73 Thing for the middle Daughter
EDragnDean
EDragnDean is offline
PostPosted: Sat Jun 11, 2016 3:31 pm    Post subject: 73 Thing for the middle Daughter Reply with quote
Scored a 73 Thing project. Plan is to wrench on it with the middle daughter. Needs work, my plan is to replace the floors, and redo all the mechanicals, basically "daily driver" status (I may need intervention as I tend to go all in... call me out if I start to falter...).
Floor was toast at some point, and some PO welded in flat sheet metal, which also then rusted... PO should be a swear word! Motor needs a rebuild, brakes, etc... Last on the road in 2005.
63 Double Cab http://www.thesamba.com/vw/forum/viewtopic.php?t=443823&highlight=deanos
66 Bus Click to view image - SOLD
73 Thing http://www.thesamba.com/vw/forum/viewtopic.php?p=8111202#8111202
70 BusClick to view image
GI Joe
GI Joe is offline
PostPosted: Sat Jun 11, 2016 7:07 pm    Post subject: Re: 73 Thing for the middle Daughter Reply with quote
Looks like a Great start! She appears Very solid...
And do I see adhesive ALL over that interior(doors, rockers, etc??)..... Rolling Eyes
Welcome!
'74 Thing, "Our Thing"....Blue 181
http://www.thesamba.com/vw/forum/viewtopic.php?t=4...p;start=60
'71 Beetle RPU
http://www.thesamba.com/vw/forum/viewtopic.php?p=8080337#8080337
www.NLEOMF.com
Respect, Honor, Remember
EDragnDean
PostPosted: Sat Jun 11, 2016 7:24 pm    Post subject: Re: 73 Thing for the middle Daughter Reply with quote
PO glued on carpet?!?! And hacked holes in the middle of the inside rockers, arrrg!
Yarkle
Yarkle is offline
PostPosted: Sun Jun 12, 2016 7:25 am    Post subject: Re: 73 Thing for the middle Daughter Reply with quote
One thing that continually baffles me is when you see things of one original color repainted to another original color..eg white over orange yellow over orange, orange over yellow. i jsut think its odd
Tilda the Mustard Tigress 1973 Squareback (o'''^'''o)
https://www.thesamba.com/vw/forum/viewtopic.php?t=771024&highlight=
doublecanister
doublecanister is offline
PostPosted: Wed Jun 15, 2016 12:56 pm    Post subject: Re: 73 Thing for the middle Daughter Reply with quote
what's with the four things on the bumpers?
like they had a over the roof rack or were feet for a tent maybe?
Neat idea, tent feet for a popup over your THING! LOL
Don't worry, I'm sure yall will get it cleaned up and purring again!
Good luck with your project!
T
2020 - Mustang Eco Boost [High Performance]
1973 - Thing
1966 - Mustang GT- Fastback
1951 - Ford F1 pickup Flathead V8
EDragnDean
PostPosted: Wed Jun 15, 2016 6:21 pm    Post subject: Re: 73 Thing for the middle Daughter Reply with quote
T
Hippie "roll bar" ??? What they are is a collection point for water, therefore rust issues inside the tube. I will be removing them.
EDragnDean
PostPosted: Mon Jul 04, 2016 7:01 pm    Post subject: Re: 73 Thing for the middle Daughter Reply with quote
How I spent my Sunday. Finally got the last of the triple layered, welded, angle iron floors cut out, lots of careful surgery removing the welds without damaging the tunnel/rockers. Frame is in great shape, inner driver rocker needs some rust repair (beyond the hacked out hole to clear the custom seats).
EDragnDean
PostPosted: Mon Jul 04, 2016 7:03 pm    Post subject: Re: 73 Thing for the middle Daughter Reply with quote
Worked the passenger doors, hinges were rusted, now they open and remove as they should. Replaced the seals on the top and bottom of the windshield, and windshield to dash seal. Replaced the missing pad below the glove box. Replaced the connection bar and lubed the pivots on the wiper arms. Making progress slowly...
63ziggy
63ziggy is offline
PostPosted: Mon Jul 04, 2016 7:16 pm    Post subject: Re: 73 Thing for the middle Daughter Reply with quote
Great to see another Thing under restoration in the Houston area.
Keep the pics coming
View user's profile Send private message Send e-mail AIM Address Instagram Gallery Classifieds Feedback
EDragnDean
PostPosted: Tue Jul 05, 2016 4:30 am    Post subject: Re: 73 Thing for the middle Daughter Reply with quote
Thanks Ziggy. I've seen your Thing around, I will introduce myself next time we cross paths.
