Smallest tire a port-a-wall will sit properly on?
Forum Index -> Custom Wheel/Tire Share: Facebook Twitter
THEPISTONHEAD
THEPISTONHEAD is offline
PostPosted: Tue Oct 11, 2011 9:18 pm    Post subject: Smallest tire a port-a-wall will sit properly on? Reply with quote
Wondering what the smallest size tire/low pro that I can run a port-a-wall insert on and have the insert sit against the tire.
Trying to use this as my determining factor on how low to go. Ive ran 135's and had the overhang of the white wall. Trying to avoid that even though 135's seem to be the ultimate!!!!
Thanks!
Egorspyle65
Egorspyle65 is offline
PostPosted: Wed Oct 12, 2011 2:22 pm    Post subject: Reply with quote
Im running them on 145-65-15 with no problem. Ive also run them on 135s with no problem. Depends on the size portawall you have too.
THEPISTONHEAD
PostPosted: Wed Oct 12, 2011 11:03 pm    Post subject: Reply with quote
Any pics by chance?
blackp5ca
blackp5ca is offline
PostPosted: Thu Oct 13, 2011 5:09 am    Post subject: Reply with quote
Here's a set of portawalls on my 58, 145/65 smarts up front, 165's out back. The fronts had to have the lip saver shaved off the rubber for the portawalls to sit flush against the sidewall but no issueas at all after that.
THEPISTONHEAD
PostPosted: Thu Oct 13, 2011 6:35 am    Post subject: Reply with quote
That is perfect!!!! PM-ing you to find out your suspension set-up.
Phat bug
Phat bug is offline
PostPosted: Thu Oct 13, 2011 1:31 pm    Post subject: Reply with quote
I've run the "ATLAS" inserts on 125's, no problems.
Click to view image
Egorspyle65
PostPosted: Thu Oct 13, 2011 4:40 pm    Post subject: Reply with quote
I had to cut the rim saver lip off my 145/65/15s too. After that they fit perfect.
Mondo
Mondo is offline
PostPosted: Thu Feb 09, 2012 10:14 pm    Post subject: Very nice Reply with quote
I hope my 58 looks that good.
I will do something like that with mine, if you don't mind me asking, how did you set your suspension? I'm putting on drop spindles from Wolfgang and not sure how to do the rearend..
I like the way you set yours up..
Mondo..
6sixTinBox
6sixTinBox is offline
PostPosted: Wed Mar 28, 2012 3:50 pm    Post subject: Reply with quote
I tried "searching" and this is the closest result thread I came to my question and it's still not what I'm looking for. Does anyone know if port-a-walls will fit on 165/50/15s? These are the port-a-walls:
http://www.thesamba.com/vw/classifieds/detail.php?id=785180
Thanks in advance!
1966 13 Window Deluxe
It is what it is
blackp5ca
PostPosted: Fri Mar 30, 2012 8:38 am    Post subject: Reply with quote
Ooo..I don't know. If it did fit, I think it might look goofy..even on the smart car tires there is almost not enough sidewall for it to look right (in my opinion) Being the black/red porta-walls you're looking at it might look a little better but you're pushing that insert almost right to the tread..I don't think it would last too long, or seat properly once the tires are weighted with a little bulge at the contact patch?
The tire comparrison..
145/65-15 3.7in Sidewall
165/50-15 3.2in Sidewall
6sixTinBox
PostPosted: Fri Mar 30, 2012 2:07 pm    Post subject: Reply with quote
^^ I did read that they'd probably get eaten up on turns on short sidewalls. I wonder if anyoen has had any success with trimming the circumferance down? Thanks for the input.
It is what it is
DaKine
DaKine is offline
PostPosted: Sat Mar 31, 2012 5:08 pm    Post subject: Reply with quote
THEPISTONHEAD wrote:
Any pics by chance?
I'm running the same as blackp5ca with 185/60 in back. Cool
6sixTinBox
PostPosted: Sat Mar 31, 2012 5:29 pm    Post subject: Reply with quote
135's up front? Looks sweet, so does the bug on sprints in the back. Very nice.
It is what it is
flemcadiddlehopper
flemcadiddlehopper is offline
PostPosted: Sun May 06, 2012 5:05 pm    Post subject: Reply with quote
I have been wondering the same thing, because I want to run 185/55s up front and 205/50s in the back of my Bus and porta-walls would look sweet on it, in either a wide white or the narrow red stripe.
So, has no one run them on low profile tires? A 185/55 and a 205/50 still have 4" sidewalls and the wide white portas are 3" ?
gordo.
rollo6fo
rollo6fo is offline
PostPosted: Mon May 07, 2012 5:37 pm    Post subject: Reply with quote
You can run them on small tires...but you have to make sure the tires dont have the rim savers on them like smart car tires.. It keeps the porta walls from laying flat..
63 oval rag "Swaggen"
76 Weekender " The Krusty Krab"
78 Champagne Adventurewagen " Mr Hanky"
ChickenChit
ChickenChit is offline
PostPosted: Wed Mar 13, 2013 12:05 pm    Post subject: Reply with quote
135s front, 165s out back. They work great.
Will6
Will6 is offline
PostPosted: Mon Jun 13, 2016 2:30 am    Post subject: Re: Smallest tire a port-a-wall will sit properly on? Reply with quote
Are they 15 x 2 or 3" inserts. I have 145 and 155 continental smart car tires? Thx
Keep the Beetle Heart Beating...VWCPR
Reply to topic    Forum Index -> Custom Wheel/Tire All times are Mountain Standard Time/Pacific Daylight Savings Time
