ewdb92 Samba Member
Joined: September 24, 2010 Posts: 502 Location: Plymouth, NH
Posted: Sat Jul 02, 2016 6:37 pm Post subject: Re: The Tire Sticky |
cdennisg wrote: |
ewdb92 wrote: |
All I can think when seeing this bus the other day is that the owner is asking for trouble with those tires and rims. They can't be good for a bus, right?
Other than the flat left front, why would he be asking for trouble? They make the bus look a bit silly, but they likely won't hurt anything. |
I admit to knowing little about low-profile tires, and to me, after all the tire recommendations and info in this thread, they jut don't seem like they could handle a bus. But you say they can? Interesting. Learn something everyday. _________________ Erik
71 Camper
http://zerotosixtyeventually.wordpress.com/ |
Hikelite Samba Member
Joined: August 31, 2012 Posts: 557 Location: Colville, WA
Posted: Sat Jul 02, 2016 7:10 pm Post subject: Re: The Tire Sticky |
cdennisg wrote: |
Hikelite wrote: |
I've noticed the RA18's are very popular, so I pulled up the Hankook site.
They label it a "Summer" tire. wth?
Just the fact that it's not all season makes it less appealing to me.
Do the folks running these only take the Bus out during good weather?
I'm thinking they must suck in the snow? |
Most tires I have used that are labeled as "mud and snow" or "all season" suck in the mud and snow, too.
The RA18 is not designed to be used in anything other than summer driving conditions, but they will probably handle some adversity. Having them siped would help, too.
Many folks only drive their VW's in good weather because they don't want them to get beat up and rusty. |
So is the general tire grabber the best option?
I tried to find a Michelin, but couldn't find anything in the right size and rating. _________________ ~Kevin
My 1968 Campmobile |
Manfred58sc Samba Member
Posted: Sat Jul 02, 2016 8:55 pm Post subject: Re: The Tire Sticky |
The Road Claws are doing OK on the rear but fading fast on the front. About 10K on them. Just had to rotate the fronts to the rear to get more out of the set. I'm guessing 12-15K miles will be about it. Otherwise no real issues _________________ Fat chick owner/operator |
beatles4 Samba Member
Posted: Sat Jul 02, 2016 9:29 pm Post subject: Re: The Tire Sticky |
Hikelite wrote: |
cdennisg wrote: |
Hikelite wrote: |
I tried to find a Michelin, but couldn't find anything in the right size and rating. |
I am happy with my General Grabber AT/2's. Price was right and they look great. _________________ Click to view image
http://www.vw-mplate.com/mplate2-27771.png |
chaosisme Samba Member
Joined: August 29, 2005 Posts: 1256 Location: Orange County, Ca
Posted: Sat Jul 02, 2016 10:18 pm Post subject: Re: The Tire Sticky |
beatles4 wrote: |
SamboSamba22 wrote: |
Well dang, I'm calling up the shop first thing tomorrow morning just to verify that don't have any left.
Looks like my option of the RA18's is looking pretty imminent.
I'd love to have some "meaty" tread tires for this Ozark red clay down here |
You can go with the General Grabbers in 27*8.5r14. They fit and look pretty good on stock wheels. Here is my bus with them as of a few days ago. The cost of the tires ended up being $400 plus mounting and balancing.
I need tires for my Westy, how do these compare to the RA08's in 195? I see that the load rating is different, the Generals are a C and the Hankooks are a D load rating, is that a huge difference? _________________ '65 1500 S [quareback]
'68 FI Sunroof Squareback
'70 Westy
OCT3 - Orange County Type 3's |
Posted: Sat Jul 02, 2016 10:36 pm Post subject: Re: The Tire Sticky |
Those tires are only available in 27*8.5r14 these days. They are a fair bit wider than the 195 width Hancooks. They are fine for me so far. The side wall isn't an issue and if I am not mistaken the owners manual says to go with C rated tires. D is a bit stiffer and in my opinion overkill. It all depends what you are after. If you want a generic stock replacement then the ra18 is most certainly a good stock replacement tire. I wanted a slightly beefier/aggressive tire to get me to camp sites and I wanted to minimize any issues with wet grass or mud. I am satisfied so far. _________________ Click to view image
cdennisg Samba Member
Joined: November 02, 2004 Posts: 20271 Location: Sandpoint, ID
ewdb92 wrote: |
cdennisg wrote: |
ewdb92 wrote: |
All I can think when seeing this bus the other day is that the owner is asking for trouble with those tires and rims. They can't be good for a bus, right? |
I admit to knowing little about low-profile tires, and to me, after all the tire recommendations and info in this thread, they jut don't seem like they could handle a bus. But you say they can? Interesting. Learn something everyday. |
Here's the thing. A bus "requires" a tire with a high load rating. But, what it really requires is a tire with a stiff sidewall. For a stock diameter tire the only way to get that stiff sidewall is with a D, C, or LT rated tire.
