flashho Samba Member
Joined: August 11, 2012 Posts: 240 Location: Mulege, Baja
Posted: Sat Jul 23, 2016 5:56 pm Post subject: Re: Type 4 Power! |
_________________ rant _ classified ads with out pics are almost worthless |
Manx Lee Samba Member
Posted: Tue Aug 02, 2016 3:29 pm Post subject: |
Vanapplebomb wrote: |
Baja Rabbit with Type 4 power and Type 1 based suspension.
I like the exhaust I wonder if that would work on my Manx? |
Vanapplebomb Samba Member
Joined: November 03, 2010 Posts: 5418 Location: Holland, MI
Posted: Sat Aug 06, 2016 4:35 pm Post subject: Re: Type 4 Power! |
You could easy do that, yeah. The manifolds are factory for 75-78 bus engines. I don't particularly like them, but they will work fine. Just add your own custom tubing to the ends and your all set. _________________ 1800 Type 4 Berrien 295
http://www.thesamba.com/vw/forum/viewtopic.php?t=487021 |
Posted: Sat Aug 06, 2016 4:39 pm Post subject: Re: Type 4 Power! |
This is the system I made from factory T4 heater boxes cut down to the cores. Then just a header I found for 20 bucks (dented and rusty, this 20 bucks), a bend, and stinger. I got the baffle and 3x5 suppertrapp for the end of the stinger...
nextgen Samba Member
Joined: August 19, 2004 Posts: 6033 Location: CONGERS, N.Y.
Posted: Tue Jun 18, 2019 1:47 pm Post subject: Re: Type 4 Power! |
When my manual came out in 1992 it was Jack Raby, Joe of Oregon Performance , FAT Performance and me with my manual up against the T-1 guys.
They had no clue as to what a T-4 was, all they knew was it burned out in heavy loaded buses.
My first drive, the clutch holding power was what I noticed first, then the constant torque.
Now I am not alone on the T-4 mission, I got you guys. Ha!!!!
Like Jake and I once said after debates after debates, " you just have to drive one to understand ". _________________ email: [email protected]
The TYPE IV UPRIGHT CONVERSION MANUAL
BEETLE MAGNETIC DEFLECTOR SHIELDS
LETS TALK DUBS https://www.youtube.com/results?search_query=joe+cali+ghia https://letstalkdubs.libsyn.com/ep-200-joe-cali-ty...qI3xJTCzjs |
p0rschenut69 Samba Member
Joined: March 11, 2012 Posts: 35 Location: Pemberton, BC
Posted: Fri Mar 20, 2020 4:02 am Post subject: Re: Type 4 Power! |
My VW Beetle Baja with T4 Porsche 914 power |
Posted: Fri Mar 20, 2020 4:14 am Post subject: Re: Type 4 Power! |
Some more pics of my Baja which uses Twin Weber 40 IDF EMPI style Carbs and a 200 mm Kennedy Flywheel with a Cip1 200mm diaphragm clutch.
Posted: Fri Mar 20, 2020 4:26 am Post subject: Re: Type 4 Power! |
Side view of my project. Thanks for the informative posted on this thread, it was a big help! |
BFB Samba Member
Posted: Sat Mar 21, 2020 8:23 am Post subject: Re: Type 4 Power! |
this is a little trail buggy i built a couple years ago. had a turbocharged type 4 1700, 3 rib, and 228 mm flywheel. i had to do some clearancing to get the flywheel to fit and modify the flywheel for short trans input shaft bearing location.
with the low gearing and large flywheel you couldn't hardly stall the engine if u wanted to, i accidentally took off in 3rd a couple times. it sure wasn't like 1st but ive never had another buggy that would do that |
