Fan rubbing / Pulling fan shroud with motor in car?
Page: Previous  1, 2
Stevie Hall
Stevie Hall is offline
PostPosted: Wed Jul 20, 2016 11:54 am    Post subject: Re: Fan rubbing / Pulling fan shroud with motor in car? Reply with quote
Sorry guys. Quick question here. What thread are the two screws that hold the large fan on? They are the cause of my rubbing noise. Mine seem to have gone AWOL in rebuild. Thank you Rolling Eyes
67 Steel slider
69 Notchback
88 Carat
34 Ford
Tram
Samba Socialist
Location: Still Feelin' the Bern- Once you've felt it you can't un- feel it.
Tram is offline
PostPosted: Wed Jul 20, 2016 12:14 pm    Post subject: Re: Fan rubbing / Pulling fan shroud with motor in car? Reply with quote
The two threaded holes in the big fan are for a puller. They have no bearing on the fan itself whatsoever.
If your fan is rubbing and not knocking your most likely suspect is that the bolts holding the front part of the aluminum fan housing to the case have backed out and are rubbing on the fan.
Bryan67 wrote:
To best contact me, please use the EMAIL function in my profile
Bobnotch
Bobnotch is offline
PostPosted: Wed Jul 20, 2016 12:15 pm    Post subject: Re: Fan rubbing / Pulling fan shroud with motor in car? Reply with quote
Those 2 holes are for aiding in the removal of the big fan. There aren't any bolts that go in them. They holes are however M8x1.25 thread.
If you've got some extra movement from the fan, then it needs rebuilding. There's a thread on it that can be found doing a search.
Bob 65 Notch S with Sunroof
Tram wrote:
Tram wrote:
Stevie Hall
PostPosted: Wed Jul 20, 2016 12:43 pm    Post subject: Re: Fan rubbing / Pulling fan shroud with motor in car? Reply with quote
Thanks very much guys! I didn't remember there being screws in there. There is however some rocking of the fan and can see movement through the holes that are threaded. Id assumed I'd missed screws. I have a video on my phone
67 Steel slider
69 Notchback
88 Carat
34 Ford
KTPhil Premium Member
KTPhil is offline
PostPosted: Wed Jul 20, 2016 1:09 pm    Post subject: Re: Fan rubbing / Pulling fan shroud with motor in car? Reply with quote
Another thing to check is the big bolt holding the fan/pulley in place. Many manuals repeat the Bug's ≈35 ft-lb torque, but the Type 3 is more like ≈90. It may be coming loose.
Stevie Hall
PostPosted: Wed Jul 20, 2016 1:21 pm    Post subject: Re: Fan rubbing / Pulling fan shroud with motor in car? Reply with quote
True. It was damn tight with the engine in the car which is why I dropped it out last night. I'll remember when I'm putting it back on to make sure its FT! Wink
67 Steel slider
69 Notchback
88 Carat
34 Ford
Tram
Samba Socialist
Tram is offline
PostPosted: Wed Jul 20, 2016 1:34 pm    Post subject: Re: Fan rubbing / Pulling fan shroud with motor in car? Reply with quote
Uh oh.
I've had lots of problems with mismatched and misidentified main bearing sets (new non steel backed type) causing perceptible movement of the crankshaft after as little as a few minutes of running. Get the fan off and install the bolt to the crank and rock it up/ down/ to/ fro and tell us what you find.
Stevie Hall
PostPosted: Thu Jul 21, 2016 7:15 am    Post subject: Re: Fan rubbing / Pulling fan shroud with motor in car? Reply with quote
Any reasons why this wouldn't work? 2 M8 buttons Question
67 Steel slider
69 Notchback
88 Carat
34 Ford
Tram
Samba Socialist
Tram is offline
PostPosted: Thu Jul 21, 2016 11:04 am    Post subject: Re: Fan rubbing / Pulling fan shroud with motor in car? Reply with quote
I don't care what you put in there- it won't solve anything. Those holes are for a puller!!!
Stevie Hall
PostPosted: Thu Jul 21, 2016 11:39 am    Post subject: Re: Fan rubbing / Pulling fan shroud with motor in car? Reply with quote
Totally agreed Tram! Ive thought about it and pulled it today. Going to do the rebuild. Better in the long run! Thanks for the help Wink
67 Steel slider
69 Notchback
88 Carat
34 Ford
Tram
Samba Socialist
Tram is offline
PostPosted: Thu Jul 21, 2016 3:41 pm    Post subject: Re: Fan rubbing / Pulling fan shroud with motor in car? Reply with quote
Do the bolt in the crank test before you rebuild the fan...
Page: Previous  1, 2
Page 2 of 2
