Tire help
CAR60
CAR60 is offline
PostPosted: Sat Jul 23, 2016 5:22 pm    Post subject: Tire help Reply with quote
Right now I have N50-15 on 12" rims on rear
and g-50-14 on 8" rims on front
I'm thinking about 295/50/15 on rear
and 215/60/14 on front
what do you guys think
clonebug
clonebug is offline
PostPosted: Sun Jul 24, 2016 8:25 am    Post subject: Re: Tire help Reply with quote
Measure how tall that rear tire is.
I have run both 295/50-15 and 275/60-15 tires and I like the taller 275/60-15 for my buggy the most.
The 275/60 gives a nicer gear ratio in my opinion.
It will all depend on how much mid range power or torque you have.
If your engine pulls the buggy around nicely now then get the taller 275's.
I run my BFG 275/60-15 on a 8 inch wide rim.
It will cruise 70 mph at 3100 rpm all day without an issue.
The 275 is 28 inches tall and the 295 is around 26.5 inches tall. It make a pretty noticeable difference.
vwracerdave wrote:
Take a good long look in the mirror and report back on what you see.
Paul.H wrote:
That one line on that chart is probably better info than you can get from this place in a month
Water/Alcohol Injection
Audi TT intercooler
Upgraded to MS3Pro-Evo
EcuMaster PMU16
ECUMaster ADU5 Digital Dash
http://www.shoptalkforums.com/viewtopic.php?f=3&t=127936
CAR60
CAR60 is offline
PostPosted: Sun Jul 24, 2016 9:17 am    Post subject: Re: Tire help Reply with quote
Thanks clonebug for reply. I looked up the 275/60/15 and it looks like it is an 11" wide tire. They should be ok on a 12" rim with a little bulge.
What do you think about the 215/60/14 on front on 8" rim.
clonebug
clonebug is offline
PostPosted: Sun Jul 24, 2016 8:05 pm    Post subject: Re: Tire help Reply with quote
I am running 185/60-15 on 3.5 inch rims but will be upgrading my Front brakes to 5x4.75 Chevy discs and 5.0 inch rims here shortly.
The 215 tire is probably about 1.5 inches wider than mine and should be fine although an eight inch rim might be on the wide side.
No worse than a 275 on a 12 inch rim.
Audi TT intercooler
EcuMaster PMU16
CAR60
CAR60 is offline
PostPosted: Mon Jul 25, 2016 1:23 pm    Post subject: Re: Tire help Reply with quote
Spoke with tire guy today and leaning toward
295/50/15 on rear
215/60/14 on front
$740 total for tires and install.
B F Goodrich
