wingman Samba Member
Posted: Mon Jun 27, 2016 6:00 pm Post subject: Help! spindle spacer install |
Hi,
I tried to put my original spindle spacers back to the new drop spindles. They don't go all the way in when I tried to press them by hand. Is it ok to leave them like this and hope bearings and seals will drive it in? Or is there a way to press them in without special tools?
Thanks,
Michael[/img] |
Posted: Mon Jun 27, 2016 6:06 pm Post subject: Re: Help! spindle spacer install |
Heat the rings up in the oven to 400°F and then you should be able to just drop them in place. Have a brass hammer on hand in case they don't go all the way on immediately. |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51057 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Mon Jun 27, 2016 6:49 pm Post subject: Re: Help! spindle spacer install |
That ring has to be fully seated or the bearings will get super loose in a few miles as it seats itself. Warm it up as WT's suggests. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Mon Jun 27, 2016 7:39 pm Post subject: Re: Help! spindle spacer install |
Tried it with heat gun and no bueno. Going to give another try with plastic mallet (no brass hammer on hand) later. |
Tcash Samba Member
Posted: Mon Jun 27, 2016 7:52 pm Post subject: Re: Help! spindle spacer install |
It's stuck on there now.
If you do not have a puller to pull it off.
Heat it with a propane torch.
Use a length of pipe and a Big Hammer to drive it home.
Good luck
Tcash |
Posted: Mon Jun 27, 2016 8:38 pm Post subject: Re: Help! spindle spacer install |
A few more ideas:
1. The book may have a "seating" torque for the bearings. Get everything installed and tighten the nut up to the seating torque and see if that pushes the spacer into place. If so just keep the pressure on until the spacer is all the way seated
2. You could also get a piece of pipe that would fit over the spindle and thus apply an even force to the bearing. Use a moderately heavy hammer, like 2-4 pounds to beat on the pipe. If you could find a washer that would protect the spacer from the pipe that would be a plus.
3. Get a long brass drift or aluminium drift (like a snowmobile axle) and use that to drive the spacer on, working around the spacer to keep it straight. |
Posted: Mon Jun 27, 2016 9:20 pm Post subject: Re: Help! spindle spacer install |
Thanks for all the ideas. Another failed attempt with the mallet but this time it goes in a bit more. I think I will give brass drift a try since it's less destructive. Another question, I somehow remember the races flushed with the surface when I took them off. But it seems there will be a gap even if I manage to push it all the way in. Am I missing something here?
Thanks,
Michael |
richparker Samba Member
Joined: November 24, 2011 Posts: 6936 Location: Durango, CO
Posted: Mon Jun 27, 2016 9:31 pm Post subject: Re: Help! spindle spacer install |
wingman wrote: |
A heat gun isn't gonna do anything. You need to heat that race with a torch and get it super hot, it will slide right on then.
I don't know about the depth difference, what did the spindle manufacturer say? _________________ __________
’71 Westy build
Adventure thread
’65 Deluxe Build |
Posted: Mon Jun 27, 2016 10:05 pm Post subject: Re: Help! spindle spacer install |
I pulled up my original spindles and they have the same gaps as the new ones. I am really confused |
Tcash Samba Member
Posted: Tue Jun 28, 2016 7:13 am Post subject: Re: Help! spindle spacer install |
wingman wrote: |
Same gaps meaning what? They are not pressed on all the way?
Tcash |
Posted: Tue Jun 28, 2016 7:20 pm Post subject: Re: Help! spindle spacer install |
It seems heat and hit with brass punch is a go. But for one side there is like this < 1mm gap b/w rear end of the spacer and the spindle surface while the other side went all the way in. I wonder whether it will cause any issues?
@tcash the gap i mentioned earlier is the one at the front b/w spacer and spindle stem. I did find some online photos with the same gap.
Thanks,
Michael |
Tcash Samba Member
Posted: Tue Jun 28, 2016 7:33 pm Post subject: Re: Help! spindle spacer install |
Run it. What's a mm.
Tcash |
Posted: Tue Jun 28, 2016 8:05 pm Post subject: Re: Help! spindle spacer install |
1 millimeter
If no objection I am going to go ahead and finish my front end tonight |
Posted: Tue Jun 28, 2016 8:25 pm Post subject: Re: Help! spindle spacer install |
Do jack up the bus every week for the next while and see if the wheel wiggles, if that seats down further by itself the bearings will need readjusting. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Thu Jun 30, 2016 12:12 am Post subject: Re: Help! spindle spacer install |
Thanks all! I have installed the front brakes and they look good! Couldn't have done it without your help.
@busdaddy Thanks for the tips. Now I can see your concern about the gap. I will keep an eye on it. |
Posted: Thu Jun 30, 2016 8:07 am Post subject: Re: Help! spindle spacer install |
You don't even need to jack the front up to test for looseness of the bearing. Just grap the top of the tire and give it a good shake in and out. You should feel just a tad of play but not much. If you find that the play increases day to day then go back and tighten the nut a bit more. |
