littleray Samba Member
Joined: May 17, 2016 Posts: 12 Location: Paso robles,ca
Posted: Mon Jul 18, 2016 8:12 pm Post subject: Re: Forum Syndication |
i'm a new member (littleray). Does anybody have an EMPI 38 mm egas carb?
If so do you have any info how too adj? |
catahoula lou Samba Member
Joined: August 30, 2008 Posts: 594 Location: south of Silver Springs, NV
Posted: Tue Jul 19, 2016 5:50 am Post subject: Re: How to adjust EMPI 38 mm egas carb? |
What are you trying to adjust? If your idle stays high because of your pedal/throttle not returning all the way, you will need to add another spring in addition to the wimpy one that comes on it.
If this is what you're talking about, let me know and I'll post a photo of what was done to mine.
Outside of that, great carb...
Best,
Thom _________________ 1 great wife
2 Catahoula Leopard Dogs (Mahogany Star and Spartan) - RIP Lucy, Braveheart, & Dusty!
1 1959 mango green Ragtop Bug (the "Mango")
1 1958 pantina red Lowlight Ghia (the "Chili Pepper")
Still looking for:
(1) My Dad's 1955 356 (he raced it amateur-class at Riverside and other courses during 1950s),
(2) My parent's black 1955 hardtop bug (CA license plate FWC 201 or FWG 201), and
(3) My parent's agave green 1957 ragtop bug (CA license plate LFK 734). |
earthquake Samba Member
Joined: January 10, 2008 Posts: 3984 Location: SANDY VALLEY, NEVADA
Posted: Tue Jul 19, 2016 10:29 am Post subject: Re: How to adjust EMPI 38 mm egas carb? |
Post a picture of your set up so we can see what manifold and such you are using to help you better.
Casey _________________ 74 CLASS 11 LOOK-A-LIKE
69 DUNE BUGGY
79 INTERNATIONAL SCOUT II
05 SCION XB SERIES RELEASE 2[#437]
95 Chevy C3500 dually
98 Ford E150
Link to Kelly J. Nolte 3/20/53 - 11/6/08
https://time-zonelabs.blogspot.com/p/about-kelly.html
DEATH TO CHINGERS!
[From a military recruitment poster in the novel "The Stainless Steel Rat" By Harry Harrison] |
Posted: Wed Jul 20, 2016 8:19 am Post subject: Re: How to adjust EMPI 38 mm egas carb? |
Spring was installed to pull the throttle/pedal back into closed position, as the original wimpy spring would only partially close, resulting in high idle. The spring (yellow/brass colored, above spark plug wires) was installed by drilling a small hole into the carb support, even height with the lower end of the throttle mechanism, and then hooking the spring into the new hole and onto the lower end of the throttle mechanism. Solved the high idle issue. All other parts that I installed with the carb came with it in the box...
Littleray, you still have not clarified what you're looking for...
Best,
Still looking for:
Posted: Wed Jul 20, 2016 3:22 pm Post subject: Re: How to adjust EMPI 38 mm egas carb? |
Does that carb have two A/F screws like a Weber DGAS?, If it does I would try closing one off and adjust it on the other but only on a open plenum manifold.
69 DUNE BUGGY
98 Ford E150
DEATH TO CHINGERS!
Posted: Sun Jul 24, 2016 3:58 pm Post subject: Re: How to adjust EMPI 38 mm egas carb? |
to catahoula lou, That's a great picture thanks. I'm getting a little pause when I step on the pedal. Mine has 4 adjusting screws, maybe I shouldn't have tried to adj some of them? |
Posted: Sun Jul 24, 2016 7:39 pm Post subject: Re: How to adjust EMPI 38 mm egas carb? |
Littleray:
What distributor are you using?
