Tcash Samba Member
Posted: Fri Jul 08, 2016 10:29 am Post subject: Re: The Tire Sticky |
iratehippie wrote: |
Tcash wrote: |
Note that those are Passenger car tires?
Tcash |
HUH? 195x14 D/8PR LT or Van/Bus NOT passenger tires... |
The add that you linked to Double King DK218
195R14 D/, list the tire as a passenger tire. With no specifications listed.
http://www.tires-direct.com/cgi-bin/rshop.pl?dsco=...ountry=BUS
This ad appears to list a different tire DK218 195R14C-8PR, the DK218 is the same but the suffix is different.
http://www.doublekinggroup.com/article/201110/67.html
So to conclude the tire you listed and the proceeding tire listed may not be the same tire. I can only go off the ad that you listed as a passenger tire.
What are the markings on the side of the tires that you purchased?
Sincerely
Tcash |
iratehippie Samba Member
Joined: April 21, 2002 Posts: 401 Location: high on southern oregon mountaintop...
Posted: Fri Jul 08, 2016 12:16 pm Post subject: Re: The Tire Sticky |
Sincerely
Tcash[/quote]
195R14 LT 8PR
105/103S
Load Range D
Tread 2poly/2steel
Sidewall 2poly _________________ 1972 westy
Type IV 1700/w Prog. Weber
"Tune in, Turn On, Dropout", Idiots school of VW Philosophy |
Tcash Samba Member
Posted: Fri Jul 08, 2016 1:33 pm Post subject: Re: The Tire Sticky |
Tcash wrote: |
Sincerely
Tcash |
195R14 LT 8PR
105/103S
Load Range D
Tread 2poly/2steel
Sidewall 2poly |
Cool they are a LT [light truck] tire not a Passenger tire with a load range of [D].
Must have been a misprint on the link.
GD
Tcash |
Hikelite Samba Member
Joined: August 31, 2012 Posts: 557 Location: Colville, WA
Posted: Fri Jul 08, 2016 3:25 pm Post subject: Re: The Tire Sticky |
cdennisg wrote: |
Hikelite wrote: |
I've noticed the RA18's are very popular, so I pulled up the Hankook site.
They label it a "Summer" tire. wth?
Just the fact that it's not all season makes it less appealing to me.
Do the folks running these only take the Bus out during good weather?
I'm thinking they must suck in the snow? |
Most tires I have used that are labeled as "mud and snow" or "all season" suck in the mud and snow, too.
The RA18 is not designed to be used in anything other than summer driving conditions, but they will probably handle some adversity. Having them siped would help, too.
Many folks only drive their VW's in good weather because they don't want them to get beat up and rusty. |
I live in WA, so I think it's wise to get an all-season tire.
I don't need them immediately, so I am not deciding now. I'll admit I'm a LOT overwhelmed by how many tires you can find searching the internet. Maybe when the time comes, I will just go to the local shop and see what he can get me _________________ ~Kevin
My 1968 Campmobile |
71whitewesty Samba Member
Joined: February 25, 2010 Posts: 1544 Location: oregon
Posted: Fri Jul 08, 2016 7:30 pm Post subject: Re: The Tire Sticky |
I have the R-A08s on both busses. I think they're great. They are quiet, stiff and work great for most conditions. Used to have the Michelin ltx's on there and were also great but no longer made. The Hankooks get me anywhere when it's dry but real slick mud or sand can be a problem. But for 99% of the driving they work really well. In the winter I either throw a set of studs on the back or carry the studded tires with me, one on the front and one in the rear spot. I think they work just fine on wet roads.
20k on the most used set or r-18's and they seem to be holding up fine and wearing well. I would take a guess and say 20k left on them to be safe. _________________ 71 Westy 1600 DP, all stock Bus 1
1970's Snow Trac 1600 SP (sold 12/2016)
1968 Tucker sno cat, sold 2021
1969 Tucker Sno cat 542
2017 VW Alltrac
71 tin top stock 1600 DP (project but runs)
Twin 71 White Westy, Bus 2, that I pulled from a 15 year slumber in a dry eastern WA field in 2015.
1966 Sundial Camper "Boomer"
Last edited by 71whitewesty on Sat Jul 09, 2016 3:51 pm; edited 2 times in total |
richparker Samba Member
Joined: November 24, 2011 Posts: 6980 Location: Durango, CO
Posted: Fri Jul 08, 2016 9:03 pm Post subject: Re: The Tire Sticky |
71whitewesty wrote: |
I have the R-18's on both busses. The Hankooks get me anywhere when it's dry but real slick mud or sand can be a problem. |
The RA08s are also not the best in the mud, sand and snow. I think siping the RA18s would help.
Although I like the Grabbers I'm leaning towards the RA18s (siped) now. I do go off road but not like Stu. _________________ __________
’71 Westy build
Adventure thread
’65 Deluxe Build
’63 Deluxe Build |
vdubyah73 Samba Member
Joined: July 05, 2003 Posts: 2541 Location: somewhere in Texas, my house has wheels
Posted: Sat Jul 09, 2016 10:19 am Post subject: Re: The Tire Sticky |
I used to run the 195 RA08's up front and the Grabbers out back. Worked real well for me. Would always go, it would understeer in slick conditions but having learned to drive before FWD, understeer isn't much of an issue for everyday driving.
Bill _________________ burning down the house
73 bounty hunter, sold.
'77 transporter, junked had crotch rot.
