Does the engine tinware get hot enough to require heat resistant
kai.scott98
kai.scott98 is offline
PostPosted: Tue Jul 05, 2016 1:03 pm    Post subject: Does the engine tinware get hot enough to require heat resistant Reply with quote
Title says it all, can I paint the tinware with normal pearlescent paint and laquer or does it have to be painted with heat resistant stuff?
My bug build "Beelzebug" http://www.thesamba.com/vw/forum/viewtopic.php?p=7842613&highlight=#7842613
raygreenwood
raygreenwood is offline
PostPosted: Tue Jul 05, 2016 3:32 pm    Post subject: Re: does the engine tinware get hot enough to require heat resistant Reply with quote
Depends on the engine and vehicle. In normal running...only the plates close to the muffler get more than about 125-150F with lots of air flowing through the engine compartment.
However once you shut down on a hot day...radiant heat soak can put a lot of the tin closer to 250+. Ray
kai.scott98
PostPosted: Tue Jul 05, 2016 5:21 pm    Post subject: Re: does the engine tinware get hot enough to require heat resistant Reply with quote
So would I be ok painting it pearlescent red and laquered over the top, can I get heat resistant laquer, should I just chance it or should I spray it heat resistant. For what its worth its a 1.2 engine single carb and i live in England, not usually a really hot day.
andk5591
andk5591 is offline
PostPosted: Tue Jul 05, 2016 6:40 pm    Post subject: Re: does the engine tinware get hot enough to require heat resistant Reply with quote
Assuming you have the engine tunes properly, I dont see a problem, but we don't use lacquer much over here anymore. I use regular Rustoleum rattle can paint for my tins and never have an issue. Pretty sure its just a regular enamel
D-Dubya Manx clone - 63 Short pan,1914.
There's more, but not keeping them...
kai.scott98
PostPosted: Wed Jul 06, 2016 1:10 am    Post subject: Re: Does the engine tinware get hot enough to require heat resistant Reply with quote
Yeah the paint I'm using requires,it and I'm putting a silver fleck mixed I the laquer, its how we did the interior and it worked.
