amotomura Samba Member
Posted: Sun Apr 12, 2015 8:43 am Post subject: |
Just left Sears. After reading this post, I ordered a set of 205/75r15 Guardsman LT tires. While they were mounting them, I noticed they had a "P" on them. Long story short, the Guardsman LT tires are NOT Light Truck tire rated. The "LT" is part of the tire name, not the tire rating. They are Passenger rated tire with 2 ply side walls.
A little deceptive, and disappointing. So now I'm going home with my old tires. Time to do more calling around. I can't find the Nexens or Vancos around here.
Please keep the suggestions coming for those of use searching for tires.
Thanks,
Andrew |
srfndoc Samba Member
Posted: Thu Apr 16, 2015 5:58 pm Post subject: |
After calling 4 different local tire shops and having no luck with them finding anything, I went to tires-easy.com.
The still have the SV820's in stock. I placed the order on Tuesday, and tires showed up on Thursday! Cost was $100 each plus $70 shipping for 5.
The date code is 4713, so end of 2013.
Can't wait to try them out... |
EDragnDean Samba Member
Joined: July 13, 2005 Posts: 1148 Location: Vancouver, WA
quartermilecamel Samba Member
Posted: Fri Aug 07, 2015 11:00 pm Post subject: |
Just tried to look for the nexen 820s on tire easy cannot find them. Ok just found them but no specs??? _________________ Waiting for santa to drop off funky green. I can wish can't I???? |
crukab Samba Chef
Joined: December 13, 2002 Posts: 6116 Location: Vermont
Posted: Sat Aug 08, 2015 5:32 am Post subject: |
Red Fau Veh wrote: |
I just ordered 4 Continental Vanco 4 season 195 70 15 tires from Discount tires. They matched Walmart and the total for 4 of them mounted is $627. |
That is a really good price Red, I'm paying $176 each for Vanco four season 195/70R15 6 ply tires, mounted, they dump the old tires. The guy at the tire store said they are getting harder to find, his supplier only carries one set at a time.
They are great for all the back road/ off road driving I do here in Vt.
This is my second set, they have gone up $20 ea. in 3 years.... _________________ Tom
My Pops:
In the yard right now:
'51 Dodge 5 window truck
'65 Bug
'66 Singlecab
'82 Rabbit Truck Diesel from CALI
'86 Doublecab W/T
'88 Dodge Ram pickup
'11 Jetta Wagon |
Posted: Sat Aug 08, 2015 6:29 am Post subject: |
I run American prospector tires on the rear 205 75 15 and rated at 1890lbs. Front has 1580lbs rating. So I thought I would upgrade the fronts to heavier payload. Guessing the 195s are shorter also. They quit making the americanprospector tires in 2010. Just checked and walmart has those vancos in stock or so it says.........online. So Im gonna guess that when it says boat or trailer tire, that doesn't make a difference? Called locally and when I try to get into a good tire in 6ply they say 205 75 6ply is a trailer tire and you wouldn't put that on a vehicle but they wont say why.
All I want is a tire 205 75 15 that's rated at or better than 1890lbs. Might have to just say F it and go get a trailer tire to get that.
Found nexen sv820 data.http://www.nexentireusa.com/cms_files/original/SV820SV820A_Spec_Sheet1.pdf
Thinking of ordering 2 of these but don't know if I should get 2 and run the prospectors on the back or just get all 4.
This just in: Went out to check my rear prospector tires. I need replacement eyeballs in L380. Rear tires as noted:1608lbs!!! _________________ Waiting for santa to drop off funky green. I can wish can't I????
Last edited by quartermilecamel on Sat Aug 08, 2015 10:41 pm; edited 2 times in total |
BulliBill Samba Member
Joined: July 09, 2004 Posts: 4573 Location: St Charles, MO
Posted: Sat Aug 08, 2015 7:24 am Post subject: |
quartermilecamel wrote: |
All I want is a tire 205 75 15 that's rated at or better than 1890lbs. Might have to just say F it and go get a trailer tire to get that |
When I was checking out "C" and "D" rated tires a while back I had a tire shop or two explain that "trailer tires" aren't designed to make sharp turns like normal tires (think having to make a sudden evasive turn). They are designed to carry loads in pretty much straight line and gently arcing turns. That is why many have warnings on the tire "trailer tire only" or "trailer use only". The tire shop personnel warned me against their use as a Bus tire.
That was my experience, and it seems logical.
