richierich Samba Member
Posted: Mon Jun 20, 2016 1:23 pm Post subject: Help with carb damage (pic) |
Just had engine delivered after 3000 mile journey and.....damage to one of the carbs (EMPI 48 IDA's)
Will i be able to get this something like back into shape and will it be likely to have caused any damage to critical parts?
Broken manifold aswell but going to get that welded. |
theDrew Samba Member
Heinz57 Samba Member
Joined: June 23, 2008 Posts: 141 Location: Smyrna, GA
Posted: Mon Jun 20, 2016 2:16 pm Post subject: Re: Help with carb damage (pic) |
Yes that linkage and arm is replaceable but get rid of the return spring on the carb. I guess you have another on the other carb too. Only use one where the cable attaches to the Hex bar arm. Having springs on the carbs wears out the throttle shaft bushings. Only should have the small spring that wraps around the throttle shaft. _________________ 1970 Baja 1641cc, 1965 Gltterbug Buggy 1641cc and a 1989 Jeep Cherokee XJ |
Posted: Mon Jun 20, 2016 2:23 pm Post subject: Re: Help with carb damage (pic) |
This is how I found it in the crate. Will I have to replace that whole shaft or will i be able to gently bend that tab back around straight? |
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20378 Location: Just a tiny bit west of Yosemite Valley
Posted: Mon Jun 20, 2016 2:34 pm Post subject: Re: Help with carb damage (pic) |
Remove tab from throttle butterfly shaft before you try to massage it back to where you want it... If you are lucky butterfly shaft did not get bent.....
Heim joint and rods are all replaceable, any good parts place that deals with carburetors should lave parts.... CB Performance comes to mind....
Never mind what others say about return spring, its the most positive you can have (almost requirement on most sanctioned racing) , just be sure it is not to strong and it slams butterfly closes to hard and does not tire out your leg when driving.... I put these types of springs on all my dual carb engines...
IF you packed up the engine, it is sad, if someone else did it for shipping ask if they will help with the repairs...
vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15303 Location: Deep in the 405
Posted: Mon Jun 20, 2016 2:42 pm Post subject: Re: Help with carb damage (pic) |
I'd be calling the people that sent you the engine. Looks like the manifold was broken off at the flange. _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
Featured in Dec. 2001 HOT VW's Magazine page 63
Watch my racing video's http://www.youtube.com/user/okvwracer/videos |
Posted: Mon Jun 20, 2016 2:44 pm Post subject: Re: Help with carb damage (pic) |
Are those holes in manifolds for Nitrous injectors?
Posted: Mon Jun 20, 2016 2:51 pm Post subject: Re: Help with carb damage (pic) |
It was crated by the shippers in Miami and I am going to be speaking to the shippers tomorrow to try and get some money back.
I dont like messing with carbs at all really but i can remove that tab without the shaft all falling to pieces?
Dave - it did - the manifold broke at the bottom - its gone to a guy today who says he can weld it up. |
Posted: Mon Jun 20, 2016 2:52 pm Post subject: Re: Help with carb damage (pic) |
Dale M. wrote: |
Dale |
Not sure Dale....i did wonder what they are for myself |
Posted: Mon Jun 20, 2016 2:55 pm Post subject: Re: Help with carb damage (pic) |
Im confident i'll be able to straighten the rod but its the little tab thing im concerned about |
jfats808 Samba Member
Joined: December 10, 2007 Posts: 5022 Location: oahu hawaii
Posted: Mon Jun 20, 2016 3:17 pm Post subject: Re: Help with carb damage (pic) |
When I crate an engine, I don't put the carbs/manifolds on. I preset the linkage geometry before and remove before shipping. Also the box was poorly made. I flush the valve covers and run posts all the way down. This also helps for backing to screw to. Then a cross brace midway and on the top before capping it with ply cover. The box is built flush to the flywheel and front. He used straps which are fine. I usually use banding. Hope the shipper accommodates u. I would contact the seller also. _________________ 2276 IDA's 86C 11-1 DD !
2017 48 Trijet DRLA's W125
Rockstar Suzuki wrote: |
You might as well put 10 year build in your bullshit sig, as it will NEVER run. Also your a dick |
You can always learn something new, even from a fool.
Check your oil levels routinely! |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51125 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Mon Jun 20, 2016 4:16 pm Post subject: Re: Help with carb damage (pic) |
richierich wrote: |
I'd be asking the shippers for a new set of carbs, that's a piss poor crating job to say the least. Too tight to the carbs and just 2 lousy poly straps in close holding it to the pallet, always assume it's going to get pushed out of the back of the truck and land on it's side and plan for it. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
esde Samba Member
Joined: October 20, 2007 Posts: 5966 Location: central rust belt
Posted: Mon Jun 20, 2016 4:21 pm Post subject: Re: Help with carb damage (pic) |
you might want to have the flange surface ground after welding to be sure that it's flat. At very least check it thoroughly. _________________ modok wrote:
Posted: Tue Jun 21, 2016 12:48 pm Post subject: Re: Help with carb damage (pic) |
I have notified the shippers of my extreme distaste for their attempt to break my engine and am waiting to hear back.
In the meantime, I have to remove the cylinder head as the broken manifold may have dropped a bit of debris into the ports and want to be sure there's nothing in there. Assuming all equal and good, when re-fitting would you guys replace the pushrod tubes or just the seals? Will only be doing the one side... |
Posted: Tue Jun 21, 2016 2:11 pm Post subject: Re: Help with carb damage (pic) |
You have to look and see if there's any damage. The seals being that new shouldn't be a problem reinstalling. You have to inspect. If all checks out, I would reuse. You could buy new seals and have just in case. _________________ 2276 IDA's 86C 11-1 DD !
Posted: Tue Jun 21, 2016 2:17 pm Post subject: Re: Help with carb damage (pic) |
jfats808 wrote: |
You have to look and see if there's any damage. The seals being that new shouldn't be a problem reinstalling. You have to inspect. If all checks out, I would reuse. You could buy new seals and have just in case. |
Yep, that's a good idea, I'll do that - thanks for the advice! |
Posted: Wed Jun 22, 2016 12:33 pm Post subject: Re: Help with carb damage (pic) |
Ok - managed to straighten the bent tab on the throttle shaft arm (fortunately the shaft isn't bent) and the rod and got the welded manifold back - he's done a great job, you can't even tell its been repaired. Thanks so much for everyone's help with this. |
