What did you do for your Type 3 today?
Page: Previous  1, 2, 3 ... 198, 199, 200 ... 222, 223, 224  Next
ALLWAGONS
ALLWAGONS is offline
PostPosted: Fri May 13, 2016 1:38 pm    Post subject: Re: What did you do for your Type 3 today? Reply with quote
Awesome pics! i was a creeper and looked at your photobucket. Some cool scenery right out of FEAR THE WALKING DEAD!
NON INFLUENCER APPROVED
Stevo Wide 5
Stevo Wide 5 is offline
PostPosted: Fri May 13, 2016 2:04 pm    Post subject: Re: What did you do for your Type 3 today? Reply with quote
yeah that was a blast going to the Ghost Town! Here r some pics!
62 Type 3 Notchback
Check out my Aircooled blog @ http://stevo.skyblogs.be
Wide 5 Vintage Volkswagen Club
http://www.wide5.com
Stevo Wide 5
PostPosted: Tue May 24, 2016 3:05 pm    Post subject: Re: What did you do for your Type 3 today? Reply with quote
I treated the square to a coat of owatrol!!!
62 Type 3 Notchback
PeteLeary
PeteLeary is offline
PostPosted: Sun May 29, 2016 5:55 pm    Post subject: Re: What did you do for your Type 3 today? Reply with quote
Wow that ghost town looks crazy! Where is it? Do you have anymore pics?
chaosisme
chaosisme is offline
PostPosted: Sun May 29, 2016 8:20 pm    Post subject: Re: What did you do for your Type 3 today? Reply with quote
Whats owatrol?
'65 1500 S [quareback]
'68 FI Sunroof Squareback
'70 Westy
OCT3 - Orange County Type 3's
Tram
Samba Socialist
Location: Still Feelin' the Bern- Once you've felt it you can't un- feel it.
Tram is offline
PostPosted: Sun May 29, 2016 8:36 pm    Post subject: Re: What did you do for your Type 3 today? Reply with quote
http://www.owatroldirect.co.uk/product/polytrol/
Perhaps you, too, can "Google"... Smile
Bryan67 wrote:
To best contact me, please use the EMAIL function in my profile
chaosisme
PostPosted: Sun May 29, 2016 8:46 pm    Post subject: Re: What did you do for your Type 3 today? Reply with quote
My google-fu failed. I found something they make that keeps rusty stuff rusty.
'70 Westy
Stevo Wide 5
PostPosted: Tue May 31, 2016 9:46 am    Post subject: Re: What did you do for your Type 3 today? Reply with quote
Installed a roof rack and blinds!!!!
62 Type 3 Notchback
ALLWAGONS
PostPosted: Tue May 31, 2016 1:15 pm    Post subject: Re: What did you do for your Type 3 today? Reply with quote
nice!
Rome
Rome is offline
PostPosted: Sat Jun 18, 2016 7:55 pm    Post subject: Re: What did you do for your Type 3 today? Reply with quote
IN the past few weeks, got the engine running again. 1679cc, stock valve home-ported DP heads, C25 cam, 8:1 CR. Current layout has rebuilt 32PDSIT Solexes with snug throttle shafts, disabled choke, and stock jetting. All factory ball sockets in the carb linkage replaced with heim joints purchased from McMaster Supply. Older, decent quality 009 distrib.
Problem in past was the 40DCNF carbs ran well but car had poor fuel economy. I switched to the Solexes, but the last time the engine ran and I could drive the car it had a bad misfire above part-throttle. It sat this way for about 3 yrs.
First step was replacing all fuel hoses in the engine compartment. Each one had developed a leak! Verified TDC by removing #1 spark plug, rotating engine until the fan timing markings for TDC lined up with the engine case split. Observed the TDC piston position through the spark plug hole using an inspection mirror and flashlight. I pulled out the distributor to verify the distrib. drive gear position, which was correct with the slot angled, and the larger portion of the offset pointing to the rear of the car. Installed the distrib, rotating the body until the timing slot on the edge lined up with the rotor which was pointing to approx. "10:00" position. Then wired the spark plug cables starting with #1 above the rotor.
Engine started up quickly, and ran smoothly when revved. Got out the timing strobe light and saw the idle was at about 15-20 BTDC- way too early. Problem was the 009's condenser was tight against the fan housing so I could not rotate to retard the timing. Turned off engine, turned it to the confirmed TDC position, lifted up the distrib body and rotated it 1/4 turn CCW so that the condenser cleared the fan housing. Oriented the plug cables 1/4 sequence so that #1 was again above the rotor. Thanks to a recent comment from Max Welton on this topic. Started up engine, then set timing to 30 degrees BTDC per the fan timing marks and the strobe light with engine revving at about 2500rpm.
Fuel pressure per in-line test gauge was at 2.5 to 2.8psi.
Next was to get the carb linkage in order. Used the factory procedure from theSamba tech section http://www.thesamba.com/vw/archives/manuals/t3dualcarbtuning/index.php
It was already close, but the right linkage rod heim joint needed to be rotated about 2 turns so that it did not "lead" the left carb linkage rod. After setting both carbs to "best lean" and measuring airflow with a Uni-Syn, the engine idled nicely for a good 20 minutes. Phew. Success.