If you run a larger wheel diameter and a low profile tire, or you have a lowered bus and want a low profile tire with a stock-ish wheel size, you are getting a stiffer tire sidewall by default. Low profile tires have stiffer sidewalls simply by nature of their design.
This is my theory, and mine alone. Your results may vary. _________________ nothing |
khalimadeath Samba Member
Posted: Sun Jul 03, 2016 7:54 am Post subject: Re: The Tire Sticky |
Love my AT2's
_________________ The United States Constitution
(c) 1787. All Rights Reserved
1970 Bus Westfalia
1964 Kombi |
Posted: Sun Jul 03, 2016 12:07 pm Post subject: Re: The Tire Sticky |
Those AT2's look to off roadish for my taste.
I want good traction off the pavement too, but I prefer a style with less tread wrapping around the sidewall.
I want them for a 68 campmobile, so I'm going to running on the heavy side. Especially when we are in it full time.
So far I've only seen 2 tires being recommended, the Hankooks and the Grabbers. Apparently BFG and Michelin no longer make products suitable, so what are my other options? _________________ ~Kevin
Brian Samba Moderator
Posted: Sun Jul 03, 2016 1:37 pm Post subject: Re: The Tire Sticky |
$232 each! Uff Da _________________ nothing |
iratehippie Samba Member
Joined: April 21, 2002 Posts: 401 Location: high on southern oregon mountaintop...
Tcash Samba Member
Posted: Mon Jul 04, 2016 2:28 pm Post subject: Re: The Tire Sticky |
Note that those are Passenger car tires?
Tcash |
zabo Samba Member
Posted: Mon Jul 04, 2016 3:12 pm Post subject: Re: The Tire Sticky |
Tcash wrote: |
Tcash |
http://www.doublekinggroup.com/article/201110/67.html
what is "SINGLE EMBRYO MAXIMAL" _________________ 1960 6 volt sedan- 1978 adventurewagen
–wanted bill spreen atlanta dealer tag frame |
Posted: Mon Jul 04, 2016 4:05 pm Post subject: Re: The Tire Sticky |
bad chinese translation of single tire vs double tire? _________________ ~Kevin
Hiramhaus Samba Member
Posted: Wed Jul 06, 2016 8:49 am Post subject: Re: The Tire Sticky |
Cancelled _________________ 1969 Ghia
2016 Audi Q3
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 12721 Location: on a bike ride somewhere
Posted: Thu Jul 07, 2016 2:39 am Post subject: Re: The Tire Sticky |
A comparison of the Hankook 185 size with the 195 size:
I can't tell a difference.
Maybe the ride is a little softer, or they're just not as sensitive to inflation pressures with the thicker sidewall.
The extra half a cm of diameter will give me about 20 less rotations per mile, or about 300,000 fewer rotations on my cross-country drive this year. My wheel bearings thank me, but my wallet does not. I'll see if there is any fuel economy to be gained here.
www.airschooled.com |
skeesby Samba Member
Posted: Thu Jul 07, 2016 6:55 am Post subject: Re: The Tire Sticky |
Thanks for all the advice on this thread. Went with the Hankook 195s from ebay seller Fast lane Tires. Arrived quickly and will get them on today.
tootype2crazy Samba Member
Joined: October 08, 2007 Posts: 1276 Location: St. Louis Missouri
Posted: Thu Jul 07, 2016 3:00 pm Post subject: Re: The Tire Sticky |
cdennisg wrote: |
ewdb92 wrote: |
cdennisg wrote: |
ewdb92 wrote: |
This is my theory, and mine alone. Your results may vary. |
You are correct. The lower the sidewall, the higher the pressure the tire requires. High pressure means a very stiff tire. Large SUVs can be had from the factory with quite low profile tires and they don't have a problem. The bad part about very low profile tires is they absolutely destroy your suspension system in short order since the stock sidewall absorbs a great deal of shock from the road.
The more concerning matter on those wheels are in fact the wheels. Cheapo ebay wheels might not be tough enough to handle a bus's load forces because most of them are meant for jettas, golfs, and mercedes, with which the bus shares the same bolt pattern. _________________ air-cooled or nothing for me
1978 Sunroof Deluxe Bus (daily driver)
1978 Transporter (mom's, making into a camper)
1970 Single Cab 2.1 turbo/EFI 6 Rib, 78 front beam, vanagon backing plates on rear (project)
2001 GTI VR6 (wife's) |
Posted: Fri Jul 08, 2016 9:38 am Post subject: Re: The Tire Sticky |
Tcash wrote: |
Tcash |
HUH? 195x14 D/8PR LT or Van/Bus NOT passenger tires... _________________ 1972 westy
Type IV 1700/w Prog. Weber
"Tune in, Turn On, Dropout", Idiots school of VW Philosophy |
