Need help finding a barrel nut for a 28 pict carb
static337
static337 is offline
PostPosted: Sat Jul 23, 2016 5:46 pm    Post subject: Need help finding a barrel nut for a 28 pict carb Reply with quote
Found one. Thanks all for the help.
Danwvw
Danwvw is offline
PostPosted: Sat Jul 23, 2016 5:59 pm    Post subject: Re: need help finding a barrel nut for a 28 pict carb Reply with quote
Gd Used Throttle Cable Extender w/barrell Nut Price: $6 + Shipping,
throttle cable nut bolt barrel nut accelerator Price: $3.
1960 Beetle And 1679cc DP W-100 & Dual Zeniths!
static337
PostPosted: Sat Jul 23, 2016 6:04 pm    Post subject: Re: need help finding a barrel nut for a 28 pict carb Reply with quote
Thanks the second one I've found similar ones but have been told they don't fit a 28 pict I'll double check with the seller.
mukluk
mukluk is offline
PostPosted: Sat Jul 23, 2016 6:39 pm    Post subject: Re: need help finding a barrel nut for a 28 pict carb Reply with quote
New old stock part from BUGCITY: https://www.bugcity.com/shop/shop.htm?pquery=111129921
static337
PostPosted: Sat Jul 23, 2016 9:13 pm    Post subject: Re: need help finding a barrel nut for a 28 pict carb Reply with quote
Thank you. That's what I need. But not gonna pay 10 dollars shipping on a 4 dollar part. Bummer.
mukluk
mukluk is offline
PostPosted: Sat Jul 23, 2016 10:11 pm    Post subject: Re: need help finding a barrel nut for a 28 pict carb Reply with quote
In similar cases where shipping cost exceeded the item cost, I usually end up fleshing out the order some with other bits and bobs that I've had floating about on my "want" list -- there are always small items and projects that could use some attention, or at the very least having a couple OEM spare parts about does come in handy from time to time.
glutamodo Premium Member
The Android
glutamodo is offline
PostPosted: Sun Jul 24, 2016 3:42 am    Post subject: Re: Need help finding a barrel nut for a 28 pict carb Reply with quote
I'm not sure where you're getting that other barrel clamps won't fit.
The ones on the carbs were the same diameter going back a very long ways. In the late 60s they changed from a flat head screw to an 8mm hex head, but the barrel size was the same.
I'm one of the few people around who actually like the old slotted-style barrel clamp - well I like the original look of it better than the 8mm style. But I've used BOTH styles at various times over the years, on the 28PICT on my 62 bug.
Really, all of these examples interchange!
What won't work are the larger diameter barrel clamps used on the heater box levers up to the early/mid 60s.
Andy T.
I do not know how to fix this. All I can say is it all works fine for me with what I use, Firefox.
andk5591
andk5591 is offline
PostPosted: Sun Jul 24, 2016 4:52 am    Post subject: Re: need help finding a barrel nut for a 28 pict carb Reply with quote
Well - if you read it on the internet, it must be true Laughing .... I have run into one here and there that is a little too snug but if I didnt have any other options, a piece of sandpaper would solve that....
D-Dubya Manx clone - 63 Short pan,1914.
There's more, but not keeping them...
static337
PostPosted: Sun Jul 24, 2016 5:53 am    Post subject: Re: Need help finding a barrel nut for a 28 pict carb Reply with quote
I'll take a sellers word on it not fitting before wasting the money on one that won't fit. If that's reading it on the Internet then I'm guilty.
rcroane Premium Member
rcroane is offline
PostPosted: Sun Jul 24, 2016 5:58 am    Post subject: Re: Need help finding a barrel nut for a 28 pict carb Reply with quote
I've got several extras. Happy to send you one. PM me your address.
'65 Sunroof Bug
static337
Hmm. I'll keep looking. Seems thato the ones I found have a diameter of 5/16 or 8mm I'm measuring only 6mm of opening on my throttle lever.
static337
PostPosted: Sun Jul 24, 2016 5:59 am    Post subject: Re: Need help finding a barrel nut for a 28 pict carb Reply with quote
Awesome. Sending pm now.
tasb
The Distributor Distributor
tasb is offline
PostPosted: Sun Jul 24, 2016 8:13 am    Post subject: Re: Need help finding a barrel nut for a 28 pict carb Reply with quote
Or you can go this route and save 50% on the part and I'm sure he won't charge $10 for shipping.
http://www.thesamba.com/vw/classifieds/detail.php?id=1792579
This was accomplished with a classifieds search using 'barrel".
You might want to buy a small grip of em. When I used to take my car to the local VW repair they routinely "replaced the clamp with the "correct" part" Rolling Eyes
Roads Scholar &
The Android
PostPosted: Sun Jul 24, 2016 12:07 pm    Post subject: Re: Need help finding a barrel nut for a 28 pict carb Reply with quote
Not sure how you got 6mm there. It is supposed to be 8mm.
Andy T.