Bill _________________ I'm looking for these license plate frames for my fleet:
Mission VW - San Fernando
Thornton VW - Stockton
Thanks for any help! |
Posted: Sat Aug 08, 2015 7:43 am Post subject: |
Thanks bill, yeah just got on a chat window and they said the same thing. The current debate Im having is what tire to get now. I don't like the jerkiness in 1st gear over bumps and I don't like the freeway automatic lane change with 1580lbs tires up front. Anyone care to venture a guess as to how the nexens hold up/handling/mileage? _________________ Waiting for santa to drop off funky green. I can wish can't I???? |
Scorcho Samba Member
Joined: May 04, 2012 Posts: 386 Location: Chicago, IL
Posted: Thu Sep 03, 2015 12:14 pm Post subject: |
That is a passenger rated tire so you would have to reduce the load rating by about 10% to get a true load capacity vs. a LT rated tire and the same PSI. Here's a good explanation:
Quote: |
P vs. LT
Although originally developed for cars, most vans, pickups and SUVs are used primarily to carry passengers and P-metric tires are typically lighter, with lower rolling resistance and less aggressive tread designs than typical LT-metric tires.
The combination of better ride, greater fuel efficiency and less noise has resulted in P-metric tires being used extensively for light truck applications. However, vans, pickup trucks and SUVs typically have a higher center of gravity and greater probability of being overloaded than passenger cars.
In order to accommodate this, vehicle engineers are required by Federal Motor Vehicle Safety Standards to specify P-metric sized tires rated to carry 10% more weight than would be required if they were used on a passenger car. This is the equivalent of dividing the tire’s sidewall branded load capacity by 1.10. For example, a P265/75R16 114S tire has a maximum load rating of 2,601 lbs. at 35 psi. However, when this tire is installed on a light truck, the load rating is reduced by a factor of 1.10 to 2,365 lbs. at 35 psi. |
Bus Depot has even more detail if your interested:
http://www.busdepot.com/details/tires/ _________________ RPM=(MPH*336* (R&P*4th*1.26))/Tire Diameter in inches |
Posted: Sun Sep 06, 2015 2:31 pm Post subject: |
Thanks for the info, will probably pass on the PepBoys tires. Was going to order the nexens but they're not available today on tire easy . These are on here too and are fairly cheap. Anybody have experience with them? |
Red Fau Veh Samba Member
Joined: September 07, 2012 Posts: 3037 Location: Prescott Az.
Posted: Sun Sep 06, 2015 4:23 pm Post subject: |
That is a euro tire, see it is spelled tyre? I would guess you can't get that tire here, but if you can it looks correct I think. _________________ 1971 Deluxe Sunroof Bay 1905 stroker, dual idf40's, 74mm Scat forged crank, engle 110 cam. CB 044 heads, AutoCraft rockers, chromoly push rods
1973 Orange transporter stock type 4 with dual 40 Dellortos and Empi single quiet pack
1969 Adventurewagen blue whale Gene Berg 1776 built by Dave Kawell dual 36 DRLA's, Vintage Speed exhaust, Bosch 019 screamer
1961 Swivel Seat camper, L345 grey
Touch Nicks Thing wrote: |
Swivel Seat panels are for people with no friends |
Posted: Mon Sep 07, 2015 5:06 pm Post subject: |
It doesn't say if they are the Vanco 4 season tires or other ones. _________________ 1971 Deluxe Sunroof Bay 1905 stroker, dual idf40's, 74mm Scat forged crank, engle 110 cam. CB 044 heads, AutoCraft rockers, chromoly push rods
Posted: Mon Sep 07, 2015 5:21 pm Post subject: |
http://www2.tires-easy.com/cgi-bin/rshop.pl?dsco=1...typ=457441
When i search by size the continental tires that come up are the ones from the other link and these, which say 4 season. So i am assuming the other ones are different. Just not sure if they are teh same as in the pic |
GTV Samba Member
Posted: Mon Sep 07, 2015 5:47 pm Post subject: |
195/70 is too short, over an inch shorter than stock. _________________ EMPI Power Rules! |
Posted: Tue Sep 08, 2015 7:49 am Post subject: |
The ones in the pics on the bus are Vanco 8's, not sure if they still make them. _________________ 1971 Deluxe Sunroof Bay 1905 stroker, dual idf40's, 74mm Scat forged crank, engle 110 cam. CB 044 heads, AutoCraft rockers, chromoly push rods