My plan is not to restore this one, just repairing the floors (and now the driver side rocker) and redoing the mechanicals. Will roll the body as is, shooting for daily driver quality. I've given myself a one year deadline to complete given time and financials.
doublecanister
PostPosted: Tue Jul 05, 2016 10:38 am    Post subject: Re: 73 Thing for the middle Daughter Reply with quote
I know it's probably a tad bit early,
but what's your thought on seats?
I've been mulling swapping mine with some (I think they are BMW) seats I everything was manual on these, now power. But I need
to make their seat tracks fit the THING seat tracks in the floor, so
I found an old cruddy set of seat bottoms to use but they need major cleanup.
Since you don't have seat tracks right now, maybe now's a good time to spec out some seats?
Just asking/mentioning as I'm curious myself what i'd do if it were mine.
Good luck with it and keep the photos coming.
T
1973 - Thing
EDragnDean
PostPosted: Tue Jul 05, 2016 5:52 pm    Post subject: Re: 73 Thing for the middle Daughter Reply with quote
Stock for now. Got some used seat tracks from thingparts.com, even if I decide to install something different, I would like the originals as an option.
EDragnDean
PostPosted: Sun Jul 17, 2016 9:52 am    Post subject: Re: 73 Thing for the middle Daughter Reply with quote
Got the body and pan separated. In the process, both rear shock tower captive nuts spun.
How do you replace those captive nuts? Any thread links? I can't possibly be the first to have this issue... TIA
63ziggy
63ziggy is offline
PostPosted: Sun Jul 17, 2016 10:16 am    Post subject: Re: 73 Thing for the middle Daughter Reply with quote
so it's been a while since I had mine apart. sounds like you are referring to body mount bolt that goes through the shock tower arm up into the bottom of the body.
if so, an easy way to repair/replace a captive nut that is buried behind sheet metal is to cut open a square in sheetmetal around the captive not/bolt area.
you can then weld in new nut or weld old not back in place. then weld sheetmetal square back in place.
hope that makes since.
basically do surgery, open up area, repair, weld back in.
EDragnDean
PostPosted: Sun Nov 20, 2016 8:18 am    Post subject: Re: 73 Thing for the middle Daughter Reply with quote
Making progress.
Separated the pan from the body, trimmed and welded all the necessary attachments (seat tracks, battery mount, seat belt mount, pedal stop, jack points, jack support braces).
Three rims/tires stacked on top of each other make for a good body holder over the pan... wish I had taken pictures of my getto stand... Laughing
Driver side rocker needed rust repair lower three inches inner/outer, and repaired holes on both sides.
Put POR 15 on outer edges of the new floor pans, installed new floor pan seal, then bolted pan halves to body. Dropped body back on the chassis and bolted everything up before welding pan halves to tunnel so I wouldn't have any issues with alignment.
POR 15 with Chassis Black Top Coat.
63ziggy
63ziggy is offline
PostPosted: Sun Nov 20, 2016 8:25 am    Post subject: Re: 73 Thing for the middle Daughter Reply with quote
if you have not already, pull that tape line. Por-15 dried will give you fits removing the tape in crisp line.
EDragnDean
PostPosted: Sun Nov 20, 2016 8:31 am    Post subject: Re: 73 Thing for the middle Daughter Reply with quote
Thanks. BTDT, I removed the tape while still wet.
EDragnDean
PostPosted: Sun Nov 20, 2016 8:45 am    Post subject: Re: 73 Thing for the middle Daughter Reply with quote
Needed to address some rust under the dash/foot well area. Knowing that POR 15 is a bad idea on actual body panels, I just sanded down and applied only the chassis black top coat to the inside of the rockers and under the dash.
EDragnDean
PostPosted: Tue Jan 03, 2017 9:10 pm    Post subject: Re: 73 Thing for the middle Daughter Reply with quote
Working on the rear brakes, and decided to replace the bearing seal.
Question. The outer spacer has a bevel. Does the bevel face in toward the outer bearing or out toward the seal?
74 Thing
74 Thing is offline
PostPosted: Wed Jan 04, 2017 12:09 am    Post subject: Re: 73 Thing for the middle Daughter Reply with quote
Outer rear spacer has the bevel in towards the CVs and the larger part facing outwards and it mates up with the brake drum.
