robertburdett Samba Member
Posted: Wed Jun 22, 2016 8:37 pm Post subject: Tire size |
I am looking for some advice. I have a 1967 Karmann Ghia and I was wondering what a good tire size is? The car has 2.5 inch drop spindles on a stock width beam. The tire size is 135SR15 in the front and 165SR15 in the back. I am looking for a tire that is going to provide more stability while cruising the highway. I was thinking 195/60-15 in the front and 205/65-15 in the back. Any suggestions would be greatly appreciated.
Robert |
Danwvw Samba Member
Posted: Wed Jun 22, 2016 8:41 pm Post subject: Re: TIRE SIZE |
No need to go bigger than 165's on the front.. 135's are funky! Do what you want in the rear 165's or bigger. _________________ 1960 Beetle And 1679cc DP W-100 & Dual Zeniths! |
kiwighia68 Samba Member
Joined: October 20, 2013 Posts: 2878 Location: Auckland, New Zealand
Posted: Wed Jun 22, 2016 8:59 pm Post subject: Re: TIRE SIZE |
robertburdett wrote: |
Robert |
I had 185/60/R15s with the same set-up (2.5" drop with stock width beam) but the tyres were too big and damaged my newly painted fenders. The rear can take tyres up to 195 or 205 in width, but the front is problematic. I think 155's are going to be the widest you can go at the front, provided the tyres don't stand higher than 24.5". Perhaps the 145/65/R15 - found on Smart cars. _________________ Festina lente - hasten slowly
1968 Ghia named Emiko
Resto completed Dec 2015 |
sactojesse Samba Member
Joined: November 21, 2006 Posts: 2655 Location: Sacramento, California, USA
Posted: Wed Jun 22, 2016 10:06 pm Post subject: Re: TIRE SIZE |
195/60R15 won't fit in front with a stock width front beam and drop spindles. What rims do you have? Depending on your rims and offset, you can probably fit up to a 165/65R15 up front. _________________ 1966 Karmann-Ghia convertible |
lonotch Samba Padrino
Joined: August 28, 2004 Posts: 3304 Location: So. Cal. Oceanside GFK!
Posted: Thu Jun 23, 2016 7:48 am Post subject: Re: Tire size |
205's in the back will work but will be very tight, I would go with 195's to be safe. _________________ It's not about the window, it's about the people.
German Folks |
mlhsquared Samba Member
Joined: October 13, 2008 Posts: 1482 Location: Strasburg, VA
Posted: Thu Jun 23, 2016 9:45 am Post subject: Re: Tire size |
'67s have a "long axle" in the back. Anything other than stock is very iffy. It largely depends on the wheel that you use. I am running 155s on Porsche 2-liter replicas and it is very tight! _________________ Mike
'67 Ghia Coupe |
Posted: Thu Jun 23, 2016 9:52 am Post subject: Re: Tire size |
mlhsquared wrote: |
'67s have a "long axle" in the back. Anything other than stock is very iffy. |
Very true. _________________ 1966 Karmann-Ghia convertible |
NWGhiaGuy Samba Member
Joined: March 16, 2005 Posts: 700 Location: Bellingham, WA
Posted: Thu Jun 23, 2016 3:24 pm Post subject: Re: Tire size |
sactojesse wrote: |
mlhsquared wrote: |
Very true. |
These are 185/55/15s with SHORT axles on the rear of my '66, but the wheels are 5.5 wide/ET15. Just switching to a 5.5/ET25 made all the difference.....