Still looking for:
Posted: Sun Jul 24, 2016 10:04 pm Post subject: Re: How to adjust EMPI 38 mm egas carb? |
To Catahoula Lou, My distributor is like the one in the picture except it's electronic ignition. I'm going to post a picture! I was thinking of going with an 009 dist? There's an adj screw behind the choke and I think that's the one I shouldn't have messed with. |
Posted: Sun Jul 24, 2016 10:07 pm Post subject: Re: How to adjust EMPI 38 mm egas carb? |
To earthquake, yes it does have 2 A/F screws, one in the back and one in the front. |
Posted: Mon Jul 25, 2016 7:21 am Post subject: Re: How to adjust EMPI 38 mm egas carb? |
The reason why I ask about your distributor is that I had been putting up with a hesitation similar to yours with my 009. My neighbor gave me a box of VW stuff, including the SVDA shown in the picture and the hesitation disappeared when I installed it to test for selling on the Samba.
However, my mechanic says that he prefers 009s and can tune the hesitation out. Problem is, he had already done that, it came back before the SDVA installation, and I don't want to keep coming back...
If you decide to go with an SVDA, you'll need to use two vacuum hose sizes, slip one into the other, and secure as shown in the photo.
Best,
Still looking for:
Posted: Mon Jul 25, 2016 8:45 am Post subject: Re: How to adjust EMPI 38 mm egas carb? |
To Catahoula Lou:
Here's the photos.
Posted: Tue Jul 26, 2016 7:19 am Post subject: Re: How to adjust EMPI 38 mm egas carb? |
It looks like you do have a SVDA. Have you taken off your air cleaner and operated your throttle to confirm that both accelerator tubes are squirting correctly? If one or both are not squirting cleanly/strongly, that could be the cause of your hesitation. As I recall, you'll need to take the top of the 38 off and use a can of carb cleaner with a little red tube to blow all passageways BOTH directions.
On another note, find the instructions that came with the 38 and go through them again. If you don't have them, I can email a PDF of them to you, if you PM your email to me.
Also, can't see if you've connected the tube that goes from the oil filler to the air filter. If you don't have it installed, make sure you plug the air filter inlet, as dirty air will bypass your air filter and go directly into your carb/engine.
Ultimately, you might have to take it to a trusted mechanic once for a correct setup...
Best,
Still looking for:
50sboy Samba Member
Posted: Tue Jul 26, 2016 3:34 pm Post subject: Re: How to adjust EMPI 38 mm egas carb? |
Also - run your distributor vacuum hose from the driver side end casting (like stock) and not the carb. That is an egr port and may not have enough vacuum to crank your advance when you need it. Then follow the Mixture Screw(s)/speed screw procedure in the instructions or on empis web site...similar to the progressive carb...it is basically the same as a weber dgas - which is the DGV carb family.. |
Posted: Tue Jul 26, 2016 8:15 pm Post subject: Re: How to adjust EMPI 38 mm egas carb? |
To Catahoula Lou, Thanks for the info, please send me pdf of instructions, my email is ([email protected]). I bought the carb from Car Craft and the instructions they sent were not very good!. |
Posted: Tue Jul 26, 2016 8:16 pm Post subject: Re: How to adjust EMPI 38 mm egas carb? |
To 50sboy, Thanks for your input. |
Posted: Wed Jul 27, 2016 6:46 am Post subject: Re: How to adjust EMPI 38 mm egas carb? |
Littleray:
I bought mine from the same company, so likely same instructions. Can still send PDF if you want what likely will be a duplicate of what you already have.
Best,
Still looking for:
Posted: Wed Jul 27, 2016 2:35 pm Post subject: Re: How to adjust EMPI 38 mm egas carb? |
To Catahoula Lou, yes please send, just in case. Thanks |
Posted: Wed Jul 27, 2016 5:28 pm Post subject: Re: How to adjust EMPI 38 mm egas carb? |
Littleray:
Will email PDF of instructions. Also, found PDF of how I solved my hesitation problem at one point, by raising the idle a bit.
Best,
Still looking for:
bugaddiction71 Samba Member
Joined: February 12, 2013 Posts: 20 Location: United States
Posted: Sat Nov 19, 2016 12:17 pm Post subject: Re: How to adjust EMPI 38 mm egas carb? |
I have that pos carb and still fucking running that pos! Too it's never ran right for me. But I did get a 1600dp down to a 17.98 at 72mph. Bugaddiction71 on YouTube. Stock is about 21sec so i guess it works |