On my brief test of the car in the driveway, the brake pedal felt unusually firm, not progressive. After parking the car and turning off the engine, I heard a "squirt" sound when I pressed the pedal Shocked . Then looked at the driveway and saw a trail of liquid spots and a small puddle where I stopped and shifted from reverse to first. Damn- brake line leak Mad . Turns out the main brake line along the trans tunnel rusted through near the pedals, and a second leak spot at the junction of the left rear hard line to the LR brake hose. Worse than this, I was shocked to see full rust-through on the floor pan under the pedals, and a tennis-ball rot hole in the bottom center of the pan spine near the frame "T". Could look right up to the inside "ceiling" of the tunnel. This will require significant cutting and welding to remedy. Hmm- not hard to guess the source- car is parked outdoors with just a good quality car cover, so it is exposed to rain. Rust holes at top of front fender rear edge must've let water into the interior which collected on the floor during my 3 years of storage. Air vents in cowl are covered with magnetic sheets so they were not a source of the water ingress.
All 4 bumper mounts on the body are also rotten and need to be replaced. Luckily CIP1 and ISP West sell Tabco repair panels for those areas.
Plan is to get 4 new tires (the front two 185/65 now on it are 23 yrs old and dry rotting), new brake lines and hoses. Get it driveable, get its NY state safety inspection, then take it to a friend who has good welding equipment at his VW/Audi repair shop to weld-patch the pans at half-day intervals, driving home after each session.
Here's the car from 2006 when it was a bit more solid.
Donnie strickland
Donnie strickland is offline
PostPosted: Sat Jun 18, 2016 8:29 pm    Post subject: Re: What did you do for your Type 3 today? Reply with quote
Glad you got some of your problems sorted.
Never use a car cover on a vehicle which is parked outdoors long-term. The car will still get wet, but the cover will not let the moisture escape, greatly accelerating the rust process. BTDT with my 66 Bug.
71 Elm Green FI A/T Squareback
Peters Van
Peters Van is offline
PostPosted: Sun Jun 19, 2016 12:27 am    Post subject: Re: What did you do for your Type 3 today? Reply with quote
new tail light housing to lens gasket on the panelvan
no more tail lights half full of water after i wash it
1965 Type 3 Panel Van
1963 EH Holden Station Wagon
Bobnotch
Bobnotch is offline
PostPosted: Sun Jun 19, 2016 11:19 am    Post subject: Re: What did you do for your Type 3 today? Reply with quote
Yup, I learned that lesson years ago...never use a car cover outdoors. In my case, it stripped the paint off in places, requiring a complete repaint. Since then, the cars just sit outside in the weather.
Glad to hear you've got it running again Roland. I'm sure you're happy about that part. Cool
We're still rebuilding parts of Rob's car. Getting close to laying some epoxy primer to seal the bare metal, now that most of the welding is done in the rear 1/3rd of the car. I've also been doing a Steve, and playing around on my mini bike. Very Happy
Bob 65 Notch S with Sunroof
Tram wrote:
Tram wrote:
axeman569
axeman569 is offline
PostPosted: Wed Jul 06, 2016 9:43 pm    Post subject: Re: What did you do for your Type 3 today? Reply with quote
Today I brought my Notch home. I bought it in 1985 when I was a kid. It has been in my Dad's garage ever since. I will post pictures soon.
Stevo Wide 5
PostPosted: Wed Jul 06, 2016 11:46 pm    Post subject: Re: What did you do for your Type 3 today? Reply with quote
Played around with different offsets and tire sizes until I found the perfect ride quality and stance for my 63!
62 Type 3 Notchback
SBD
SBD is offline
PostPosted: Thu Jul 07, 2016 7:59 am    Post subject: Re: What did you do for your Type 3 today? Reply with quote
Looks GOOD! ME LIKEY! Cool
"Just $99 down and $64 a month for 36 months buys you a brand new Volkswagen Beetle!"
mark tucker wrote:
I wouldent waste $ or thyme on building a small motor. build it big so it dosent have to work hard.remember it's only as fast as your foot alows it to be unless you build a small turd then it just stinks as it squishes up through your toes when you step on it.
thom
thom is offline
PostPosted: Tue Jul 19, 2016 6:49 am    Post subject: Re: What did you do for your Type 3 today? Reply with quote
Raised mine up about 3/4"
-Thom
1956 Single Cab
1957 Porsche 356A Sunroof
1957 23-Window Deluxe
1963 Unimog 404
1965 E-Type
Alan Patten
Alan Patten is offline
PostPosted: Sat Jul 23, 2016 6:07 pm    Post subject: Re: What did you do for your Type 3 today? Reply with quote
Built new fresh air hoses, not that I need heat now, but come winter I'll have a toasty ride.
Oreganoflow
Oreganoflow is offline
PostPosted: Mon Aug 01, 2016 11:02 am    Post subject: Re: What did you do for your Type 3 today? Reply with quote
dodged maybe 1000 potholes, only took one good one to take me down...
stonecoldcars
stonecoldcars is offline
PostPosted: Mon Aug 01, 2016 4:08 pm    Post subject: Re: What did you do for your Type 3 today? Reply with quote
Removed, dissasembled, cleaned, lubed and re-installed the speedo to eliminate the horrid screaming noise. Sooo much better now and i can maybe avoid those pesky speeding tickets.. Or not.
My build thread(The desert Rat). http://www.thesamba.com/vw/forum/viewtopic.php?t=653395
Page 199 of 224
