Steve2150 Samba Member
Joined: April 05, 2016 Posts: 36 Location: Punta Gorda
Posted: Wed Jun 22, 2016 8:35 am Post subject: Turn Signal Switch Help |
On my 1972 standard Beetle the turn signal switch broke, got replacement but it had 9 wires while my original had 6 wires, any help of what goes where would be of help, thanks. |
boater Samba Member
Joined: November 03, 2013 Posts: 98 Location: North Carolina
Posted: Wed Jun 22, 2016 8:45 am Post subject: Re: Turn Signal Switch Help |
You don't need the three wires in question. Instructions should tell you the ones are not needed, just cut and tape . |
Posted: Wed Jun 22, 2016 10:42 am Post subject: Re: Turn Signal Switch Help |
boater wrote: |
Did not come with any instructions |
zoobyshoe Samba Member
Joined: June 26, 2014 Posts: 461 Location: San Diego, Ca.
Posted: Thu Jun 23, 2016 12:42 pm Post subject: Re: Turn Signal Switch Help |
I just replaced the turn signal switch on my '72 a couple months ago. I noticed how someone had cut some of the connectors on the old switch. I had no idea why, so I connected everything that was there on the new switch. There have been no problems with it, so, I would say that, even if you don't need some of the connections, it doesn't seem that you need to make sure they're not connected, either. |
runamoc Samba Member
Joined: June 19, 2006 Posts: 5601 Location: 37.5N 77.1W
Posted: Fri Jun 24, 2016 8:08 am Post subject: Re: Turn Signal Switch Help |
My old one wouldn't stay 'lit' on the righthand turn. Had to hold the stalk a little off of the stop. Notice the new one I bought had 6 wires and that on the right side a contact was further over. I spliced the pairs together. Works great and all fit back into the housing.
_________________ Daily driver: '69 Baja owned 44 yrs - Plan B: '81 Rabbit Diesel LS Deluxe - Plan C: '72 Ghia
Yard Art: 2 Sandrails
Outback: '69 Ghia - '68,'69,'70,'72 Beetle - '84 Scirocco, GTI - Pair of '02 Golfs-
VW Wiring = It's just wires |
