Joined: July 23, 2012 Posts: 704 Location: Denver, Colorado
Posted: Tue Aug 02, 2016 7:51 am Post subject: Re: The Tire Sticky |
What tire pressure are people running on their grabbers. The 20 7X8.5 14s, that is? _________________ -------
'77 Transporter/camper (Bussy - Reef Blue/Pastel White)
'67 bug (Santos - VW Blue)
'84 Vanagon Westfalia (Pink Flamingo - Pastel White/Pink)
'88 Vanagon GL Westfalia (Frankie Says - Wolfram Gray)
'02 Eurovan Weekender (Green Apple)
'95-'03 Eurovan full campers and weekenders (rental fleet)
'84 -'91 Vanagon full campers and weekenders (rental fleet)
'72 Porsche 914 (Greta - RIP)
www.RockyMountainCampervans.com |
Randy in Maine Samba Member
Posted: Tue Aug 02, 2016 12:04 pm Post subject: Re: The Tire Sticky |
Start with the stock pressures. 30 up front and 44 in the rear. |
Alan Brase Samba Member
Joined: March 28, 2004 Posts: 4532 Location: Cedar Falls, Iowa
Posted: Tue Aug 02, 2016 2:38 pm Post subject: Re: The Tire Sticky |
So, what (if any) of the newly available tires has anyone tried and liked or disliked?
I've seen some Ranger/Thunderer brand, I think in 185R and 195R-14 sizes. several others.
Last summer, I bought a set of Goform brand 185R-14 from Tires-Easy $282 delivered in Iowa.
I put them on my 71 Dormie, which was basically sold, so I only drove them perhaps 100 miles. they looked to be a commercial/ highway mileage tread, not so much an all weather tire. But they looked the part and drove very good for what I could tell.
I have Vanagons, a bay or two, and a couple splitties, so whatever tires I buy can be moved to any of these 3 models, with some rim changing.
I need to buy some very soon.
that would be my main use- highway miles good conditions.
Al _________________ Al Brase
Projects: 67 sunroof bug, 67 Porsche 912 Targa, 70 Westy
Dec 1955 Single Cab pickup WANT 15" BUS RIMS dated 8/55, thru 12/55
To New owners: 1969 doublecab, 1971 Dormobile
Vanagons:
80 P27 Westy JUL 1979, 3rd oldest known US
83 1.6TD Vanagon, 87 Wolfie Westy daily driver, swap meet home |
cdennisg Samba Member
Joined: November 02, 2004 Posts: 20278 Location: Sandpoint, ID
Posted: Tue Aug 02, 2016 7:43 pm Post subject: Re: The Tire Sticky |
Randy in Maine wrote: |
Is that what the sticker on a 77 says for tire pressures? _________________ nothing |
Posted: Wed Aug 03, 2016 11:48 am Post subject: Re: The Tire Sticky |
cdennisg wrote: |
Is that what the sticker on a 77 says for tire pressures? |
Posted: Thu Aug 04, 2016 3:51 pm Post subject: Re: The Tire Sticky |
I did and I'm at 44 and 30 - but that's based on a stock tire size. While they are the correct rating, grabbers are not that size. _________________ -------
Posted: Thu Aug 04, 2016 7:59 pm Post subject: Re: The Tire Sticky |
Size doesn't matter. |
Posted: Fri Aug 05, 2016 1:39 pm Post subject: Re: The Tire Sticky |
40 years of improvement in tire technology does. _________________ nothing |
Posted: Fri Aug 05, 2016 4:24 pm Post subject: Re: The Tire Sticky |
cdennisg wrote: |
40 years of improvement in tire technology does. |
What improvements would those be? |
Posted: Fri Aug 05, 2016 5:49 pm Post subject: Re: The Tire Sticky |
cdennisg wrote: |
Surely you don't expect the tires that came on that shiny new 77 Westy are built with the same design/materials/technology as what is available today?
