arthurnugen Samba Member
Joined: January 11, 2005 Posts: 3081 Location: The PNW, where "going green" means rolling with moss.
Posted: Sun Jul 24, 2016 10:03 pm Post subject: Brakes - at my wits end |
Hey all,
So I'm so frustrated I almost put my '67 up for sale today! I put all new brakes on the front: wheel cylinders, shoes, drums, brake spring kit, soft and hard lines, new mastercylinder. Everything.
I go to drive it and it feels like the brakes are on all the time. I've adjusted, re-adjusted, adjusted the free play for the brake pedal - and it still does it! It seems worse when I turn the steering wheel left or right - it even stops and doesn't roll backwards on my slightly uphill driveway. I jack it up and the wheels turn freely. All I can say is WTF!!! Please help. Tomorrow I'm doing something for the first time since I've owned old VWs: take it to a shop.
Any ideas?
Arthur _________________
cdennisg wrote: |
Lawyers don't deserve buses. |
zozo wrote: |
Don't worry too much. You can always trust a lawyer. |
ALWAYS WEAR STEEL-TOE BOOTS IN THE GARAGE!
1965 Bus (Riviera camper)
1972 Bug 'vert
1967 Bug sunroof
1961 Ghia 'vert
1957 DKW 3=6: 3 cylinder 2 stroke! |
mukluk Samba Member
Posted: Sun Jul 24, 2016 10:36 pm Post subject: Re: Brakes - at my wits end |
Not quite clear on whether "I jack it up and the wheels turn freely" is only in reference to the front wheels/brakes that you replaced, or if you have checked the rear brakes as well for freedom of rotation. _________________ 1960 Ragtop w/Semaphores "Inga" |
herbie1200 Samba Member
Joined: April 27, 2006 Posts: 833 Location: Rome - Italy
Posted: Mon Jul 25, 2016 4:58 am Post subject: Re: Brakes - at my wits end |
First thing is to identify the wheel with brake on. After a short driving you should feel hot the wheel that does not spin free. |
60ragtop Bonneville Belt Bitch
Joined: March 13, 2006 Posts: 7800 Location: Big Wonderful WYO 82401
Posted: Mon Jul 25, 2016 5:09 am Post subject: Re: Brakes - at my wits end |
check the inner front wheel bearings to make sure you have the right ones. VW made a change to the spindle in 68. _________________ Rick
Certified Mechanic by the State of Michigan in 1977
ASA certified in 1987
Certified Hunter Wheel Alignment Master Technician 1986
tasb wrote: |
I've restored a large number too, but I don't toot my horn quite as loud.
sb001 wrote: |
maybe he just snapped cause his car sucked |
sjbartnik Samba Member
Joined: September 01, 2011 Posts: 5998 Location: Brooklyn
Posted: Mon Jul 25, 2016 5:45 am Post subject: Re: Brakes - at my wits end |
How are you adjusting the pedal free play?
The right way is with the pedal stop on the floor of the car.
The wrong way is by altering the length of the master cylinder push rod.
If you do it the wrong way, you can block the compensating port inside the master cylinder which will cause the brakes to slowly lock on as they heat up.
If the new master cylinder is a different p/n or configuration than the original one the length of the push rod may need to be altered to make it work properly - Bentley has the procedure for this. _________________ 1965 Volkswagen 1500 Variant S
2000 Kawasaki W650 |
Joined: May 17, 2003 Posts: 4863 Location: Harmony, PA
Posted: Mon Jul 25, 2016 6:50 am Post subject: Re: Brakes - at my wits end |
Take a closer look at your brake shoes, and adjusters. An early set would have an adjuster that has a shoe groove that is equally cut through the adjuster, and the shoe would have an end to it perpendicular to the adjuster to properly seat it in the adjuster. The late style has the shoe groove cut at an angle, along with the end of a shoe cut at an angle to mate to it. I would think a 67 would have a late set. Unless you've owned the car from new, who knows what correct, or incorrect repairs have been done in 49 years by previous owners. If the shoes, and adjusters aren't the correct mating ones, the shoes can shift/jam when the brakes are applied. |
Posted: Mon Jul 25, 2016 12:39 pm Post subject: Re: Brakes - at my wits end |
Thanks all! The rear wheels and brakes are fine. I did adjust the freeplay with the pushrod - and even made it TOO loose as an experiment and the problem did not go away. I also double checked and it does have the angle adjusters and the shoes are seated properly.
I don't know what else could be going on but appreciate the insights!
Arthur
PS the bearings looked the same as the old ones. Weird thing is that I drove it a couple of blocks around my neighborhood and did not use the brakes at all. When I got home and checked the drums they were very hot to the touch! _________________
cdennisg wrote: |
zozo wrote: |
1972 Bug 'vert
1967 Bug sunroof
1961 Ghia 'vert
bugheadred Samba Member
Posted: Mon Jul 25, 2016 1:39 pm Post subject: Re: Brakes - at my wits end |
using the adjusters tighten them until you push all the fluid out of the wheel cyl. then adj the break shoes until you have free play then bleed the brakes |
Posted: Sun Aug 28, 2016 10:19 am Post subject: Re: Brakes - at my wits end |
So I thought I would close the loop on this thread and let everyone know that I had the wrong inner wheel bearings!! They were for an earlier year. Got the right bearings and works great now.
cdennisg wrote: |
zozo wrote: |
1972 Bug 'vert
1967 Bug sunroof
1961 Ghia 'vert
Zylinderkopf Samba Member
Joined: September 09, 2012 Posts: 679 Location: SE Oklahoma
Posted: Sun Aug 28, 2016 11:21 am Post subject: Re: Brakes - at my wits end |
arthurnugen wrote: |
Arthur |
Makes sense. Thank you for closing the loop-wish more people did! _________________ 1963 Beetle
1966 Beetle 1300
1970 Karmann Ghia Coupe
1971 Super Beetle
1974 Thing
"A lot of people never use their initiative because no one told them to." |
