67vwcruising Samba Member
Joined: March 31, 2015 Posts: 127 Location: Carson City NV
Posted: Sat Jun 25, 2016 8:44 am Post subject: Re: oil temp on new build |
Hot oil pressure does not exceed 40 psi at any rpm |
Posted: Sat Jun 25, 2016 9:55 am Post subject: Re: oil temp on new build |
ok, great! Just getting those gaps filled will drop your temps a lot. Report back. _________________ It's just advice, do whatever you want with it!
"Like" our Facebook page at
and get a 5% off code for use on one order for VW Parts ON OUR PARTS STORE WEBSITE, vwparts.aircooled.net |
vw moses Samba Member
Joined: April 17, 2012 Posts: 213 Location: independance,louisiana
Posted: Sat Jun 25, 2016 10:10 pm Post subject: Re: oil temp on new build |
67vw crusing heres a pic of the gen./alt. vent that points straight down
when you rotate yours _________________ Youtube@vw moses
73 thing-gone
66 beetle-gone
62 beetle-gone
57 beetle-gone
convertable-beetle-w/bugspray & screamer dist.(019) gone
"Where There's a Will There's a Way"
63 one of a kind beetle. 57 dash,double rear window--sweet! |
madmike Samba Member
Joined: July 11, 2005 Posts: 5292 Location: Atlanta,Michigan
Posted: Sun Jun 26, 2016 4:00 am Post subject: Re: oil temp on new build |
Ok ,been lurkin,,,
My 1915cc does about the same thing,,has the (don't usethat SLANTED fan shroud,no stock oil cooler at all, just a blockoff & a 72 plate w/fan I turn on mounted over the trans,gaps all over the place too no sled tin ,, hell hardly any tin really ,just the 'forgetmeknots'under the cylinders and the rest of them are CHROME
and It's turbocharged so ever more heated oil coming out of a hotass turbo
I'm not worried at all!!! It still has 10lbs @1000rpm when it's all hot & bothered and I hammer on this thing!!! then cruise to bring the temps back down Cheers,Madmike _________________ 'Black Ice'Drag Buggy 'Turbo'
Rail Buggy 1915 turbo
Posted: Sat Jul 16, 2016 9:03 am Post subject: Re: oil temp on new build |
So the temps still seem ok. 220 at 65mph and 210 around town with 95 deg ambient temperature.
I'm still fighting the weird acceleration from a cruise. It's not so much a fall on Face flat spot. The best way I can describe is it that when I roll on the throttle from cruising about half way it feels like hitting a rev limiter. Just a wall for half a second then accelerates fine.
Timing is@30degrees at full advance
Both carbs reach full throttle at the same time.
Any ideas? |
66brm Samba Member
Joined: January 25, 2010 Posts: 3676 Location: Perth Western Australia
Posted: Sun Jul 17, 2016 8:41 pm Post subject: Re: oil temp on new build |
Could need an accelerator pump adjustment, either its going lean and missfires or rich and floods the spark for a moment. Before you try adjusting them, just try richening up the idle mixture an 1/8th of a turn. _________________ Aust. RHD 66 Type 1
Aust. RHD 57 Type 1 Oval
modok wrote: |
I am an expert at fitting things in holes, been doing it a long time |
Posted: Sat Sep 16, 2017 9:39 am Post subject: Re: oil temp on new build |
Ok, so i know its been a while but I just wanted to post an update.
After a bunch of small things I got the oil temps under control. Here is a list of what i did,
1) change oil to 10w30
2) Fill all gaps in tin
3) Mess with carb linkage till perfect
I also found out that my temp gauge is reading high like everyone said. In 100 degree weather my cold motor is showing almost 120 degrees.
so after everything i took a drive up to Spooner summit. That's 2300 feet in 13 miles and 95 degree ambient. Temps got to 230 and I'm happy with that.
Average highway temps are 190-220 depending on ambient
thanks for all the advice! |