I am not a tire engineer, but I am confident there is an obvious difference in tires made today compared to those made 40 years ago. Are you? _________________ nothing |
Posted: Sat Aug 06, 2016 6:15 am Post subject: Re: The Tire Sticky |
I certainly cannot think of any that involve air pressures. |
Posted: Sat Aug 06, 2016 10:31 am Post subject: Re: The Tire Sticky |
If I go by the recommended tire pressures on my 68 single cab with Wrangler HT's, or my 70 camper with BFG's, the steering is way too heavy. 28 PSI may have been great with the rock hard rubber compounds back then, but not anymore. _________________ nothing |
Posted: Wed Aug 10, 2016 9:51 am Post subject: Re: The Tire Sticky |
size doesn't matter?
hmm.. well, on my vanagons the stickers show that different tire sizes (185 and 205) require different pressures that range as much as 10 PSI. Yeah, a vanagon isn't a bus... but the principle would be the same.
so...
I'll ask again: what pressure are people running their gRabber AT 27s at on their buses. _________________ -------
Posted: Wed Aug 10, 2016 12:47 pm Post subject: Re: The Tire Sticky |
DenverB wrote: |
so...
I'll ask again: what pressure are people running their gRabber AT 27s at on their buses. |
That sticker might just be a little irrelevant. There is not a single place in the US you can buy a 205/70R-14 6pr load range C tire. Nobody has sold "C" rated tire 205/70-14 in a decade.
The higher aspect ratio tires, there are MANY RATED tires with enough load rating to carry a loaded type 2. (they are always labeled 185R-14. I do not know why, but in that size they do not label the aspect ratio, so it is understood to be "80".)
The inflation always seems to work better for me if kept in about the same front/ rear bias. If you put as much air in the front as in the rear, the contact patch in front will be much smaller than the rear and the front end will be skittish.
Next time you have some spare time and a crosswind, try some experimentation yourself. Start out with equal pressure on all 4 tires, make a pass each direction, then drop the front pressure about 4 lbs. Try it again. I think a bay usually works best with about 10 more psi in the rear than the front.
Vanagons:
Posted: Wed Aug 10, 2016 3:50 pm Post subject: Re: The Tire Sticky |
Agreed you are comparing apples ("commercial" 6 ply rated tires 185R14Cs good to about 65 psi) to oranges (205/70/14 passenger tires although they are extra load and may be inflated to about 42 psi).
It is not the size, it is the meat. |
Posted: Wed Aug 10, 2016 4:12 pm Post subject: Re: The Tire Sticky |
DenverB wrote: |
so...
I believe the Grabbers to be very similar in construction to the BFG's. Given that possibility, I am running 40 PSI front/45 PSI rear on my 70 camper with good results on my BFG's of the same size. I have run them both as much as 10 PSI lower, but this seems where the bus is most happy. _________________ nothing |
Posted: Wed Aug 10, 2016 6:45 pm Post subject: Re: The Tire Sticky |
cdennisg wrote: |
DenverB wrote: |
so...
I believe the Grabbers to be very similar in construction to the BFG's. Given that possibility, I am running 40 PSI front/45 PSI rear on my 70 camper with good results on my BFG's of the same size. I have run them both as much as 10 PSI lower, but this seems where the bus is most happy. |
Thank you. This is the type of feedback I was looking for. _________________ -------
airforceSF Samba Member
Joined: April 13, 2016 Posts: 18 Location: Great falls, Montana
Posted: Sat Aug 13, 2016 9:17 pm Post subject: Re: The Tire Sticky |
Anyone running general grabbers, how are they doing? Looking at getting a pair. I live in Montana and the summer winds and winter snow are bad here. Need something to help with both. |
Posted: Sat Aug 13, 2016 10:23 pm Post subject: Re: The Tire Sticky |
airforceSF wrote: |
I am guessing they won't be that great in the cold, dry snow you get in Great Falls. If you're gonna drive it much in those conditions, you need some real snow tires. The grabbers will be excellent for the other three seasons, though. _________________ nothing |
