Alaskan Original Paint 58 PGSG
sled
sled is offline
PostPosted: Fri Jul 22, 2016 11:20 am    Post subject: Re: Alaskan Original Paint 58 PGSG Reply with quote
Yes it is, but it would be better to get a nice hinge and reweld it into the door. Either way you will end up paint matching so might as well have a hinge with solid fingers
drive your split.
Chris Paterson
Chris Paterson is offline
PostPosted: Fri Jul 22, 2016 11:22 am    Post subject: Re: Alaskan Original Paint 58 PGSG Reply with quote
So it just welds into the inside of the door. I have to find one. Maybe I'll put up a want ad, or if someone has one they'd sell PM me!
- Chris
58' PGSG
srfndoc
srfndoc is offline
PostPosted: Fri Jul 22, 2016 11:39 am    Post subject: Re: Alaskan Original Paint 58 PGSG Reply with quote
I think they are actually press fit or secured with a type of rivet. Either way they are really hard to find. I looked a long time for one until this guy popped up with some NOS ones:
http://www.thesamba.com/vw/classifieds/detail.php?id=1862836
Wrong year for you but what your looking for.
Chris Paterson
PostPosted: Fri Jul 22, 2016 11:43 am    Post subject: Re: Alaskan Original Paint 58 PGSG Reply with quote
I saw that one, would be nice if it was correct for my bus! I'm sure someone has a junk cargo door they'd be willing to sell me. I put up a wanted ad and I'll just wait and watch.
- Chris
58' PGSG
campingbox Premium Member
campingbox is offline
PostPosted: Fri Jul 22, 2016 12:21 pm    Post subject: Re: Alaskan Original Paint 58 PGSG Reply with quote
Could you just replace the hinge pin and ignore the broken finger? At least that would make it relatively functional, and you could skip blending the paint.
Chris Paterson
PostPosted: Fri Jul 22, 2016 12:29 pm    Post subject: Re: Alaskan Original Paint 58 PGSG Reply with quote
That's a thought. I can tell the pin is rusted in there though so it would involve drilling it out, most likely. That's how I'm assuming the fingers broke on it in the first place. But then again, if I mess it up I could just go back to the other plan and I don't lose anything.
- Chris
58' PGSG
Stocknazi
Stocknazi is offline
PostPosted: Fri Jul 22, 2016 4:58 pm    Post subject: Re: Alaskan Original Paint 58 PGSG Reply with quote
You could remover the hinge half from the bus, wrap a wet rag around it, leaving only the finger exposed and heat it with a torch and drive the pin out. Drilling it out would be a PITA.
You will have to remove the hinge to replace it, so might as well get those 2 screws out.
WANTED:
"Resistance to tyrants is obedience to God."
Thomas Jefferson
ZENVWDRIVER
ZENVWDRIVER is offline
PostPosted: Fri Jul 22, 2016 5:21 pm    Post subject: Re: Alaskan Original Paint 58 PGSG Reply with quote
many years back there was a PGSG '58 from Alaska for sale here in Oklahoma too @ $1500... shouldda' bought it... had to do a double take with yours... real nice... Enjoy.
5/50, pastel green 11G - SOLD
8/50, gray 11A Beetle
6/52, pastel green 11C - SOLD
1960 single cab
9/63 Pacific blue, Ghia
'87 Toyota MR2
All super-heroes, wear a MASK
Chris Paterson
PostPosted: Sat Jul 23, 2016 8:51 am    Post subject: Re: Alaskan Original Paint 58 PGSG Reply with quote
Working on the little details
- Chris
58' PGSG
Chris Paterson
PostPosted: Tue Jul 26, 2016 9:18 pm    Post subject: Re: Alaskan Original Paint 58 PGSG Reply with quote
Here's my middle seat mounting clamp I guess
Boy that's disappointing!
