lumbee Samba Member
Joined: June 15, 2012 Posts: 180 Location: Asheville, NC
Posted: Fri Jul 15, 2016 7:08 am Post subject: Tappets out of line with top of valves |
Hey folks! I have a 56 oval that I am rebuilding the top end on. I am reassembling the heads, and when I mounted the tappets I noticed at least one of the tappets is way out of line with the top of the valve. I am attaching an image for you to check out. Note I added the arrow, but if you look at the one on the end, the alignment is not so great either.
While I did completely disable the valves and springs...I did take the tappet assemble apart. I left it assembled and just soaked it in cleaner. I say that to say...I did not reassemble it wrong.
Am I missing something, or is there a way adjust the tappets from side to side to get a better contact area?
Also swapped tappet assemblies on both heads, and the misalignment is present on both heads.
Any info appreciated.
Snort Samba Member
Joined: April 02, 2005 Posts: 1957 Location: Seattle, WA
Posted: Fri Jul 15, 2016 7:42 am Post subject: Re: Tappets out of line with top of valves |
This is normal and an intentional design feature. |
vw54john Samba Member
Joined: March 12, 2004 Posts: 147 Location: Cheshire, CT USA
Posted: Fri Jul 15, 2016 8:35 am Post subject: Re: Tappets out of line with top of valves |
Yep, this "misalignment" actually causes the valve to rotate, thereby preventing a hot spot on the valve and enabling more even wear. _________________ Regards, John
'54 Strato Silver Oval |
lumbee Samba Member
Posted: Fri Jul 15, 2016 8:59 am Post subject: Re: Tappets out of line with top of valves |
Wow! Would have never guessed that. Thanks all! |
h~moto Samba Member
Joined: November 19, 2008 Posts: 317 Location: Northern Virginia
Posted: Fri Jul 15, 2016 12:21 pm Post subject: Re: Tappets out of line with top of valves |
Very many of the VW repair manuals will show three pictures about this. One with no offset, one with too much offset and the third with the proper offset. |
lumbee Samba Member
Posted: Fri Jul 15, 2016 12:32 pm Post subject: Re: Tappets out of line with top of valves |
h~moto wrote: |
If anyone has a pic of this they can share online I'd love to see it. Thanks! |
TSLAVO Samba Member
Posted: Fri Jul 15, 2016 1:11 pm Post subject: Re: Tappets out of line with top of valves |
I don't have it in english. The 3rd one is the correct alignment.
Joined: April 27, 2002 Posts: 6371 Location: Pentwater, Michigan
Posted: Sat Jul 16, 2016 6:49 pm Post subject: Re: Tappets out of line with top of valves |
Who would need a translator for that! _________________ Roads Scholar &
1961 (October)Single Cab- Road Trip Workhorse |
lumbee Samba Member
Posted: Mon Jul 18, 2016 5:39 am Post subject: Re: Tappets out of line with top of valves |
Great info. Thanks everyone! |
williamM Samba Member
Joined: August 07, 2008 Posts: 4333 Location: southwest Arizona
Posted: Mon Jul 18, 2016 6:28 am Post subject: Re: Tappets out of line with top of valves |
If that far off I would shim them towards the spring for better contact- that one sure looks off. _________________ some days I get up and just sit and think. Some days I just sit.
opinion untempered by fact is ignorance.
Don't step in any! |