Dubless, but have a CPR built stroker waiting for a new to me Beetle
'93 Fleetwood Bounder 34' |
DenverB Samba Member
Joined: July 23, 2012 Posts: 704 Location: Denver, Colorado
Posted: Sat Jul 16, 2016 10:00 am Post subject: Re: The Tire Sticky |
I"m a week into a new set of the grabber AT 27 8.5 14s on the bus and i freaking love them.
solid tire, tracks a bit at high speed but I think that's more me getting used to a stiffer/larger tire. Haven't had them off pavement yet, but they are screaming for it.
_________________ -------
'77 Transporter/camper (Bussy - Reef Blue/Pastel White)
'67 bug (Santos - VW Blue)
'84 Vanagon Westfalia (Pink Flamingo - Pastel White/Pink)
'88 Vanagon GL Westfalia (Frankie Says - Wolfram Gray)
'02 Eurovan Weekender (Green Apple)
'95-'03 Eurovan full campers and weekenders (rental fleet)
'84 -'91 Vanagon full campers and weekenders (rental fleet)
'72 Porsche 914 (Greta - RIP)
www.RockyMountainCampervans.com |
roadron Samba Member
Joined: October 15, 2004 Posts: 215 Location: taos new mexico
Posted: Sat Jul 16, 2016 11:51 am Post subject: Re: The Tire Sticky |
they will track a bit until the edges round off. takes a few thousand miles _________________ 73 WESTY SO72-6 with continental bed |
TiberiusConstantine Samba Member
Posted: Sun Jul 17, 2016 9:36 pm Post subject: Re: The Tire Sticky |
Hi all, newbie here. I had a question regarding the grabber AT 27 8.5 14s. Will they fit the stock rims? I bought new tires last year but am concerned about the load rating, just went into it all willy last time, these Grabbers look sweet.
thnx |
cdennisg Samba Member
Joined: November 02, 2004 Posts: 20271 Location: Sandpoint, ID
Posted: Sun Jul 17, 2016 9:52 pm Post subject: Re: The Tire Sticky |
TiberiusConstantine wrote: |
thnx |
Yes, they will fit the stock rims. The photo two posts above yours shows them mounted on stock 71-79 bay bus rims. _________________ nothing |
beatles4 Samba Member
Posted: Mon Jul 18, 2016 8:11 am Post subject: Re: The Tire Sticky |
thnx |
I can also confirm that they fit the stock wide 5 wheels too. _________________ Click to view image
http://www.vw-mplate.com/mplate2-27771.png |
GTV Samba Member
Posted: Mon Jul 18, 2016 9:27 pm Post subject: Re: The Tire Sticky |
Hey ya'll, I'm thinking about buying a wide 5 early bay that has already been lifted with 2.5" spindles up front and 2.5" lift plates in the rear. It currently is running some ugly wheels (too much offset) with 215/75/15's that look too small with the lift. I have a set of bus 15's that I think would look MUCH better and have a more favorable offset. So, what size tires could I jam in there with those wheels? Is a 235/75 possible? I'd like to go as tall and wide as possible without going nuts on more suspension modifications. Any help is appreciated, thank you _________________ EMPI Power Rules!
GTV Samba Member
Posted: Thu Jul 21, 2016 5:22 pm Post subject: Re: The Tire Sticky |
Hello?? Anyone tried 235/75's on a lifted bay with bus 15's? _________________ EMPI Power Rules! |
Randy in Maine Samba Member
Posted: Fri Jul 22, 2016 4:01 am Post subject: Re: The Tire Sticky |
Wow you must have an engine with a ton of torque to get those big tires up to hiway speeds! |
GTV Samba Member
Posted: Fri Jul 22, 2016 2:41 pm Post subject: Re: The Tire Sticky |
Randy in Maine wrote: |
Engine and gearing are fine, lets focus on tires _________________ EMPI Power Rules! |
Alan Brase Samba Member
Joined: March 28, 2004 Posts: 4532 Location: Cedar Falls, Iowa
Posted: Fri Jul 22, 2016 3:33 pm Post subject: Re: The Tire Sticky |
GTV wrote: |
Engine and gearing are fine, lets focus on tires |
That is the stupidest thing all day on theSamba!
TIRE DIAMETER= GEARING
DUHH. _________________ Al Brase
Projects: 67 sunroof bug, 67 Porsche 912 Targa, 70 Westy
Dec 1955 Single Cab pickup WANT 15" BUS RIMS dated 8/55, thru 12/55
To New owners: 1969 doublecab, 1971 Dormobile
Vanagons:
80 P27 Westy JUL 1979, 3rd oldest known US
83 1.6TD Vanagon, 87 Wolfie Westy daily driver, swap meet home |
GTV Samba Member
Posted: Fri Jul 22, 2016 3:37 pm Post subject: Re: The Tire Sticky |
69doublecab wrote: |
GTV wrote: |
DUHH. |
Ya. I know.
Don't worry yourself with my gearing or engine. This thread is about tires. _________________ EMPI Power Rules! |
old DKP driver Samba Member
Joined: March 30, 2005 Posts: 4145 Location: Los Gatos,Ca.
Posted: Fri Jul 22, 2016 7:30 pm Post subject: Re: The Tire Sticky |
Does anyone have any updates on recent purchases of,
1.Nexen SV820's
2.Hankook RA18's
3.Vanco 2's
These are the 3 brands i am debating about my purchase for new tires.
I have Vanco 8's on my Bus but, have not driven it more than 3,000 miles since putting them on in 2003
Thank's for any help - Chris _________________ V.W.owner since 1967 |
Brian Samba Moderator
Posted: Fri Jul 22, 2016 10:25 pm Post subject: Re: The Tire Sticky |
GTV wrote: |
Hello?? Anyone tried 235/75's on a lifted bay with bus 15's? |
Go 31s! _________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter |
