Help with 85 cabrio needed
Forum Index -> Water-cooled VW Share: Facebook Twitter
white85cabrio
white85cabrio is offline
PostPosted: Thu Apr 16, 2015 11:15 am    Post subject: Help with 85 cabrio needed Reply with quote
I need help with my wife's car it wont stay running, I have changed the injectors the plugs , wires , cap, and rotor, it just will not stay running unless i keep reving it up and even after doing that for awhile it will die out. any ideas???
GermanIronWerks
GermanIronWerks is offline
PostPosted: Fri Jun 10, 2016 12:07 pm    Post subject: Re: Help with 85 cabrio needed Reply with quote
Fuel.pump/filter im goi g through the same.thing right now
TDCTDI
Samba Advocatus Diaboli
TDCTDI is offline
PostPosted: Fri Jun 10, 2016 12:22 pm    Post subject: Re: Help with 85 cabrio needed Reply with quote
Big vacuum leak? Was this all of the sudden? Has the car been sitting for a long time? What kind of rotor & cap did you use? (if not the Bosch orangish ones, replace them again), what spark plugs? (Use only the cheap Bosch copper or NGK, it'll foul all the others)
kamzcab86
kamzcab86 is offline
PostPosted: Sun Jun 12, 2016 7:13 pm    Post subject: Re: Help with 85 cabrio needed Reply with quote
http://www.cabby-info.com/fuel.htm#CIS
~Kamz Anxious
2016 Golf GTI S
Reply to topic    Forum Index -> Water-cooled VW All times are Mountain Standard Time/Pacific Daylight Savings Time
