Deep dish wheels...school me
Forum Index -> Custom Wheel/Tire Share: Facebook Twitter
SkyDawgVW
SkyDawgVW is offline
PostPosted: Mon Dec 01, 2014 11:05 am    Post subject: Deep dish wheels...school me Reply with quote
I am looking to purchase a pair of 7" widened smoothies for my '63 bug. Will the rims bolt up to a stock drum? Or are spacers needed? If so what size?
What tire size generally goes well with 7" widened smoothies?
1961 SWR Kombi
rwf8ball
rwf8ball is offline
PostPosted: Thu Dec 11, 2014 9:20 pm    Post subject: deep dish wheels Reply with quote
7" wide wheels will bolt up to a stock wide five drum. I am puting 7's on my 63 as well, Iam useing 225/60/15 tires but I have"nt put them on yet, I"ll let you know how they fit.
ALB
ALB is offline
PostPosted: Fri Dec 12, 2014 8:21 am    Post subject: Reply with quote
A 215/60- 15 (25.1" tall) fits a 6- 7 1/2" rim, is closer to stock VW height and will be a little easier to fit than the wider tire; exactly where it sits in relation to the fender edge will depend on the offset of the wheel. The 225/60 is also a little taller (25 1/2- 25 3/4", which is not that much), but if you aren't running a lot of power you may feel it.
Depending on the offset of the wheel, you may or may not need spacers; you'll have to mount them and see. Al
On a lifelong mission to prove (much to my wife's dismay) that Immaturity is Forever!!
rwf8ball
rwf8ball is offline
PostPosted: Fri Dec 12, 2014 11:25 am    Post subject: DEEP DISH WHEELS Reply with quote
The offset is key. The stock offset is 3.75" so if you stick to that you should be fine.
theastronaut
theastronaut is offline
PostPosted: Fri Dec 12, 2014 3:38 pm    Post subject: Re: DEEP DISH WHEELS Reply with quote
7" with stock backspacing on a short axle car will put the wheel lip 1/2" away from the fender lip with. At least that's what my '64 measures with 5 degrees of camber. You'll have to stretch the tire to keep from rubbing, like 185 wide. No way a 205 or 225 would ever fit if the backspacing is stock. You could run more backspacing if you wanted a wider tire.
Strive for perfection in everything. Take the best that exist and make it better. If it doesn't exist, create it. Accept nothing nearly right or good enough."
-Sir Henry Royce, co-founder of Rolls-Royce
'64 Beetle Sunroof OG Bahama Blue
'63 Beetle Vert
'66 Beetle
'88 Festiva L
'89 Festiva L
'64 Chevy C10
'66 Chevy C10
esde
esde is offline
PostPosted: Thu Dec 18, 2014 7:09 am    Post subject: Re: DEEP DISH WHEELS Reply with quote
Incorrect, the stock wide 5 type 1 smoothie backspace is 3.25".
Some people have claimed to have run 4" backspace on early "short" type 1 axles and stock drums, but I suspect they are measuring incorrectly. I ran 8" wide rims, with 3.75" backspace, and 225/55/15 under stock fenders. The tires always rubbed a clean spot on the spring plate, and fender lip. Room for a credit card and no more..
rwf8ball
rwf8ball is offline
PostPosted: Tue Dec 23, 2014 12:05 am    Post subject: 7" wide wheels Reply with quote
Here's my 7" wide wheels on my 1963 bug.
VWMIke82
VWMIke82 is offline
PostPosted: Wed Dec 24, 2014 10:23 am    Post subject: Reply with quote
What size tires are you running rwf8ball?
1959 VW Bug Sedan
I chopped it up for Baja and then put it back to stock...
1914 cc, 043 heads, 110 cam, weber 40idfs.
rwf8ball
rwf8ball is offline
PostPosted: Thu Dec 25, 2014 5:55 pm    Post subject: Reply with quote
225/60/15
SkyDawgVW
PostPosted: Wed Jul 22, 2015 7:57 pm    Post subject: Reply with quote
Here's what I finally ended up with:
175/55 on 6 inch widened on the front
205/60 on 7 inch widened on the back
1961 SWR Kombi
turbotype1
turbotype1 is offline
PostPosted: Tue Aug 11, 2015 7:44 pm    Post subject: Reply with quote
Were these wheels built with stock backspacing?
117harv wrote:
This new fad of get it the lowest, or run it with the worst looks, (patina) isn't cool, it's for the hey everyone look at me crowd, i'm driving a beat down ratty, unsafe, VW, how cool am I ???...your not....
Pissing off the purists since 1997
Wanted: Boyd Motors plate frame
57 Turbo Oval Sliding rag
67 13 window delux walk-thru- now 21
64 all original for the misses
83 Sinka m-TDI diesel
SkyDawgVW
PostPosted: Wed Aug 19, 2015 12:15 pm    Post subject: Reply with quote
Yes, I believe they were.
The rear wheels were purchased through thesamba.
1961 SWR Kombi
Cali_Army_Guy
Cali_Army_Guy is offline
PostPosted: Sun Jul 17, 2016 7:14 pm    Post subject: Reply with quote
I know this is an old post but this is the exact setup I'm going with. Is your beam narrowed 4" or 6"?
2015 VW Passat Wolfsburg Edition
1966 VW Beetle - Sold
ridehard
ridehard is offline
PostPosted: Tue Jul 19, 2016 2:07 am    Post subject: Re: 7" wide wheels Reply with quote
I do like the deep dish rims!! what colour are you spraying the car to go with it???
meatball74
meatball74 is offline
PostPosted: Mon Aug 15, 2016 10:25 am    Post subject: Reply with quote
and can you tell me if the rear was narrowed at all? I have a 4" narrowed beam but am trying to figure out how wide I can go in the rear with stock offsets and not rub my fenders. Mine is fully bagged too so need to be able to tuck the rears.
Reply to topic    Forum Index -> Custom Wheel/Tire All times are Mountain Standard Time/Pacific Daylight Savings Time
