Scorcho Samba Member
Joined: May 04, 2012 Posts: 386 Location: Chicago, IL
Posted: Tue Sep 08, 2015 6:22 pm Post subject: |
I ended up finding the Nexens at simpletire.com! Hopefully they get here soon |
Posted: Tue Sep 15, 2015 7:15 pm Post subject: |
Got the nexens today from simpletire! FYI if you get them shipped to an installer shipping is much less. Pepboys let me ship them to their store without me having them installed there |
srfndoc Samba Member
Posted: Sat Nov 07, 2015 8:46 am Post subject: |
Here's a 195R15C tire for $74.99. Made in Thailand and I cant find any reviews but the specs are great.
http://simpletire.com/catalog/product/104833 _________________ RPM=(MPH*336* (R&P*4th*1.26))/Tire Diameter in inches |
JohnnyRingo Samba Member
Joined: October 22, 2011 Posts: 415 Location: United States
Posted: Thu Nov 19, 2015 2:32 am Post subject: |
I bought these from simple tire.......d rated tire, bus drives ten times better with a radial rather than a bias ply.$350.00 shipped. |
Posted: Thu Nov 19, 2015 8:43 am Post subject: |
JohnnyRingo wrote: |
Give us a report back after you have some miles on them. The specs look great just weren't a lot of information about them out there. Also, do they fit in the walk thru spare tire well?
Thanks _________________ RPM=(MPH*336* (R&P*4th*1.26))/Tire Diameter in inches |
bubba Samba Member
Posted: Tue Dec 22, 2015 8:20 pm Post subject: |
srfndoc wrote: |
Thanks |
Any feed back on the tires?pictures? _________________ ***WANTED***
SO-23 Cargo net hooks...
for sale
curtain Bungee cords for SO23, 22, 33 ,34 ,35
http://www.thesamba.com/vw/classifieds/detail.php?id=1587591 |
Posted: Wed Dec 23, 2015 6:20 am Post subject: Re: 15" Radial Tires - Sizes and Vendors |
Tires are great so far............they balanced very well using weights on inside only........I recently installed dyno beads in front tires only just for the added assurance of tires. Had a big argument with customer service, I have a little viberation at 55-60 with beads.....they tried to tell me I should have used 4oz instead of 3oz.....if you look at their tire chart it suggested every tire under 205/75/15 to install 3oz.....my tires are 195/70/15 customer service argued that my tire was not listed in their tire chart and I should have used 4oz??????????? Think their just trying to justify and make a defense for their product if you ask me.........may take beads out, because I didn't have the viberation before. Tires look great on my swivel seat......hope to post a picture soon. |
bubba Samba Member
Posted: Wed Dec 23, 2015 6:28 am Post subject: Re: 15" Radial Tires - Sizes and Vendors |
Sorry... I have no idea what 'Beads" are, or what they do, or how they help? _________________ ***WANTED***
for sale
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24733 Location: Olympia Wash Rinse & Repeat
Posted: Mon Apr 11, 2016 1:13 pm Post subject: Re: 15" Radial Tires - Sizes and Vendors |
Anyone running these from Coker:
670-15 size, $223 each. Bias Ply look with Radial construction
bubba Samba Member
Posted: Tue Apr 12, 2016 7:33 am Post subject: Re: 15" Radial Tires - Sizes and Vendors |
Coker American Classic Collector Radial Tires 195/75-15
Anyone try these? Is a 1444 LB weight load good? bad for a bus? _________________ ***WANTED***
for sale
Posted: Tue Apr 12, 2016 7:38 am Post subject: Re: 15" Radial Tires - Sizes and Vendors |
bubba wrote: |
Anyone try these? Is a 1444 LB weight load good? bad for a bus? |
1525 Lbs. is the official tire load range for type 2. 1200 Lbs. for type 1, and totally sucks on a type 2 at high speed. So 1444 Lbs. would be a lot better than 1200 Lbs. and less than optimal than 1525 Lbs.. _________________ In Stereo, Where Available! |
mandraks Samba Member
Joined: November 28, 2004 Posts: 7047 Location: Lawrenceville, Ga
Posted: Tue Apr 12, 2016 7:42 am Post subject: Re: 15" Radial Tires - Sizes and Vendors |
bubba wrote: |
never bought any of these, but it do think they will make a good tire for a bus.