I took the window frame off the passenger side because there was no vertical divider and the window wouldn't slide. So I bought a couple dividers and painted them and got the seal etc. It turns out regular felts were used on the bottom instead of sigla and that's why it wouldn't slide.
More surprisingly, there was not one single bolt or screw in the whole window frame holding it on! So no front or side m8 bolts. No m8 screws in the back and no m6 nuts holding the frame on. Fortunately I had the bolts and screws lying around, even the wavy washers.
- Chris
58' PGSG
AlteWagen
Troll
AlteWagen is offline
PostPosted: Tue Jul 26, 2016 9:35 pm    Post subject: Re: Alaskan Original Paint 58 PGSG Reply with quote
What is the source for sigla felts these days?
Official Dual Carb Thread
Chris Paterson
PostPosted: Tue Jul 26, 2016 9:36 pm    Post subject: Re: Alaskan Original Paint 58 PGSG Reply with quote
Ronnie carries them: http://www.bustoration.com/Felt-Channel-Bottom-Only-PAIR-for-Sigla-laminated-glass-B16_p_1200.html
- Chris
58' PGSG
PostPosted: Tue Jul 26, 2016 10:31 pm    Post subject: Re: Alaskan Original Paint 58 PGSG Reply with quote
I feel like your comment indicates you know this but:
That is Brazilian garbage. Smile
Check out the Middle Seat thread for the right stuff
Or spoiler:
(Painted black though)
Chris Paterson
PostPosted: Wed Jul 27, 2016 12:08 am    Post subject: Re: Alaskan Original Paint 58 PGSG Reply with quote
Yes I know. I've been buying up original seat hardware. Thanks for the link. I was more intrigued by the ingenious bolt and nut configuration and how that somehow held the seat down to the floor slots.
- Chris
58' PGSG
Chris Paterson
PostPosted: Thu Jul 28, 2016 8:58 pm    Post subject: Re: Alaskan Original Paint 58 PGSG Reply with quote
Yes all 4!
But interestingly, the two silverish ones say 3a and 3b the other two do not. What does it mean?
- Chris
58' PGSG
PostPosted: Thu Jul 28, 2016 10:45 pm    Post subject: Re: Alaskan Original Paint 58 PGSG Reply with quote
I've noticed they have different codes like that but haven't kept track.
I figured they were production codes of some sort.
In the photo I posted above, it looks like some of them say 3c too.
Chris Paterson
PostPosted: Thu Jul 28, 2016 11:45 pm    Post subject: Re: Alaskan Original Paint 58 PGSG Reply with quote
I think I won't get too crazy about having matchy matchy. It might knock down the value of the bus a bit... but it's a compromise I'm willing to make for expediency.
- Chris
58' PGSG
PostPosted: Fri Jul 29, 2016 7:03 am    Post subject: Re: Alaskan Original Paint 58 PGSG Reply with quote
Haha, I thought about telling you you better get matching ones but I don't think they matched on original Buses either.
I'm pretty sure the ones I pposted above are all from the same Bus since they all have the same sort of blue overspray on them.
Chris Paterson
PostPosted: Fri Oct 28, 2016 2:56 pm    Post subject: Re: Alaskan Original Paint 58 PGSG Reply with quote
Got these og paint wheels and I'm pretty excited about it! (No they're not date matched, I was just happy to have original paint PGSG wheels)
The neighbors listed their house for sale and we bought it. We've been renting in this neighborhood that we love and we were sad when our landlord wouldn't sell the place to us. Anyway this sort of derailed my plans on things for this bus!
Here's me moving
- Chris
58' PGSG
oakman
oakman is offline
PostPosted: Fri Oct 28, 2016 5:36 pm    Post subject: Re: Alaskan Original Paint 58 PGSG Reply with quote
Congrats on the house purchase, being next door makes it easier! The wheels look great. Damn, two og paint pgsg's?? Let me know if you get tired of all that green, I can take one off your hands! Very Happy
Page 2 of 6
