JiI Samba Member
Joined: February 18, 2006 Posts: 1845 Location: Michigan
Posted: Wed Nov 25, 2015 11:29 pm Post subject: |
But only up to 2002 year engines.
Jeff |
Iguana Samba Member
Posted: Fri Nov 27, 2015 12:18 am Post subject: Re: the subaru dream |
A/C in a Buggy is done as even with the roof etc missing it does wonders to keep you cool on a hot day stuck in traffic and is awesome when it comes to demist.
I have Heat and Air and being desert season it is AWESOME to cruise around in jeans and a t-shirt while others are all rugged up
As for the EZ30 they run just fine on the stock ECU outside of the Subaru. In fact here is one with what is left of the loom running happily and about to go into a Baja Bug, funnily enough it is getting A/C and heat as well.
herkster Samba Member
Joined: February 14, 2013 Posts: 428 Location: Boca Raton, FL
Vito85 Samba Member
Posted: Mon Dec 14, 2015 9:38 am Post subject: Re: the subaru dream |
well the car is a complete car (kelmark GT )
so the A/C will be nice ( specially here in TX )
I'm still dreaming / planning
I got this idea...... what if..........
I really would like to make it as mid engine because.....
if I use a complete subaru engine with transmission...... I still can use the same ECU and no changes or alterations ( I hope make sense )
kind of a 818 kit car
something like this
using this
so...... will look like this ( but with IRS rear )
now......... if I can use the same IRS arms to hold/set up the subaru front wheels..... which will be my rear wheels......... sounds good
now the issue is....... how to do it ?????? |
weasel_ugs Samba Member
Joined: March 16, 2012 Posts: 721 Location: Prescott Valley,Az.
Posted: Mon Dec 14, 2015 6:05 pm Post subject: Re: The Subaru dream |
Going mid eng and keeping the Suby 5spd will save you on a super beefy VW trans.
As for mating Suby axles to VW suspension, get 930 stubs and have the axles re-splined to 930 CV joints.
Or go BIG! My dad had a baja with a 455 oldsmobile eng in the back. Used a 68Olds Toronado front end and took frame and all into the back of a bug using eng, trans axles and suspension. |
Vito85 Samba Member
Posted: Tue Jun 14, 2016 7:06 am Post subject: Re: The Subaru dream |
a 455 oldsmobile eng in the back. Used a 68Olds Toronado front end and took frame and all into the back of a bug using eng, trans axles and suspension......
I think a turbo subaru 4 cyl will have the same power and is up to date technology and less space too
the issue its just the money to do it ........ lol |
Posted: Tue Jun 14, 2016 6:20 pm Post subject: Re: The Subaru dream |
Vito85 wrote: |
Hmmm, 400hp with 500ft lbs of torque? This was also built in the 80's. |