At the same time, i would probably buy the 6.70/15 radial best of both world. bias ply look and size, and radial construction. price is steep though _________________ regards
Uli
Posted: Tue Apr 12, 2016 9:08 am Post subject: Re: 15" Radial Tires - Sizes and Vendors |
If that is the small white wall radial they have, those are a bit on the small size for the outer diameter at 26.5". So a lower top speed.
Cooper Discoverer 195/15 radials would be better with load range of 1,565 Lbs. and have 80% profile, comes out to 27.28" diameter. So you have a narrow radial and slightly higher top speed if you put these on the rear axle, than if you installed stock 27" tire diameter. See if your local tire shop can get you some of those.
If you have the later 1962 thru 1967 wider rear wheel wells a 205/75r15 will fit fine and you can find them easier in 1,525 Lbs. or higher load range. Should be about a 27.11" outer diameter.
Here is a great on line tool for quickly calculating tire diameter and comparing sizes.
https://www.tacomaworld.com/tirecalc?tires=205-75r15-195-80r15
Or learn how to use a calculator. Say 205/75r15. 205 is width of tread, 75 is sidewall measurement in percentage of the tread width. So 205 x 75% = 153.75 mm, double that gives you the sidewall on each side of the rim. 2 x 153.75 = 307.50 mm. To turn that into inches divide by 25.4 mm which is 1 inch. 307.50 divided by 25.4 mm = 12.11 inches. Add 15 inches which is the rim diameter to 12.11 total side wall height and you get 27.11 inch outer diameter. _________________ In Stereo, Where Available! |
cdennisg Samba Member
Joined: November 02, 2004 Posts: 20271 Location: Sandpoint, ID
Posted: Tue Apr 12, 2016 9:14 am Post subject: Re: 15" Radial Tires - Sizes and Vendors |
Eric&Barb wrote: |
Cooper Discoverer 195/15 radials would be better with load range of 1,565 Lbs. and have 80% profile, comes out to 27.28" diameter. So you have a narrow radial and slightly higher top speed if you put these on the rear axle, than if you installed stock 27" tire diameter. See if your local tire shop can get you some of those. |
Pretty sure these are NLA. I have had several sets (one of which is on my 68 single cab right now) and they are an excellent tire. If I could find more, I would buy them. _________________ nothing |
bubba Samba Member
Posted: Tue Apr 12, 2016 7:06 pm Post subject: Re: 15" Radial Tires - Sizes and Vendors |
Those look like a great tire and a great price at near $77 bucks each. Posting the tire data now so anyone in the future can access this info.
Manufacturer/Model: Zetex CT-1000 All Season
Quantity: The price for this offer is for a SET of FOUR tires
Load Rating: Single (950 Kg/2090 Lbs) Dual (900 KG/1984 Lbs) @ 450 Kpa/65 Psi
Bubba, do you have early 1962 or earlier rear wheel wells? Will be a close fit if so. _________________ In Stereo, Where Available! |
bubba Samba Member
Posted: Wed Apr 13, 2016 4:17 am Post subject: Re: 15" Radial Tires - Sizes and Vendors |
Eric&Barb wrote: |
Bubba, do you have early 1962 or earlier rear wheel wells? Will be a close fit if so. |
60 so23.. They are 26.53 inches tall... We will see. Pics to come. _________________ ***WANTED***
for sale
Posted: Wed Apr 13, 2016 7:03 am Post subject: Re: 15" Radial Tires - Sizes and Vendors |
Is it that your old tires are 26.53" tall? If so, what is the tire size on the sidewall? _________________ In Stereo, Where Available! |
