Gravell Samba Member
Joined: June 03, 2016 Posts: 42 Location: Roanoke, Texas
Posted: Sun Jun 19, 2016 8:30 pm Post subject: Class 11 lift |
Hey Guys,
After reading some posts and looking at what everyone said about thing spindles vs. tweed I am looking at buying thing spindles to put on my 73 beetle to lift the front end. I am also wanting to upgrade my front brakes to disc. This is probably a stupid question, but can I buy a VW thing disc brake kit that includes spindles and knock 2 birds out with one stone? Bolt on the thing spindles to get the lift and the disc brakes to get the added stopping power. |
Brian Samba Moderator
Posted: Sun Jun 19, 2016 9:06 pm Post subject: Re: Class 11 lift |
Yes. A few ways to approach this problem. I think CSP has the market on Thing kits. You can also use Ghia calipers with aftermarket mounting brackets. One of those options is very expensive.
I just remembered that socal imports has some kits that will work. A ton of threads on doing this. I'm planning on doing the same thing.
Goodluck _________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter |
dirtkeeper Samba Member
Joined: February 19, 2008 Posts: 3200 Location: Left of everywhere
Posted: Sun Jun 19, 2016 11:09 pm Post subject: Re: Class 11 lift |
moore parts has the brackets for $40, ghia spindles and calipers and you are on your way . i modified the ghia spindle shield to work with the thing spindle. But the shields aren't necessary. |
Posted: Mon Jun 20, 2016 9:43 am Post subject: Re: Class 11 lift |
dirtkeeper wrote: |
So if I am understanding correctly I need to get calipers and rotors for a ghia or beetle, as long as they fit my 4 lug bolt pattern, and then I can get the brackets from moore parts and they will attach the disc brakes to the thing spindles. Also can I do a straight swap out of my beetle spindles for thing spindles without having to change front beam, trailing arms or front beam? |
Dark Earth Samba Member
gargamel Samba Member
Joined: December 20, 2011 Posts: 693 Location: Orange Grove, Texas
Posted: Mon Jun 20, 2016 12:53 pm Post subject: Re: Class 11 lift |
I lifted the front of my bug with Thing spindles. I quickly learned to also use (at least lower) Thing arms as well since the stock beetle arms were binding and not allowing any up/down movement. Yes, I did flip my lower beetle arms as some suggested but Thing arms was the way to go.
There is an aftermarket caliper plate that will bolt on the Thing spindle (same one used for Bugs) and I got m Ghia calipers on with zero problem. |
Posted: Mon Jun 20, 2016 6:45 pm Post subject: Re: Class 11 lift |
Gravell wrote: |
dirtkeeper wrote: |
Yes to all that . But you need the thing trailing arms to fit the thing spindles |
oldschool5er Samba Member
Posted: Mon Jun 20, 2016 8:04 pm Post subject: Re: Class 11 lift |
My Thing Front end with SoCal disc setup with thing spindle caliber bracket
_________________ HRE in Westerville,Ohio
Full machine shop with all types of CNC. Rapid prototyping available, CNC Plasma cutting, 3D printing and Laser engraving. |
Douglas A Samba Member
Posted: Sun Jun 26, 2016 8:42 am Post subject: Re: Class 11 lift |
oldschool5er wrote: |
Look at Kustom1 warehouse spindles
I cheated and bought a whole new beam
50 / 50 with raised spindles.
Posted: Sun Jun 26, 2016 8:45 am Post subject: Re: Class 11 lift |
50 / 50 came with 3" spindles
Posted: Tue Jul 12, 2016 9:48 am Post subject: Re: Class 11 lift |
what are y'alls opinion on using tweed spindles instead of thing spindles? It looks like I could still use my VW type 1 trailing arms and ball joints with the tweed spindles verses having to swap out trailing arms if I used the thing spindles. |
Joined: August 31, 2013 Posts: 12857 Location: North Carolina
Posted: Tue Jul 12, 2016 10:14 am Post subject: Re: Class 11 lift |
It depends on what you're trying to do with the car, the thing lower ball joints are pointed down so the weight of the car is trying to compress the ball joint instead of separating it. Also due to the lower ball joint being lower in the spindle, and the fact that the whole spindle is forged vs welded together, it is a stronger assembly. If you plan on beating on the car I would suggest the thing arms & spindles.
https://www.thesamba.com/vw/gallery/pix/1393725.jpg _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
enjoyther1de Samba Member
Joined: December 19, 2010 Posts: 1279 Location: chino,ca
Posted: Tue Jul 12, 2016 11:38 am Post subject: Re: Class 11 lift |
Thing arms and spindles are the way to go if you can find them for a decent price. I've BEAT my tweeds off road. Seperated the upper ball joint once on a very sketchy uphill.
New ball joints and a hook and rod kit to keep the joints in check, I'm confident in my spindles. _________________ HBB took me to BBV. |
Posted: Tue Jul 12, 2016 12:11 pm Post subject: Re: Class 11 lift |
Thing parts vs tweeds. Depends on which one you can get and get for less. Personally, I would go with Thing parts. I doubt many here will question VW part quality.
Some sellers do part with their Thing parts for very fair price so try that route first.
Posted: Tue Jul 12, 2016 12:19 pm Post subject: Re: Class 11 lift |
Douglas A wrote: |
Eh, I don't know whose spindles kustom1 is selling but a few other members have had some issues with lesser quality spindles. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Posted: Tue Jul 12, 2016 3:41 pm Post subject: Re: Class 11 lift |
TDCTDI wrote: |
Douglas A wrote: |
Eh, I don't know whose spindles kustom1 is selling but a few other members have had some issues with lesser quality spindles. |
When I was researching this myself, I thought kustom1 had a report
on theirs verses others? I thought they were made in house?
I know they make there front beams or lets say cut them and rebuild them. |
tirekicker Samba Member
Joined: October 16, 2007 Posts: 826 Location: Orange, CA
Posted: Tue Jul 12, 2016 5:52 pm Post subject: Re: Class 11 lift |
enjoyther1de wrote: |
New ball joints and a hook and rod kit to keep the joints in check, I'm confident in my spindles. |
pictures or it didn't happen.
bon jour _________________ DhK
Phuckancer
(16:45:42) Russ_Wolfe: TK, you are like a Maytag washer
(16:46:44) tirekicker: and what's a maytag washer?
(16:47:35) Russ_Wolfe: If you are not agitating, you are not working right |
Posted: Tue Jul 12, 2016 6:29 pm Post subject: Re: Class 11 lift |
We didn't have a photog slowing us down... Those fuckers take up too much room and drink too much beer.
Here's the aftermath.
cbeck Samba Member
Posted: Tue Jul 12, 2016 6:39 pm Post subject: Re: Class 11 lift |
If you go to a trucks gone wild, don't let matt steele anywhere near your cooler. |
Posted: Fri Jul 15, 2016 12:52 am Post subject: Re: Class 11 lift |
Douglas A wrote: |
TDCTDI wrote: |
Douglas A wrote: |
here is there link check them out!
http://www.kustom1warehouse.net/Lifted_ball_joint_...akekit.htm |
